Typical wire gauge to switches/lights/etc? Also, alternator? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
ViperMan |
Regular Posts: 53 | Hey folks, So a bit more poking around under the hood of my '56 has lead me to determine that she simply needs a thorough rewiring job. I've done this kind of thing before so I'm no stranger to it, but I want to make sure I'm using the right stuff. I'm not looking to replicate the cloth-wrapped look of the original wiring - that stuff traps moisture, grease, etc, and simply isn't safe by today's standards. So I'm going to use modern wire, but I'm just not sure what gauge to use for the typical circuits - headlight switch to headlights, cigarette lighter, dash indicators, etc. I'm going to use low-gauge stuff (4-10) for things like the starter, solenoid, ammeter, etc, and will piece that out as I need it, but for the 14-18 range I'm going to buy some spools in different colors to simply have on hand. Also, quick second question: has anyone upgraded the generator to a modern alternator, and any suggestions on what to buy and how to wire it in? As I'm eventually planning to add air ride, a modern stereo, etc, I need to make sure I'm producing plenty of amperage. Thanks! | ||
finsruskw |
Expert Posts: 2289 Location: Eastern Iowa | Consult the wire schematic in the FSM All that info is in there along w/the color wires for each. | ||
ViperMan |
Regular Posts: 53 | finsruskw - 2017-11-07 8:59 AM Consult the wire schematic in the FSM All that info is in there along w/the color wires for each. My apologies - I probably should have dug around here a bit more before posting. What is the "FSM", if I may ask? Is that here on the site? Thanks. | ||
Expert 5K+ Posts: 9914 Location: Lower Mainland BC | ViperMan - 2017-11-07 10:11 AM My apologies - I probably should have dug around here a bit more before posting. What is the "FSM", if I may ask? Is that here on the site? Thanks. Factory Service Manual. You didn't say which 56. I just checked the 56 Plymouth FSM pdf that I downloaded some time ago. Wire sizes vary. Lots of 14 and 16 gauge. Some 18 gauge. All marked on the diagram with the colours. | ||
Expert 5K+ Posts: 9914 Location: Lower Mainland BC | Just found this 56 Dodge diagram that I posted awhile ago - it shows example wire sizes: | ||
ViperMan |
Regular Posts: 53 | 56D500boy - 2017-11-07 11:36 AM ViperMan - 2017-11-07 10:11 AM My apologies - I probably should have dug around here a bit more before posting. What is the "FSM", if I may ask? Is that here on the site? Thanks. Factory Service Manual. :) HAH - duh... Thanks for the info. | ||
ViperMan |
Regular Posts: 53 | Any help with the alternator, by the way? I read that I can basically just drop in a newer alternator - was going to go with something from a 70's or 80's car perhaps - and then just need to find/fab a bracket. Any advice? | ||
Expert Posts: 3779 Location: NorCal | Depends on the amp rating of the alternator, for factory 37-46 amp alternators 10-12 gauge is sufficient but for aftermarket high output units match the wire gauge top the output. | ||
ViperMan |
Regular Posts: 53 | 57chizler - 2017-11-09 3:28 PM Depends on the amp rating of the alternator, for factory 37-46 amp alternators 10-12 gauge is sufficient but for aftermarket high output units match the wire gauge top the output. Oh I was definitely going to run high-gauge alternator wire. What I'm trying to determine is what's the best way to upgrade to a modern, high-output alternator. Just looking for some tips. | ||
Expert Posts: 3779 Location: NorCal | I'm running one of these with a #6 wire directly to the battery cable. https://www.ebay.com/itm/GM-Chrome-Universal-100-Amp-1-Wire-Internal... (Alternator (Small).JPG) Attachments ---------------- Alternator (Small).JPG (161KB - 151 downloads) | ||
