1961 Imperial tapered axles
LouisHarper
Posted 2018-01-22 10:56 AM (#556734)
Subject: 1961 Imperial tapered axles
I goofed up and buggered the first few threads on the driver's axle shaft when using the janky slide hammer from the parts store. How do I go about getting the axle shaft out of the car? The end was mushroomed a bit when pulling the drum, as well.
Posted 2018-01-22 12:13 PM (#556744 - in reply to #556734)
Subject: Re: 1961 Imperial tapered axles
50005000200010002525
Use a pipe and a flat piece of steel and pull the shaft out with the crown nut.
If the threads are molested you need a thread file
LouisHarper
Posted 2018-01-22 3:30 PM (#556755 - in reply to #556744)
Do I put the pipe on the axle shaft (behind the castle nut) and hit it with the steel bar? What's the thread pitch/nut size specifically for the axle shaft?
Edited by LouisHarper 2018-01-22 3:32 PM
Posted 2018-01-22 4:02 PM (#556756 - in reply to #556734)
No, the pipe must rest on the axle tube, adapted in lenght, the flat steel plate with a hole that fits the axle shaft resting on the pipe and the use the nut to pull the axle shaft out.
The wrench size is 1-1/4", so I presume that the threads are 3/4" UNF
Ev's62Chrysler
Posted 2018-01-22 6:22 PM (#556765 - in reply to #556734)
100100
You did disconnect the brake line and remove the backing plate first, correct? Pay attention to any shims. I imagine it's the same as 62. See link.
http://jholst.net/62-service-manual/rear-axle.pdf
3/4-16 is the thread size for my 62 Chrysler.
Robert
LouisHarper
Posted 2018-01-23 10:10 AM (#556788 - in reply to #556734)
I have everything torn out of the rear axle, including the shocks! I kept track of all the shims as well. I take it I need a stiff file and 3/4'' die to right my wrong. Fortunately, the threads aren't fouled beyond the cotter pin hole so this should be a mild headache, rather than a shooting migraine.
Edited by LouisHarper 2018-01-23 10:11 AM
