Exhaust manifold bolts coming loose
ram300
Posted 2017-09-05 9:36 PM (#547811)
Subject: Exhaust manifold bolts coming loose
1001001002525
I have a friend who is having problems with exhaust manifolds bolts coming loose and blowing out gaskets after 100 miles or less ! He is using bolts that are about 1 1/4 inch long with no spring/lock washer just a factory type HD flat washer. He was also advised to only torque to 20ftlb by gasket manufacturer.
I've suggested a longer bolt, a spring/lock washer and torque to 30-35ftlb. Don't really want to go down the loctite route. will spring washers lose their tension? Did all early cars run spring washers on exhaust from factory?
Any tips advice to get these gaskets to stay in place, being a 426 in a tight engine compartment it is a real bear to change them out.......
Thanks
Owen
Posted 2017-09-05 10:25 PM (#547813 - in reply to #547811)
Subject: Re: Exhaust manifold bolts coming loose
5000200020005001002525
The factory generally used studs. Studs don't loosen up as easily, but I generally do use lock washers with them. They will lose their spring after a while, but they will still be effective once they are rusted on there.
60 dart
Posted 2017-09-05 11:35 PM (#547816 - in reply to #547811)
50002000100050010010010010025
go to epay and look up the "lock nuts" of the correct size --------------------------------------------------later
57plybel
Posted 2017-09-06 4:39 AM (#547821 - in reply to #547811)
Subject: RE: Exhaust manifold bolts coming loose
500252525
Ive forgotton the exact terminology but remember them resembling a castle/ castellated nut (finer slots) .... front of it pinched maybe and held tight  by slight interference.... pretty much single use items.
Colin
finsruskw
Posted 2017-09-06 9:22 AM (#547828 - in reply to #547821)
2000100100252525
They are often referred to as 'stover nuts'
Fastenall calls them 'top loc' nuts.
rebel
Posted 2017-09-09 7:03 PM (#548064 - in reply to #547828)
If you can go with studs, use a little longer stud and double nut them. Won't ever come loose.
Bob
Posted 2017-09-09 10:04 PM (#548074 - in reply to #547811)
50001000500
Stage 8 sells kits:
http://www.ebay.com/itm/like/391512235821?chn=ps&dispItem=1
