Imperial to New Yorker Rear Brake drums Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
FINS! |
Elite Veteran Posts: 943 | Would Imperial rear brake drums fit on New Yorker hubs? I am just trying to get a car rolling to so I can get it moved to me. It's a 57 New Yorker It has no rear brake drums. I have several extra Imperial rear brake drums but no New Yorker ones. Or is there something that would prevent them from going on? | ||
Shep |
Expert Posts: 3398 Location: Chestertown, NY ( near Lake George) | Different axle hub size, too big?? Or different diameter drums are some basic issues. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | FINS! - 2017-11-25 11:21 AM Would Imperial rear brake drums fit on New Yorker hubs? I am just trying to get a car rolling to so I can get it moved to me. It's a 57 New Yorker It has no rear brake drums. I have several extra Imperial rear brake drums but no New Yorker ones. Or is there something that would prevent them from going on? There might not be an issue with the size of the drums (12") BUT I think the issue is the bolt circle size. I think the Chryslers are 5 x 4.5 whereas the Imperials are 5 x 5.5, i.e. won't fit REFERENCE: http://www.carnut.com/specs/gen/chry50.html | ||
KcImperial |
Expert Posts: 2490 Location: Kansas City, KS | 56D500boy - 2017-11-25 12:36 PM There might not be an issue with the size of the drums (12") BUT I think the issue is the bolt circle size. I think the Chryslers are 5 x 4.5 whereas the Imperials are 5 x 5.5, i.e. won't fit This is correct. Imperial has a larger size bolt pattern and will not interchange with other Chrysler products | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Then I presume it would be possible to take Imperial hub/drums front and back if one would like to use Imperial rims? | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | The rear axle shafts are a larger diameter so the rear drums will not fit on a Chrysler axle. The front spindles are different too but I don't remember how. Greg | ||
finsruskw |
Expert Posts: 2289 Location: Eastern Iowa | Where you located? I have drums. | ||
KcImperial |
Expert Posts: 2490 Location: Kansas City, KS | LD3 Greg - 2017-11-26 7:49 AM The rear axle shafts are a larger diameter so the rear drums will not fit on a Chrysler axle. The front spindles are different too but I don't remember how. Greg Front spindles are different due to spindle diameter. Imperials use A3/A5 bearings instead of the common A2/A6 | ||
FINS! |
Elite Veteran Posts: 943 | Thanks Greg, I thought that might be the case. | ||
FINS! |
Elite Veteran Posts: 943 | Sent you a pM | ||
hemidenis |
Expert Posts: 3887 Location: Northen Virginia | that is an Imperial dilemma on the restoration process, a lot of parts are exclusive, even between 57-58-59 what at first look seem identical cars they are not. | ||
