ANY HELPFUL HINTS ? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | Hi Guy's, Ok so I have rebuilt my 318 Poly & the cast iron Torqueflite. I hope to bolt these together this weekend & fit them to the Fury anybody have any helpful hints when fitting the trans to the converter & how do you know the pump drive sleeve is engaged correctly ? Any hints or tip will be greatly appreciated Cheers Gra | ||
Expert 5K+ Posts: 7400 Location: northern germany | you MUST use guiding rods as described in the manual. line the sleve up with the converter and it slides right in. do not force the tranny together with bolts if you can't make the case touch the bellhousing by hand. important, do not forget to oil the sleve and the seal before you install. | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | Thanks Sid I did read the manual I'll have to make up some guide rods today. Cheers Gra | ||
Expert 5K+ Posts: 7400 Location: northern germany | and if you only removed the case and left the TC in place, you might want to flush the TC with kerosene before you install the transmission. | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | TC has been serviced/reconditioned. Just had a look at the back of the block there are no locating dowels ? Is that normal ? I can't find anything in the workshop manual about locating dowels. | ||
Expert 5K+ Posts: 7400 Location: northern germany | never worked on a 318 but i think there should be dowel pins. okay, i thought you are going to install ci box with the bellhousing and converter still in the car. | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | No it's all out everything has been rebuilt. I want to put it all in before I mount the inner panels & front mudguards I can't find a picture anywhere of the rear of the block mighty Google has failed me | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | There are two locating dowels for the bell housing, one at 3 o'clock and one at 9 o'clock on the block. With the TC and bell housing in place, install the guide studs into the bell housing as Sid described. Try to line up the pump sleeve with the mating features of the TC before you slide the trans into the bell housing. | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | Ok so I have another thread in the transmission section as I now believe something is wrong as there are now dowels & my bellhousing may only have 1 hole for a dowel see pic's (bell1 (Medium).jpg) (bell2 (Medium).jpg) (block (Medium).jpg) Attachments ---------------- bell1 (Medium).jpg (141KB - 119 downloads) bell2 (Medium).jpg (151KB - 123 downloads) block (Medium).jpg (66KB - 124 downloads) | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | Ok after a bit of a struggle it went together it'll be in it's rightful place tomorrow Thanks for the info guy's (20180330_115144 (Medium).jpg) (20180330_140126_resized (Small).jpg) Attachments ---------------- 20180330_115144 (Medium).jpg (209KB - 127 downloads) 20180330_140126_resized (Small).jpg (57KB - 117 downloads) | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Good job Graham Edited by ttotired 2018-03-30 6:09 PM | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | Thanks Mick | ||
firedome |
Expert Posts: 3155 Location: NY & VT | The Porsche guys (and they're even worse that the Ferrari nuts) love Brad Penn Grade 1 racing oil at low viscosities in their high performance engines, it's semi-synthetic and has high ZDDP levels. Nobody is more anal , so if it's good enough for them... use the best oil you can buy in the lowest appropriate viscosity. | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Hey graham, just noticed you have your rocker covers on around the wrong way Plug lead holders to the back | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | firedome - 2018-04-02 3:48 AM The Porsche guys (and they're even worse that the Ferrari nuts) love Brad Penn Grade 1 racing oil at low viscosities in their high performance engines, it's semi-synthetic and has high ZDDP levels. Nobody is more anal , so if it's good enough for them... use the best oil you can buy in the lowest appropriate viscosity. I use Castrol trans max Z or Penrite classic | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | ttotired - 2018-04-02 10:13 AM Hey graham, just noticed you have your rocker covers on around the wrong way Plug lead holders to the back Hmmm that's they way they were when I got it no biggie I'll swap them around did you notice there the same colour as the roof. I'm going to add a slant 6 PCV valve instead of dumping the fumes it should fit straight in the rocker cover outlet | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | I did notice that the red was a deeper shade than the red normally used on mopar I cant remember what PCV valve I used on the dodge. I used one mostly so I didn't have oil film blown under the car making a mess | ||
OzFury |
Veteran Posts: 172 Location: Newcastle, NSW AUSTRALIA | ttotired - 2018-04-03 10:25 AM I did notice that the red was a deeper shade than the red normally used on mopar I cant remember what PCV valve I used on the dodge. I used one mostly so I didn't have oil film blown under the car making a mess Shhh it's a Mazda colour | ||
