Location: Park Hills, KY | I am measuring for the B&T conversion through Driveshaft Specialist, INC, in San Antonio. From the face of the e brake drum to the center line of the pinion yoke, I have between 60 7/8" - 60 15/16" as I measure this distance (by myself).
To Ian, and anyone else who has done the conversion..... Does this sound like the correct distance? will 1/16 inch make or break this potential upgrade?
Also, their measuring sheet asks if the pinion yoke has a "tab". I do not see anything of the sort on mine.
Lastly, I am wondering if anyone knows the bolt circle diameter on the flange of the ball and trunnion.
Thanks so much for your help!
Chris |
(if needed) Info on measuring vehicles for a custom driveshaft. U-Joint Flange- Pinion Yoke measurements. ID of different Driveshaft Types.
http://www.driveshaftspecialist.com/HTML%20Measure/MeasureList.html
http://www.driveshaftspecialist.com/Left-Column/Antique-Classics.ht...
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=47966
Edited by mstrug 2018-05-22 12:54 PM
(M1-6 1pc trans flange & reg pinion.JPG)
Attachments ---------------- M1-6 1pc trans flange & reg pinion.JPG (116KB - 195 downloads)
Location: Park Hills, KY | Thanks...Already completed that part. I now only need the distance across the outside of the ball and trunnion flange. It's either 3 5/8 or 4 ".
Location: northern germany | Before you do that, think twice. Search this site. Usually conversions should be an upgrade, not a downgrade. Keep ist forwardlook. |
Location: So. Cal | It is forwardlook Sid. The Dodge trucks of this era had the same setup. In fact, you can just shorten a forwardlook Dodge truck driveshaft to fit right into your car, and it will have all the conversion parts all ready to go on it. |
