Two steps ahead, one back: Generator issue - not charging Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | I took the Dodge out yesterday to chase some of its own parts for a change. I started kind of hard, like the starter was stuck but it did start. Drove around a bit. Noticed that even at speed, the Ammeter was (-) not (+). Hmmm... Stopped to go into a shop. When I came out, it wouldn't start, wouldn't even turn over. Battery. Merde. Fortunately, there was a Canadian Tire store within walking distance so I walked down there and bought a Lithium Ion Battery jumper pack (their house brand with 750 peak "boosting" amps). It was precharged to 100%. Walked back and after a couple of tries, got the engine started and drove home. Parked the car and put the charger on the battery for a few hours. Checked the voltage at the battery after I stopped charging. 12.58 V. Okay (battery was new last September). With the engine running, I checked the voltage at the two terminals on the generator. 0.2 V. Okay, dead. Or very very sick. Now to get the generator tested properly and either get it rebuilt or find a good new one. Tricky because this generator drives my PS pump. Edited by 56D500boy 2017-08-03 11:37 AM (DForgies56D500EngineBayJuly28_2017_2.jpg) (DForgies56D500EngineBayJuly28_2017_3.jpg) Attachments ---------------- DForgies56D500EngineBayJuly28_2017_2.jpg (240KB - 181 downloads) DForgies56D500EngineBayJuly28_2017_3.jpg (159KB - 185 downloads) | ||
Expert Posts: 3777 Location: NorCal | Before assuming that any part is faulty, follow the troubleshooting procedures in your FSM Charging section. | ||
LostDeere59 |
Extreme Veteran Posts: 406 Location: Hilltown, PA | During your extended stereo project did you have the battery disconnected, or did it go mostly dead? If so maybe the generator just needs to be re-polarized. Used to do that on VW Beetles all the time. Unfortunately I don't remember the proper diagnosis, or polarization procedure. It involved jumping battery to the generator in some fashion . . . Anyone recall? Gregg | ||
DepsilonD |
Elite Veteran Posts: 792 Location: Buena Park, CA | You jump from the + side of the batter to one of the terminals, just can't remember which one. And I had my generator rebuilt for $60 so that may be your best bet if that is the issue. And it is not that hard to separate from the power steering pump. And it will give you a chance to make sure the coupler is in good shape. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | LostDeere59 - 2017-08-03 1:58 PM During your extended stereo project did you have the battery disconnected, or did it go mostly dead? If so maybe the generator just needs to be re-polarized. Used to do that on VW Beetles all the time. Unfortunately I don't remember the proper diagnosis, or polarization procedure. It involved jumping battery to the generator in some fashion . . . Anyone recall? Gregg DepsilonD - 2017-08-03 2:19 PM You jump from the + side of the batter to one of the terminals, just can't remember which one. And I had my generator rebuilt for $60 so that may be your best bet if that is the issue. And it is not that hard to separate from the power steering pump. And it will give you a chance to make sure the coupler is in good shape. I drove the car to a local (10 min away) Starter and Generator/Alternator place this AM to have them check it out. All the guy did was check the voltage at the battery with the engine running. It was 12.18V so he pronounced the generator faulty. I would have to take it off and bring it back for the bench test and rebuild. I came home and phoned my NOS parts guy (who was a Mopar mechanic for 40 years) and told him the story. He asked me whether, I removed the big "red" wire and checked for connection to the battery. I said no, and still have to do that. He suggested that if the wire didn't give me battery voltage, I have wiring problem. During my valve cover restoration project (May/june/july), I had the generator disconnected and the battery disconnected so it could be: a) a wiring issue (I did try to fix some of the wiring but I might have failed) b) a polarization issue (of which I have no clue) Edited by 56D500boy 2017-08-03 5:00 PM | ||
DepsilonD |
Elite Veteran Posts: 792 Location: Buena Park, CA | To polarize, you just use a jumper wire from the + terminal to one of the terminals on either the gen or the regulator. Generators are "dumb", they have to be told which direction they are supposed to charge. So when you polarize it, you are just telling the generator to create a charge when you spin this direction. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | DepsilonD - 2017-08-04 2:16 PM To polarize, you just use a jumper wire from the + terminal to one of the terminals on either the gen or the regulator. Generators are "dumb", they have to be told which direction they are supposed to charge. So when you polarize it, you are just telling the generator to create a charge when you spin this direction. So I am learning. From what I have read/watched (youtube), for negative ground, I need to very temporarily jumper between the ARM (armature) terminal (on the regulator) and the BAT (battery) terminal on the regulator. I think I will go from the + post on the battery to the bigger terminal on the generator which I believe is the armature terminal (the smaller one being the field coil terminal which I read that I should avoid). After lunch and after I confirm the wiring from the battery, generator, start solenoid and the voltage regulator is correct. | ||
DepsilonD |
Elite Veteran Posts: 792 Location: Buena Park, CA | That sounds right and I use the second method you listed. And it will spark so be forewarned! All you need to do is zap it really quick. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | 56D500boy - 2017-08-04 2:51 PM So I am learning. From what I have read/watched (youtube), for negative ground, I need to very temporarily jumper between the ARM (armature) terminal (on the regulator) and the BAT (battery) terminal on the regulator. I think I will go from the + post on the battery to the bigger terminal on the generator which I believe is the armature terminal (the smaller one being the field coil terminal which I read that I should avoid). After lunch and after I confirm the wiring from the battery, generator, start solenoid and the voltage regulator is correct. Used my Multimeter set on 200 ohms to check the wiring from the Generator ARM (big thick red wire) to the voltage regulator ARM (yup connected). Also checked that the smaller wire on the generator is connected to FIELD on the Voltage Regulator (yup). For fun, also checked for continuity between the (+) terminal on the battery and BAT on voltage regulator. Yup. All good. The regulator is an after-market ECHLIN (shown in the photo below) and it already shows and mentions that before starting the car, the ARM and BAT need to be very temporarily connected via a jumper wire. So I did that before starting the engine. Started the engine. No change at the Ammeter, still in discharge mode despite increasing the revs. So I turned off the engine and temporarily jumpered between the (+) post on the battery and the ARM terminal on the generator. Nice spark! Started the engine again. No change. Still in discharge mode. I guess I will have to bite the bullet at remove the generator and investigate it (and/or take it into the Alternator/Starter shop.) The PS pump complicates things somewhat but not seriously. Long weekend here so...Tuesday at the soonest. Edited by 56D500boy 2017-08-04 6:06 PM | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | run the engine and polarize the generator whit the engine on idle. otherwise the generator cannot be polarized..... | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | wizard - 2017-08-05 1:08 AM run the engine and polarize the generator whit the engine on idle. otherwise the generator cannot be polarized..... Hmm... the wording on the cover of the ECHLIN voltage regulator specifically says to polarize *before* starting the engine. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | I took separated the PS pump from the generator yesterday and removed the generator from the engine. I then took the generator and the regulator to another Auto Electric shop that was recommended to me (Brighouse Auto Electric in Richmond BC). Andy there opened up the generator and showed me where he thinks I have dead segments in the armature. He is recommending an NOS or rebuilt armature. The brushes were fine. Now I am hoping to find a NOS armature locally. One issue is the PS pump drive. I was thinking, if I am going be putting money into this generator, why not convert it to a hidden (in the case) alternator? But then the issue will be cost and,more importantly, the PS pump drive. Anybody converted a generator to an alternator and kept the PS pump Drive? | ||
DepsilonD |
Elite Veteran Posts: 792 Location: Buena Park, CA | Dave F, I've seen people add alternators to the passenger side and just use the original gen as "dummy spacer" to run the original pump. I have also seen folks swap to a more modern pump run it off the drivers side and add an alternator to the passenger side. Dave N. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | DepsilonD - 2017-08-11 3:29 PM Dave F, I've seen people add alternators to the passenger side and just use the original gen as "dummy spacer" to run the original pump. I have also seen folks swap to a more modern pump run it off the drivers side and add an alternator to the passenger side. Dave N. Yup. Those options are going to be Plans B and C. Plan A = get a new armature for this one. | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Polarising a generator does not require it to be running. Its quite opposite actually, if its running and has already started charging opposite to what you want it to, you will make a 24V short circuit when you try to repolarise it. If I do it with the genny still on the car, I slip the belt off, disconnect the wiring for the genny from the reg (saves the contacts if something goes wrong) and then I "motor" the genny. If it wont motor, the genny has problems and would need to come off If it motored, then it should be ok, but you still would want to look at the brushes to make sure there is plenty left on them Then, if all is good, with the wires still off the reg, start the engine and put a volt meter between the genny armature terminal and the genny case and make 100% sure it is putting out the voltage the right way, EG pos earth or neg earth, which ever way you wanted it to work (most US cars were neg earth, European stuff was pos earth, made it hard to fit radios to them, so it was quite common to swap the battery around and re polarise the genny) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | I've moved on beyond that possibility (which would have been difficult with the PS pump attached). The generator did "motor" at the shop but it didn't generate much if any. Bottomline, I am sending it out Monday for a rewind. Might be back Thursday or Friday and then back to the shop. (I'm stickhandling the sending and receiving to a) save myself some money and b) speed things up (I hope). I am disappointed that nobody makes a long shaft mini-alternator that would fit in my PS-drive generator casing. Sounds like a good project to me. | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Look at diesel engine alternators like early Nissan patrols or similar (theres heaps of them), they have a vacuum pump mounted to the rear of them that is driven by a splined shaft. I have not looked at how the ps pump is driven on the genny, but an adaptor system to go between the alternator and the pump would not be to hard to make is you own or have access to a lathe | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | ttotired - 2017-08-11 7:20 PM Look at diesel engine alternators like early Nissan patrols or similar (theres heaps of them), they have a vacuum pump mounted to the rear of them that is driven by a splined shaft. I have not looked at how the ps pump is driven on the genny, but an adaptor system to go between the alternator and the pump would not be to hard to make is you own or have access to a lathe This generator has a two pin PS pump drive that is attached to the end of the armature with a single bolt (oblong slot in the drive and oblong "pin" at the end of the armature shaft). And yes, if I had a metal lathe, I would design and make the required shaft that would permit the installation of a small alternator in the generator case, with an extension through the 6203 ball bearing to the PS drive. Seemingly easy peasy. Edited by 56D500boy 2017-08-11 9:11 PM (DaveForgiesGJC20_0FArmature_small.jpg) Attachments ---------------- DaveForgiesGJC20_0FArmature_small.jpg (236KB - 221 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Okay. Finally got the generator back from the Auto Electric shop late yesterday (the armature had been rewound at Romaine Electric in Kent WA). The shop told me that they had bench tested it and had adjusted the regulator to 14.0 V cold (room temp). So I started the install yesterday and finished it today (including the PS pump re-install). Started the engine (a few pumps on the throttle and a bit of cranking). Revved the engine to see the AMP meter move from - to +. Nope. (WTF!?) Tested a few things, e.g. continuity between the armature terminal on the generator to the "ARM" connector on the regulator, field to field, etc. All good. Measured voltage at the armature terminal. 0.9 V at idle up to 4.0 V with some throttle (my hand on the carb linkage). But not 14.0 V. Phoned the shop and they suggested that I had been over zealous in painting brackets, etc. and that, as a result, the generator isn't grounded. They suggested that I try a jumper wire between the generator case and something big and metal. I tried a few variations of that but the result was the same. (!!??) It is obviously something simple but I am missing it. Where would be a good location for a ground jumper on the generator? I can attach the other end to the battery (-) or the bolt where the battery (-) attaches to the block. Help an old guy recover his sanity. Edited by 56D500boy 2017-08-31 8:00 PM | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | UPDATE: Went back out and tested some more: 1. With my Radio Shack DMM set to 20V DC, I have 12.45 volts between the "BAT" terminal on the regulator and ground. Check. 2. Using my alligator jumper wires to extend the reach of the DMM, set on 200 ohms, I have continuity between the ends of the generator and the negative ground strap attached to the block and the long generator belt tightening bracket. (THEREFORE, I have ground). Check. 3. Same set up, I have continuity between the armature terminal on the generator and "ARM" on the regulator. Check. 4. I have continuity between the field terminal on the generator and "FLD" on the regulator. Check. 5. I used the jumper to briefly connect the "BAT" and "ARM" terminals on the regulator, as per the instructions on the ECHLIN regulator case. Things are polarized. Check. But yet, I am still not charging. My head hurts. WHAT am I missing?? On the plus side, after 3 weeks of not driving it, I did drive the car a bit and actually got deep into the four barrel. Big SUCKING sounds from that unsilenced air cleaner. Yikes! Edited by 56D500boy 2017-08-31 9:30 PM | ||
58coupe |
Expert Posts: 1740 Location: Alaska | It has been my experience that if a gen. will motor, it will also charge. You're overlooking the obvious, the regulator. Just because it is fairly new doesn't mean it cannot fail. You need to follow the FSM for testing the reg. I'm a little fuzzy but IIRC you briefly touch 12 volts to the reg. side of the gen. at idle ( disconnect wire to reg. first). | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | I tested the output of the generator at the Armature terminal = 0.9V at idle, 4.0 V if I rev the engine (hand on the carb linkage at the carb) so I know the generator is not GENERATING. What I am starting to conclude is the battery voltage is not getting from the FIELD terminal on the regulator to the FIELD terminal on the generator (there is continuity but probably no voltage). No voltage to the field coils = no generation. I think I will temporarily jump from the + battery post to the FIELD terminal on the generator. Should get something better and prove/disprove the FUBAR'd regulator theory (or not). < PAUSE WHILE I GO OUT TO THE GARAGE> Well that was a really bad idea. I'm not getting battery voltage at the generator field terminal but when I tried jumping from the battery to the generator field terminal I got a nice spark (so I backed off). Now I think I have reversed the polarity of the generator. I tried jumping from the BAT terminal on the regulator to the ARM terminal on the regulator (engine off) to re-polarize the generator but it didn't work. I'm getting negative voltage still. I need intervention before I really mess things up. But the shop that I have had some work done on the engine the oldest/best guy doesn't know generators so no help there. First thing tomorrow, I am going to repolarize the generator by jumping between the battery (+) and the ARMature terminal on the generator. And then phone my NOS guy to see if he has a regulator. | ||
Beltran |
Expert Posts: 1730 Location: Michigan | When you say your not charging.. at what RPM are you making this judgement? A generator does not charge at idle. It only will charge above say 1100 rpm. This is why we went to alternators. As the generator wears out this gets worse. I had a generator that would not positively charge the battery until it got above 1900 rpm. I took it apart, turned the stator? and cleaned up the surface where the brushes ran. Put in new brushes and it improved dramatically.. but never enough to charge the battery at idle while sitting at a light.. So at night, with your lights on, heater running and radio playing.. your draining your battery. Winter, night, city driving was a bitch on these old cars until alternators came along. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | 56D500boy - 2017-09-01 11:12 PM But the shop that I have had some work done on the engine the oldest/best guy doesn't know generators so no help there. First thing tomorrow, I am going to repolarize the generator by jumping between the battery (+) and the ARMature terminal on the generator. And then phone my NOS guy to see if he has a regulator. :) Well, that is what happened. Sort of. FIRST I phoned my NOS guy and got a New-in-box (NIB) Niehoff AL-166 (Marked as 1642 333 Mopar Number) 12 V voltage regulator before he took off for a week. Then we had visitors (relatives) for the long weekend), THEN I repolarized the generator with 12V from the battery to the Armature terminal on the generator and tried again. Positive voltage output but not enough. Then I stopped the engine, removed the (+) cable from the battery and removed the Echlin voltage regulator that came with the car and the generator shop had adjusted to 14 V (they said). I took the covers off both regulators and poked around with my multimeter (set on 200 ohms) and got similar readings for similar test points on each of the regulators. I decided that the Echlin looked more robust but that I had to go with the Niehoff because the Echlin wasn't working (for some reason). I cleaned the points on the NIB Niehoff and put the cover back on. Then I put the Niehoff regulator in. Had to remove the cover again to get enough clearance to tighten the three 3/8" head bolts that hold the regulator to the firewall. Then I put the cover back on (1/4" nut driver) and attached the Field, Armature and Battery harness wire connectors to the regulator (I re-checked the continuity between the ARM and FLD wires at the regulator and the generator and the voltage between the BAT terminal and ground - all good). Then I started the engine and gave it a little gas. Ammeter needle swung to the right. Yippee!! Can't say that the ammeter needle was rock steady but at least I had positive volts. I left the engine running and checked the voltage coming off the ARM terminal of the generator. 11.7 V or something at idle. Then I reached into the carburetor and gave it some increasing throttle. Voltage went into the 13's. I quit at about 13.7 Volts (not sure of the RPM). YAY!! Now on to the next can of worms. PS: I am not throwing the Echlin VR away just yet in case it was actually okay and the issue was something else. Edited by 56D500boy 2017-09-05 7:20 PM (VoltageRegulatorsEchlinOnLeftNiehoffAL166onRight.jpg) (NiehoffAL166VoltageRegulatorBox.jpg) (EchlinVoltageRegulatorDetail.jpg) (NiehoffAL166DetailShowingThePointSize.jpg) Attachments ---------------- VoltageRegulatorsEchlinOnLeftNiehoffAL166onRight.jpg (145KB - 184 downloads) NiehoffAL166VoltageRegulatorBox.jpg (107KB - 200 downloads) EchlinVoltageRegulatorDetail.jpg (104KB - 177 downloads) NiehoffAL166DetailShowingThePointSize.jpg (120KB - 208 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Took the old dear for a short spin. So happy to have + amps (and >12 V) again. Ammeter is much steadier under power and load (e.g. headlights on). Definitely a better situation that a constantly discharging battery. That said my new Lithium Ion jumper pack is likely never to leave the car again (it's tucked under the drivers side of the front seat for now). Speaking of headlights. Mine say "GE Halogen" and I can see what appears to be a separate bulb inside. Can that be? They are very white (now that I have volts). | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | 56D500boy - 2017-09-05 8:52 PM Speaking of headlights. Mine say "GE Halogen" and I can see what appears to be a separate bulb inside. Can that be? They are very white (now that I have volts). :) Just checked. They say "General Electric, Sealed Beam, Halogen, USA DOT and 2D1" so, I have to guess they are these: | ||
Beltran |
Expert Posts: 1730 Location: Michigan | They make halogen replacements that are much better than the originals. I have them in my car too. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | I forgot to post a photo of my PS pump-driving 56 Dodge 30 Amp generator. They stripped the paint off the end plates, not sure if that is the way they came from the factory or not. Either way, I think that it locks good. Seems to be charging well which was the whole point of the exercise. Before: And After: Edited by 56D500boy 2017-09-14 3:00 PM (DForgiesRebuiltPSDriving56DodgeGenerator.jpg) Attachments ---------------- DForgiesRebuiltPSDriving56DodgeGenerator.jpg (174KB - 172 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | 56D500boy - 2017-09-14 2:58 PM I forgot to post a photo of my PS pump-driving 56 Dodge 30 Amp generator. They stripped the paint off the end plates, not sure if that is the way they came from the factory or not. Either way, I think that it looks good. Seems to be charging well which was the whole point of the exercise. It was a nice day out here in Vancouver BC (area). +9 C and sunny and dry so I started the old girl and got her out of the garage and into the sun. I let it run on fast(ish) idle and monitored the voltage at the battery and at the generator. With the amp gauge showing slightly positive, I was getting about 14.05 V at the output post on the generator and about 13.92 V at the battery. As the car warmed up (and I presume the battery charged a bit), the voltage at the generator went down to about 13.96 V and the voltage at the battery to around 13.82 V. After a short period like that, I knocked it off fast idle and took it for a quick spin around the block (and I mean the block and short). I don't have any seats in it, just a plastic milk crate and a foam pad for my butt. Nothing to see here officer. Edited by 56D500boy 2018-01-15 7:37 PM | ||
RUSTORICHES |
Extreme Veteran Posts: 494 Location: Alberta | Ah yes Dave what you're saying is "you made a milk crate run" -31F still here today and nothing run…………LOL | ||
