Reinstalling push buttons and swapping back in a pushbutton 727 into a 58 Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
plumfloored |
Regular Posts: 54 Location: Avondale, AZ | I am looking to swap a car back to push buttons from a floor shifted 727 late model I bought a 61 361 and 727 to reinstall. Looking at buying the push buttons, and trim bezels and cables What other part s? Which cable to buy? | ||
Expert Posts: 3777 Location: NorCal | A 727 won't mate to a '61 361 without an adapter or a crankshaft change. A '62-'64 pushbutton cable will install on a '57-'61 pushbutton shifter. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | 57chizler - 2018-10-10 1:09 PM ...A '62-'64 pushbutton cable will install on a '57-'61 pushbutton shifter. If you happen to pick one with the right length like from a truck. | ||
Expert Posts: 3777 Location: NorCal | Passenger car cables of that era were 42"-48" long, I used one in my '57 NY with a 727. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Mine came from a '63 B-body and was about 6" too short. I don't have information to compare the other lengths. | ||
CrAzYMoPaRGuY |
Veteran Posts: 154 Location: Locked in my Canadian garage.... | Egads I'm gonna try to do this too lol My car was a 3 in the tree. Converting to an automatic. I don't want a floor shifter. Don't like the look!!!!! I found a three speed torqueflight pushbutton shifter, excellent shape, no cables so I bought it. I know where a 1965 two cable big block trans is. I will have to find two cables I assume, and figure a way to activate the parking cable.....? Cut my dash and install the shifter, hook it up and..... ?!? lol | ||
Expert Posts: 3777 Location: NorCal | The '65 (and the '64 console shift) use a different shift cable than the pushbutton trans, it won't mate up directly to the PB shifter. You can used a PB cable in the '65 trans but it must be adjusted using the '65 instructions, not the PB instructions. If you want the Park function, you can mount a park mechanism under the dash to actuate the Park cable. (Park Low.jpg) (Park plate.jpg) Attachments ---------------- Park Low.jpg (68KB - 217 downloads) Park plate.jpg (60KB - 210 downloads) | ||
RICKYMOPAR |
Veteran Posts: 292 Location: Colorful Colorado skier on the license plate | 62 to 64 Imperial push button shift cables are 54 inches long. If this would help. Edited by RICKYMOPAR 2018-10-25 6:39 PM | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Thanks Richard! Good to know. I will search for a couple of them so I can swap mine out. | ||
RICKYMOPAR |
Veteran Posts: 292 Location: Colorful Colorado skier on the license plate | I was just wondering....Is there an adapter plate and torque converter centering plate system available for a 727A to the early B and RB engines? Changing and re-balancing crankshafts sucks. Edited by RICKYMOPAR 2018-11-05 9:23 PM | ||
Handygun |
Elite Veteran Posts: 1118 Location: STL, MO | The bolts in that box look familiar | ||
