Anybody know that the PS pump return hose gasket looks like?
Posted 2017-07-19 4:55 PM (#544426)
Subject: Anybody know that the PS pump return hose gasket looks like?
500020002000500100100100100
GASKET 19-58-20 = PN 1485 894 But I don't know what it looks like. Mine is leaking at the non-pressure return hose adapter (19-58-15) and I would like to have one in hand before I remove the hose (and adapter).
Edited by 56D500boy 2017-07-19 4:57 PM
(55-56PowerSteeringPumpDiagram.jpg)
Attachments 55-56PowerSteeringPumpDiagram.jpg (114KB - 175 downloads)
DepsilonD
Posted 2017-07-21 2:10 PM (#544542 - in reply to #544426)
Subject: Re: Anybody know that the PS pump return hose gasket looks like?
500100100252525
Dave, went looking for my pump on the shelf and it has gone missing. Sorry.
Posted 2017-07-21 2:19 PM (#544543 - in reply to #544542)
DepsilonD - 2017-07-21 2:10 PM Dave, went looking for my pump on the shelf and it has gone missing. Sorry.
Thanks for trying.
Anybody else?
hemidenis
Posted 2017-07-21 3:59 PM (#544550 - in reply to #544426)
20001000500100100100252525
the gasket it should be only a copper washer. Copper is an amazing material you can heat the old washer in an electric stove and the material fix itself enough to be re-used.
You can also use plumber's seal to put it on the thread before assembly and it will not leak..
rebel
Posted 2017-07-22 10:28 AM (#544605 - in reply to #544550)
The sealing washer is copper and is 3/4" ID x 1" OD and is .030 thick. Most good parts houses that have oil pan drain plug assortments and copper gaskets should be able to supply this washer. It won't hurt if the washer is a little thicker.
Bob
(56 Power steering return hose fitting seal 001.JPG)
(56 Power steering return hose fitting seal 002.JPG)
Attachments 56 Power steering return hose fitting seal 001.JPG (66KB - 159 downloads)
Attachments 56 Power steering return hose fitting seal 002.JPG (58KB - 160 downloads)
Posted 2017-07-22 11:01 AM (#544607 - in reply to #544605)
hemidenis - 2017-07-21 3:59 PM The gasket it should be only a copper washer. Copper is an amazing material you can heat the old washer in an electric stove and the material fix itself enough to be re-used.
rebel - 2017-07-22 10:28 AM The sealing washer is copper and is 3/4" ID x 1" OD and is .030 thick. Most good parts houses that have oil pan drain plug assortments and copper gaskets should be able to supply this washer. It won't hurt if the washer is a little thicker. Bob
Thank you both, gentlemen. I will seek out said washer.
Posted 2017-07-22 2:27 PM (#544621 - in reply to #544550)
20001000500100100252525
I agree with Denis, copper washers never die. Just anneal it and reuse.
Have you tried simply tightening the fitting?
Posted 2017-07-22 2:41 PM (#544622 - in reply to #544621)
57chizler - 2017-07-22 2:27 PM
Oh gosh!! Thanks. Why didn't *I* think of that?
DUH.
It's tightened beyond belief and yet, it still leaks.
But thanks for the suggestion.
Edited by 56D500boy 2017-07-22 3:08 PM
