Need Standard Trans Dimensions
Posted 2017-11-08 12:46 PM (#551851)
Subject: Need Standard Trans Dimensions
20001000252525
I'm planning a transmission swap and am hoping somebody here has a '57-'58 V-8 3-speed standard transmission out of the car that they can take some measurements from. I am in need of the following dimensions:
1) Dimension from the front of the case to the tip of the input shaft.
2) Diameter of the front bearing retainer where it enters the bellhousing
3) Length of the front bearing retainer from the front of the case.
4) Diameter of the front bearing retainer where the throw out bearing rides.
Posted 2017-11-08 2:17 PM (#551855 - in reply to #551851)
Subject: Re: Need Standard Trans Dimensions
200020005001001001001002525
What swap are you planning? Sounds like you are thinking of adapting the original bell housing.
Posted 2017-11-08 5:19 PM (#551864 - in reply to #551855)
20001000252525
Yes, I want to swap in a later A-230. I'd like to get an idea of what's gonna be involved without having to pull the existing trans. I'm hoping the A230 input shaft is longer so I can make a simple plate adapter between the trans and the bellhousing.
Edited by 57chizler 2017-11-08 5:22 PM
(CIMG0646 (Small).JPG)
(CIMG0645 (Small).JPG)
Attachments CIMG0646 (Small).JPG (120KB - 68 downloads)
Attachments CIMG0645 (Small).JPG (152KB - 77 downloads)
