Removing a 57 Dodge engine and transmission
Randy Schultz
Posted 2018-09-05 10:45 PM (#569667)
Subject: Removing a 57 Dodge engine and transmission
Working on my first fin car and was wondering if it is better to split the engine and trans for removal or take them out as a unit. I have an engine hoist that will handle both but as long and bulky as the torque flite looks I am worried about it clearing the firewall heater unit coming out. Its a 325 poly. But separating them is pretty tough with the adapter plate set up it has, I cant get to all the bolts. Any recommendations?
Posted 2018-09-05 11:58 PM (#569671 - in reply to #569667)
Subject: Re: Removing a 57 Dodge engine and transmission
500020002000500100252525
I would remove the iron part of the trans from the bellhousing. Then remove the motor & bellhousing as one unit. That would be much easier to do in the end and won't risk smacking into stuff.
Randy Schultz
Posted 2018-09-06 11:44 PM (#569734 - in reply to #569667)
Thanks I didn't think of splitting it. I'm used to one piece Torqueflites.
