spark plug wires Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Fellow Forward Lookers, I went to my local NAPA store and ordered up all the usual tune-up stuff...plugs wires, cap, rotor, points etc....I recently acquired the spark plug covers that bolt onto the valve covers....my newly purchased wire set does not appear to be long enough to fit under the covers...if I run it without the covers the wires work, car runs, all is good...Is there a special wire set just for that purpose that is longer? Should I buy the parts and make my own? Any help would be appreciated...57 New Yorker,,,392 Hemi Thanks, billy | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | Generic Accel wires are long enough. There also purpose made (expensive) wires at Hot heads. Atlas Obsolete makes repro. | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Thanks Mopar1 / George.....will look into those alternatives... billy | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | You will need a 25 ft roll if you make your own and you really need to buy the proper crimping tool. If you want to use 8mm wire I have plenty of high quality black and dk blue wire available. | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Ok fellow hemi owners, how do you know if the spark plug boot is on the spark plug with it buried so far down in??? Is there a special boot install tool? My fat fingers wont go down far enough to tell if the boot is all the way on... Thanks for the offer Wayfarer...I went with the Accel wires from the local Auto store...any help would be appreciated.. billy | ||
Expert 5K+ Posts: 9915 Location: Lower Mainland BC | The proper old school hemi wires have long ceramic "boots" that fitted over the wire and the spark plug end. You used that to push the spark plug wire on and later to extract the wire. The repros, e.g. from MoparMall, use plastic tubes. The tubes show in the photo and diagram below: Edited by 56D500boy 2017-07-08 9:34 PM (EarlyHemiCrossSection_small.jpg) Attachments ---------------- EarlyHemiCrossSection_small.jpg (159KB - 139 downloads) | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | I bought a spark plug wire puller & opened up the hole a little. I use it to push the wire onto the plug. This is with straight boot Accel wires. Gently pull on the wire to see if it's on. Edited by Mopar1 2017-07-09 8:50 AM | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Thanks Dave and George,,,,I bought the Accel wire kit, but does not look like its going to be much fun trying to get the Accel boot down that tube...we'll see how it goes.. billy | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | You can use some di-electric grease or silicon grease on the inside of the boot to help it slide on. | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Thanks Gary... | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | Mopar Performance, and others probably, make wire pullers, as I mentioned above. makes pushing the wires on easy! | ||
rebel |
Extreme Veteran Posts: 309 Location: Western Colorado | Billy, The wires I used for my 58 N/Y'er, with the 392, came from Taylor cable products. The set fit perfectly. My set was p/n #075089. Their website is www.taylorvertex.com. Not cheap but the best I could find anywhere. Bob | ||
Expert 5K+ Posts: 7411 Location: northern germany | when i got my car i changed stock to a set of mopar performance wires, they failed one by one. later, about 20 years ago, i purchased universal 8mm, cut to lenght, taylor wires, black with 180° boots. couldn't be happier and they still look like new. requires a crimping tool, but if you want a perfect fitting set, i think you have to cut it to lenghts yourself. | ||
Expert 5K+ Posts: 9692 Location: So. Cal | rebel - 2017-07-12 11:29 AM Billy, The wires I used for my 58 N/Y'er, with the 392, came from Taylor cable products. The set fit perfectly. My set was p/n #075089. Their website is www.taylorvertex.com. Not cheap but the best I could find anywhere. Bob I agree. I bought the Taylor hemi wires too and I really like them. | ||
51coronet |
Extreme Veteran Posts: 360 | The original solid core wires don't have a high fail rate since its basically stranded wire inside the jacket unlike modern carbon type wires. If radio noise isn't an issue I see the original type wires on ebay all the time. | ||
BigBlockMopar |
Expert Posts: 3575 Location: Netherlands | It's usually the insulating jacket around the core that starts failing after a number of years. Then spark-energy finds its way through the covering to nearby/touching metal and cause misfires. 8mm wires have a .5mm of extra insulation around the core wire which can extend their lives greatly. | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | 8mm is good stuff but, on a couple of customers projects, I found that 8mm wire gets a bit crowded at the back of the wire cover. Some cover have a bit more interior space than others; 7mm fits all that I have worked with. | ||
