decode punch card
57RID500
Posted 2018-01-14 10:48 AM (#556202)
Subject: decode punch card
Could someone decode the attached IBM Punch Card for my 1957 Dodge Royal Lancer?
Thank you
Posted 2018-01-14 11:36 AM (#556209 - in reply to #556202)
Subject: RE: decode punch card
50002000200050010010010010025
57RID500 - 2018-01-14 10:48 AM
Could someone decode the attached IBM Punch Card for my 1957 Dodge Royal Lancer? Thank you
Nothing attached.
Try again. This time start your thread in the Fender/VIN Tag and Broadcast Sheet Decoding sub-forum
http://www.forwardlook.net/forums/forums/forum-view.asp?fid=55
Your photo doesn't show because you are probably using a device, e.g. Apple, that puts a .jpeg extension on the file. This FL forum doesn't like those. They have to have .jpg (no "e") extensions.
Then someone might be able to help.
Edited by 56D500boy 2018-01-14 11:36 AM
57RID500
Posted 2018-01-14 12:01 PM (#556211 - in reply to #556202)
Subject: Re: decode punch card
I keep trying, First message is file must be less than 500 mgb! so I cut picture in half, Now message is must be less than 250 MGB!
Posted 2018-01-14 12:56 PM (#556213 - in reply to #556211)
57RID500 - 2018-01-14 12:01 PM I keep trying, First message is file must be less than 500 mgb! so I cut picture in half, Now message is must be less than 250 MGB!
The limit is 250 kB (kilo not mega bytes). 1024 x 764 is usually around 150 kB which is usually an option but with a IBM card you will want to keep resizing until it is just under 250 kB.
And .jpg, not .jpeg, right?
