Stripped hub 1955 chrysler
Marshall
Posted 2018-08-12 7:25 PM (#568319)
Subject: Stripped hub 1955 chrysler
I have a hub with a stripped lug thread. Can you get a helicoil?
RICKYMOPAR
Posted 2018-08-20 7:47 PM (#568724 - in reply to #568319)
Subject: Re: Stripped hub 1955 chrysler
100100252525
Yes you can, buy the kit with the tools. drill, tap, installation tool and inserts. Being you only need one repair. left hand thread will be more difficult to find.
lug bolts were used until 1959 in Plymouth.
Edited by RICKYMOPAR 2018-08-21 7:34 AM
Posted 2018-08-20 7:59 PM (#568727 - in reply to #568319)
500020002000500100252525
I don't recommend doing that for a wheel lug. Probably best to get a replacement hub from BigM.
51coronet
Posted 2018-08-21 1:10 AM (#568741 - in reply to #568319)
1001001002525
if they are anything like the later hubs ( sorry no idea) you can remove the lug and replace it. May take a cutting wheel etc or a swage cutter to remove but is doable. There are over the counter lugs with the same spline pattern (again this applies if they are like the later ones 57 and later). Avoid pounding and pressing the lug out as it can or will enlarge the spline pattern on the hub due to the swaging of the lug. Cutting may be your best option. Grinder and a cut off wheel can make easy work of this.
Sorry if this misleads you but my response is based on swaged lugs as equipped on 57 and later. I have not worked on prior to 57 hubs.
Posted 2018-08-21 8:44 AM (#568748 - in reply to #568319)
They aren't the same. They use lug bolts, not lug nuts like the later ones.
Posted 2018-08-21 12:14 PM (#568768 - in reply to #568727)
20001000500100100252525
Powerflite - 2018-08-20 4:59 PM
A properly installed Heli-Coil is just as, or more, reliable than the original thread. You're threading into hardened steel instead of the original cast iron/steel.
