1957 Dodge DR front doorpanel Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
FINS! |
Elite Veteran Posts: 943 | I need a '57 Dodge Driver side front 4dr door panel. I need something for a core. If you have one and even if you think it's too rough please let me know, I might be able to use it. I think the style I need was used in Royals and Custom Royals and the upper level wagons. | ||
Expert 5K+ Posts: 9915 Location: Lower Mainland BC | FINS! - 2018-09-03 11:47 AM I need a '57 Dodge Driver side front 4dr door panel. I need something for a core. If you have one and even if you think it's too rough please let me know, I might be able to use it. I think the style I need was used in Royals and Custom Royals and the upper level wagons. 1. Not sure what you have to work with but if it is something, you could make your own core using 1/8" hardboard, as per this post of mine: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=69434&... 2. If you had absolutely nothing for the driver's door, the front passenger door is exactly the same core (only reversed left/right). It was stamped out on the same machine back in the day. 3. If you had absolutely nothing but the vinyl, etc, you could make a paper template by taping tracing paper to the door and marking it up with a Sharpie, then trimming the paper and retrying, marking where the holes for the clips need to be. With that done, then you could follow my door panel post linked above. 4. If you didn't want to make your own, REM Automotive probably has what you need. Just be clear exactly what model you have, year, etc., number of doors, sedan or hardtop, etc. http://www.remautoinc.com/products.php Mine (not REMs): Edited by 56D500boy 2018-09-03 12:22 PM | ||
FINS! |
Elite Veteran Posts: 943 | Thanks, it's the material I am after, really the back center portion. Great tips though thanks! | ||
FINS! |
Elite Veteran Posts: 943 | I meant "black" center portion of the material.... Anyone parting a '57 or have any door panels they saved? Edited by FINS! 2018-09-10 11:49 AM | ||
Expert 5K+ Posts: 9915 Location: Lower Mainland BC | FINS! - 2018-09-10 11:48 AM I meant "black" center portion of the material.... Anyone parting a '57 or have any door panels they saved? It would help if you could give us a photographic clue. Any of these look familiar (in pattern?) If so, you will probably have to go to SMS in Portland to get what you need. | ||
uncltank |
Extreme Veteran Posts: 380 Location: Kennewick Wa | I will check my storage unit tomorrow. I bought a set of door panels for the trim. I think the material inside the trim was salvageable. | ||
uncltank |
Extreme Veteran Posts: 380 Location: Kennewick Wa | PM sent | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | I have a complete set and sent you a PM. | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | I have all the original door panels . Iphone won’t load pics. I sent you my phone #. | ||
