1955 Plymouth build date ? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Is there any way to determine the build date of a '55 Plymouth? Neither the body tag under the hood nor the serial tag on the door frame have a build date. Mine is serial 20816283 and from what I've found online is that it should be an Evansville car and in the later part of the production run. I need to get a new synchronizer for the transmission. The parts book shows a changeover on 16 August 1955. So, I don't know what to buy as I have no idea when my production date was. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | 71charger_fan - 2017-09-27 12:41 PM Is there any way to determine the build date of a '55 Plymouth? Neither the body tag under the hood nor the serial tag on the door frame have a build date. Mine is serial 20816283 and from what I've found online is that it should be an Evansville car and in the later part of the production run. You sure? Typically there is a four digit SCHD (Scheduled build date) on the body tag, e.g. 0831. Your VIN number is very late in the Evansville series for 1955 so I would think that you are past the change over date (BUT that is just a WAG). Edited by 56D500boy 2017-09-27 1:07 PM (55-56PlymouthModelDesignationsAndSerialNumberRanges.jpg) Attachments ---------------- 55-56PlymouthModelDesignationsAndSerialNumberRanges.jpg (152KB - 172 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | My body tag says 307-E 5821. Would that mean 21 August 1955? | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | 71charger_fan - 2017-09-27 2:32 PM My body tag says 307-E 5821. Would that mean 21 August 1955? I was guessing/hoping that you had a body build tag something like mine where SCHED = 0515 = May 15, 1956 (for my 56 Dodge) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I'll have to give the car a good going over, but I've only found two tags. One has only the serial number and one has only the body number. | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | 307-E 5821 The 307 is the model number of your car, E for the Evansville body and 5821 is the sequential production number for bodies built for model 307 at the Evansville body plant.. Plymouth started using body tags later than the other divisions and I am not sure if Evansville ever did. The Evansville body plant was small (built by Graham-Paige in 1927) and bodies had to be shipped out from the Mack Avenue body plant to have enough bodies for final assembly. That was the main reason why the Evansville plant was closed and a new plant built in St.Louis. Evansville could not build all the bodies needed for production and there was no enough property to expand the plants. The last 1955 models were built in August,1955 and 1956 production started in September. Looked in the parts book and they list a different countershaft gear that changed around August 16, 1955. No changes to the synchronizers. There is more precise information given to identify the which unit changed - the ID stamping on the transmission. These numbers and letters are stamped into the transmission and not cast. The early part number, 697 823, was used with transmission 1322 758 stamped with the letter K. This was used up to August 16, 1955. After August 16, 1955, part number 1633 761 was used intermittently with transmission 1635573 stamped with the letters CK. So check the transmission casing for the above numbers and letters. That should take you in the right direction. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I guess I'll crawl under there tomorrow and try to find a stamping on the transmission. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I looked at the transmission and did not see any stamp on it. I saw what might have been faint traces of white paint on the driver's side of the case. However, I don't know if the stamps were paint stamps or stamped into the metal. | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | Should be stamped into the transmission case. Check on the right (passenger) side just below the centre line and toward the front. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Thanks. I guess I'm crawling under there again. | ||
