1959 383: Which exhaust manfold bolts penetrate the water passages?
fivespeedv8
Posted 2018-06-22 1:27 PM (#565454)
Subject: 1959 383: Which exhaust manfold bolts penetrate the water passages?
I had my engine rebuilt by a machine shop, and upon return, the exhaust manifold studs on each end of the heads have fine threads exposed, but the newer-appearing middle studs are coarse thread.  I was going to replace them with studs that all have matching threads, but I know that some (all?) of them penetrate a water passage and I don't want to risk leaks.
Can anyone tell me which ones to pay special attention to (use sealer, teflon, etc).  some online sources say just the end ones, others say the middle ones do too...but those are all related to newer engines, 440, etc.
Thanks!
Posted 2018-06-23 11:43 AM (#565500 - in reply to #565454)
Subject: RE: 1959 383: Which exhaust manfold bolts penetrate the water passages?
20001000500100100252525
Only the two end holes in each head go through to water, the center holes are blind so no worry about leaks.
fivespeedv8
Posted 2018-06-23 12:20 PM (#565502 - in reply to #565454)
Subject: Re: 1959 383: Which exhaust manfold bolts penetrate the water passages?
thanks!
