Searching for a 4 terminal 1692 659 Starter Solenoid
Posted 2017-05-31 5:59 PM (#541289)
Subject: Searching for a 4 terminal 1692 659 Starter Solenoid
500020002000500100100100100
This is for my 56 Dodge 12V V8 automatic (neutral interlock switch). But was also used on 56-58 Plymouths, 56-58 Dodges and 57-58 Desotos according to the info that I have.
Back in the day it crossed to an SAE-4002, four lug, grounded, 12V starter solenoid. The issue is minor but important: The holes in the mounting bracket need to be 2 9/16" C to C, not the much easier to find 2 13/64" C to C varieties that I currently (pun not intended) have.
Edited by 56D500boy 2017-05-31 6:00 PM
Posted 2017-06-01 2:29 PM (#541344 - in reply to #541289)
Subject: RE: Searching for a 4 terminal 1692 659 Starter Solenoid
20001000500100100252525
If you're gonna use a NSS, you want an insulated solenoid not a grounded one.
https://www.ebay.com/p/VINTAGE-AUTOLITE-STARTER-SOLENOID-15-6-SAE-40...
Edited by 57chizler 2017-06-01 2:31 PM
Posted 2017-06-01 3:39 PM (#541351 - in reply to #541344)
57chizler - 2017-06-01 2:29 PM If you're gonna use a NSS, you want an insulated solenoid not a grounded one.
Thanks. You're right. I guess I meant one with an external ground wire, i.e. lug for the neutral safety switch.
I kept looking last night and found and bought this:
Cole Hersee - Insulated Intermittent Duty SPST Solenoid 12V - 24023
(It is supposed to have the requisite 2 9/16" mounting hole spacing)
Time will tell.
Posted 2017-06-05 3:26 PM (#541569 - in reply to #541351)
56D500boy - 2017-06-01 3:39 PM
Time will tell.
Just picked that Cole Hersee 24023 up this AM. Definitely wide enough ears/feet. It will bolt on properly to my 56 Dodge drivers side fender liner and make me happy (okay, less grumpy).
Edited by 56D500boy 2017-06-05 3:27 PM
