Location: Lower Mainland BC | MyMGs - 2018-03-07 10:25 AM
I am restoring a 1955 Dodge Lancer with the Powerflite transmission and i need the axcelerator bushings #14-11-20 Engine bracket with Bushing if that is the only way that it can be obtained and also the Body Bracket #14-11-20 with bushing if that is the only way the bushing can be obtained.
David
14-11-20 is the section of the Parts Catalogue, not the part number per se. I think that the part numbers that you would need for the brackets are shown below, 1617 434 and 1617 132. As you can see, there were no sub-assembly parts, i.e. bushings. Therefore you will have to get creative and/or lucky and probably recreate the bushings out of a hard plastic like Delrin or oil-lite bronze.
Good luck.
(55-56ThrottleLinkagePartNumbers.jpg)
Attachments ---------------- 55-56ThrottleLinkagePartNumbers.jpg (209KB - 100 downloads)
