battery for 56 New Yorker Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
lenover |
Member Posts: 27 | I have to replace my 5 year old battery and wondered if someone can advise me on the maximum size battery I can replce it with. I don't have an electric fuel pump installed so sometimes I have to crank it over a number of times to start it. Thanks | ||
59 in Calif |
Elite Veteran Posts: 1102 Location: Hayward, Calif | I always buy a batt with the longest warranty life as possible that will fit in the batt tray. | ||
Expert 5K+ Posts: 9911 Location: Lower Mainland BC | lenover - 2018-10-29 9:21 AM I have to replace my 5 year old battery and wondered if someone can advise me on the maximum size battery I can replce it with. I don't have an electric fuel pump installed so sometimes I have to crank it over a number of times to start it. Thanks You might want to consider going with a Pertronix ignition conversion and Pertronix coil. I switched and my engine fires right up much better than it did with dual points and a normal 12V coil and ballast resistor. http://www.pertronix.com/ 59 in Calif - 2018-10-29 9:55 AM I always buy a batt with the longest warranty life as possible that will fit in the batt tray. Agree. I am running a Group 24 battery in my 56 Dodge but I think that a Group 27 would fit. I think a Group 27 is what a 56 Chrysler would need. I am in Canada and am looking at this one: FEATURES MotoMaster Nautilus Group 27 Starting & Deep Cycle Battery is a premium starting and deep cycle battery Engineered for power, stamina and reliability Start your boat and/or power accessories such as trolling motors or electronics Group size 27 800 marine cranking amps, 80 amp hours, 150 minutes reserve capacity Dimensions are 12.5 L x 6.75 W x 9.3" H (31.8 x 19.6 x 23.6 cm) Edited by 56D500boy 2018-10-29 11:43 AM (Group27Battery.jpg) Attachments ---------------- Group27Battery.jpg (28KB - 146 downloads) | ||
lenover |
Member Posts: 27 | Thank you fellow Mopar owners for the helpful tips! | ||
Expert Posts: 3778 Location: NorCal | I'd go with a Group 27 with the highest CCA (Cold Cranking Amps) you can find. | ||
Expert 5K+ Posts: 9911 Location: Lower Mainland BC | 56D500boy - 2018-10-29 11:40 AM I am running a Group 24 battery in my 56 Dodge but I think that a Group 27 would fit. I think a Group 27 is what a 56 Chrysler would need. I am in Canada and am looking at this one: Group size 27 800 marine cranking amps, 80 amp hours, 150 minutes reserve capacity Dimensions are 12.5 L x 6.75 W x 9.3" H (31.8 x 19.6 x 23.6 cm) Had some time this (Sunday) afternoon so I drove the old girl to Canadian Tire (just for the drive) to check out the Group 27 battery size. I measured 12.5" at the top (and presumably at the bottom). The maximum space that I have in my existing 56 Dodge rubber battery tray is about 11.5". The Group 24 that I am running is about 10.5". The larger battery tray (for the Group 27 batteries) was 12.875" long but I don't have that tray. Too bad. Oh well. Edited by 56D500boy 2018-11-04 7:43 PM (55-58ElectricalSystemSchematicDiagram.jpg) (55-58ElectricalSystemBatteryTrayPNsAndSizes.jpg) Attachments ---------------- 55-58ElectricalSystemSchematicDiagram.jpg (187KB - 155 downloads) 55-58ElectricalSystemBatteryTrayPNsAndSizes.jpg (182KB - 162 downloads) | ||
58 DESOTOS RULE |
Expert Posts: 2308 Location: The Bat Cave, Fairborn, OH | Now that's interesting. I am talking about the searchable parts book for the 1955-58 Mo Par line. I have this book in its original format (paper in a binder) with pen and ink corrections made by partsmen at the local Chrysler dealership back in the day as they say, but I didn't know there was apparently a copy on line that can be searched. Do you have the website url where that resource can be found? | ||
Expert 5K+ Posts: 9911 Location: Lower Mainland BC | 58 DESOTOS RULE - 2018-11-06 11:28 AM ...but I didn't know there was apparently a copy on line that can be searched. Do you have the website url where that resource can be found? Yes, I have posted the link several times during my 2 years on this forum. Downloadable service manuals are available here: http://www.mymopar.com/index.php?pid=109 The parts catalogs are available here: http://www.mymopar.com/index.php?pid=107 How I personally use them is shown here: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=66548&... Have fun. I have the paper versions for both the full lines for 56 American Mopars and 56 Canadian Mopars but I use the pdf version daily. Edited by 56D500boy 2018-11-06 1:32 PM | ||
58 DESOTOS RULE |
Expert Posts: 2308 Location: The Bat Cave, Fairborn, OH | Thanks! I will check it out. | ||
