57 Royal with 392 project Jump to page : < 1 2 3 4 5 6 7 8 9 10 11 > Now viewing page 6 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 5006 | the trunk/quarters were not supposed to get water though, i understand the window area drains(as long as dirt doesnt clog the drain area). | ||
Expert 5K+ Posts: 5006 | spent hours upon hours to get the door gaps perfect... uhg... I could slightly push the top back just a couple thousands... I got it this close and was like finally. This job is a fight. These doors didnt come from this car and I welded new rockers. I learned you should do this before you paint the doors You should have everything aligned and marked/pinned. I knew it, just didnt do it
Edited by mikes2nd 2019-07-01 12:59 AM (door_gap.jpg) Attachments ---------------- door_gap.jpg (238KB - 394 downloads) | ||
Expert 5K+ Posts: 5006 | by the way holy hell is door gap horrible on 50's cars.. Went to a car show, the Chevys i can put my hand in those door gaps. I saw one 57 on barret jackson the darn trunk had a half inch gap! still sold for 52k! | ||
Expert 5K+ Posts: 7403 Location: northern germany | You should have seen my 60, early production, 1rst year for unibody! Unfortunately for some reason, when I was a teenager, I wanted to put it back together just like it came from the factory. Over the years I have been slowly removing my mistakes, still do. Of course this is lots of work after painting, as most parts just don't fit without modification. | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Don't sweat it too much, Mike. It's going to look great. When I found it, my Chrysler had huge gaps at the bottoms of the doors - about 5/8" on the drivers side with the door shut, and 1/2" on the pass side. And the wear marks, door/quarter glass alignment, and weatherstrip indicated it had pretty much always been that way. Crazy! I worked it over HARD to get them to line up better, but even with a lot of massaging to get them close, there is still a noticeable (to me!) gap at the bottom of each door. I spent hours carefully slotting the door hinge holes and striker holes to allow for extra adjustment range, and slightly reshaped the upper edge of both strikers to allow the doors to properly latch when the door was in position. I stopped adjusting when it became apparent there was a mismatch in the contour of the quarter panel to the contour of the door skin itself. I aligned the doors so the trim lines up straight and everything else around it is kinda wonky - but it's not going to get any better without significant cutting and welding. The car gets compliments on how "straight" it is, so it's pretty close. If I was going to build the car for display under bright lights it would be worth it to go that extra (hundred) miles to get perfect paint stick gaps.... but this is a real car. Fortunately the car is black, so uneven gaps aren't as noticeable on it as on, say, a light pastel color... Edited by 57burb 2019-07-01 3:35 PM (1.jpg) (2.jpg) Attachments ---------------- 1.jpg (91KB - 442 downloads) 2.jpg (171KB - 404 downloads) | ||
Expert 5K+ Posts: 5006 | other side perfect now, had to shim the front hinges at the firewall. test fitting fenders to make sure the rockers are good. I will also put the fenders on to guide coat the lower fenders(they twist on) so you cant get a good idea off the car that they are "flat" or not. Ill wet check them also. Edited by mikes2nd 2019-07-01 10:49 PM (passdoorgap.jpg) (57side.jpg) (front57.jpg) Attachments ---------------- passdoorgap.jpg (291KB - 390 downloads) 57side.jpg (249KB - 403 downloads) front57.jpg (314KB - 403 downloads) | ||
Expert 5K+ Posts: 5006 | test fit hood (testfithood.jpg) Attachments ---------------- testfithood.jpg (241KB - 399 downloads) | ||
Expert 5K+ Posts: 5006 | heater clean up... i have one heater box with the model 705 upside down... weird... (heatercore.jpg) (heaterbox.jpg) Attachments ---------------- heatercore.jpg (245KB - 401 downloads) heaterbox.jpg (238KB - 403 downloads) | ||
Expert 5K+ Posts: 9679 Location: So. Cal | That is odd. Never seen that before. Edit: Actually, that is right side up. You're just looking at it wrong. Edited by Powerflite 2019-07-13 12:26 AM | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | I've seen an number of them upside down especially the A/C ones. Greg | ||
Expert 5K+ Posts: 5006 | wait left hand drive? I am repairing this one a bit, its nice except it had a crack in the front. I bet these have asbestos in them? (huhWrongway.jpg) Attachments ---------------- huhWrongway.jpg (167KB - 403 downloads) | ||
Expert 5K+ Posts: 5006 | Wet checking fenders before i paint... and the booth is up again... This is the temporary booth i put up to paint the smaller things. (wetcheck.jpg) (boothUpAgain.jpg) Attachments ---------------- wetcheck.jpg (237KB - 404 downloads) boothUpAgain.jpg (214KB - 426 downloads) | ||
Expert 5K+ Posts: 5006 | fender painted (67220292_10219578023139760_5626982404204789760_o.jpg) Attachments ---------------- 67220292_10219578023139760_5626982404204789760_o.jpg (145KB - 386 downloads) | ||
Expert 5K+ Posts: 9679 Location: So. Cal | How do you install and align it without chipping the paint? I want to paint my fenders off the car as well, because it's easier to paint, but I am worried about installation. | ||
Expert 5K+ Posts: 5006 | I use a lot of tape, the yellow 3m stuff. Ill put a lot down at the bottom and all the edges. Getting ready to paint the other fender and other bits and pieces. I have to paint the 57 and 58 stuff, I have some 59 stuff to paint but havent got the fenders yet. I'm going to color match the valence and headlight surrounds I think and obviously hood hinges. (PaintParts.jpg) Attachments ---------------- PaintParts.jpg (247KB - 414 downloads) | ||
Expert 5K+ Posts: 5006 | better final pic of what it will look like. Im painting the headlight surrounds and the lower valence to match. (58WillowBlack.MatchingFront.jpg) Attachments ---------------- 58WillowBlack.MatchingFront.jpg (332KB - 382 downloads) | ||
Expert 5K+ Posts: 5006 | it so hot i cant paint so back to the engine bay... playing with fitment of power steering and alternator... (hemiAccessories.jpg) Attachments ---------------- hemiAccessories.jpg (234KB - 405 downloads) | ||
Expert 5K+ Posts: 5006 | other fender done and one side of hood hinges/front headlight covers... Also painted underneath trunk lid. Im going for only a white roof... (otherfender.jpg) Attachments ---------------- otherfender.jpg (228KB - 390 downloads) | ||
Expert 5K+ Posts: 5006 | Pulleys done pretty much, and brass nuts on the valve covers... ack... I left room for AC if I want to down the road but it will be kind of up top.
This alternator is a beast... its a GM version though, when i had it tested, the guy at the store didnt think they made alternators that put out 240 amps.. https://www.jegs.com/i/Flaming-River/898/FR1171/10002/-1
had to use that large angle bracket though... Edited by mikes2nd 2019-07-29 3:47 AM (pulleys4.jpg) (valvecover.jpg) Attachments ---------------- pulleys4.jpg (243KB - 379 downloads) valvecover.jpg (243KB - 411 downloads) | ||
big m |
Expert 5K+ Posts: 7808 Location: Williams California | Looking great, Mike!! | ||
Expert 5K+ Posts: 5006 | hood springs painted... (hinges.jpg) Attachments ---------------- hinges.jpg (231KB - 375 downloads) | ||
Expert 5K+ Posts: 5006 | trunk painted! holy crap im going to actually have the body done soon... had to order another gallon of paint. (trunkdrying.jpg) Attachments ---------------- trunkdrying.jpg (243KB - 361 downloads) | ||
Brushwolf |
Veteran Posts: 292 Location: Twin Cities MN | Really enjoyed this thread. I have a 57 Custom Royal with original hemi and it came with 58 trim in place of 57 CRL trim. Like you I kept changing my mind on color, original equipment and trim or add factory options like PS and brakes. Use the nice 58 trim or find 57 replacements? So, I now have both 57 and 58 trim (57 cost almost what I paid for the car and took several years to find it all..). Have PS and PB complete original setups (car was manual steering and brakes). A spare dash, several different PS pumps, Got a 57 Firesweep that has a good spare 325 poly block, an air cooled unmolested transmission, complete good frame, much better right side fender (same except lower front section), a couple different later liquid cooled cast iron torqueflights, a 62? aluminum torqueflight, and more. Plus many Ebay buys (gold hood letters, D500 trunk medallions, numerous door latches, gauges, front bumpers and teeth, etc. Interesting that 57 Chev body mounts will work. I had bought a couple Dodge front floor pan years ago, but didn't think they were good enough to use, so have since bought a bead roller and sheet metal brake to make my own if I dont find something better. Recently did front floors in a 59 TBird and didn't like those reproductions either, so made my own from 18 gauge. The Dodge floor pans are more complex though.. Where did you get your floor pans from? Thanks, Mike | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | Real steel Replacements make a good floor pan. https://b-m.facebook.com/RealSteelReplacments/ (RSR.jpg) Attachments ---------------- RSR.jpg (15KB - 354 downloads) | ||
Expert 5K+ Posts: 5006 | i got mine from the guy in Georgia, they are nice and thick, and they are rounded on the edges instead of flat. So more solid. Not sure the guy still makes them, he is retired but they were 400$ His name is Bob, if you want a set send me an PM and Ill send you his email. | ||
Brushwolf |
Veteran Posts: 292 Location: Twin Cities MN | Thanks, Had not heard of them before and dont use Facebook, but sent an email to them requesting info. Haven't been on the site much due to other issues since back when Neil was the most prolific poster and bought a bunch of motor parts from him. These floor and trunk pans look like pretty good and would save me a lot of time fabricating parts. Mike | ||
Brushwolf |
Veteran Posts: 292 Location: Twin Cities MN | PM sent.. Do you happen to have a kit number or listing description for the 57 Chev body mounts as well? Thanks, Mike | ||
Expert 5K+ Posts: 5006 | Here is the one i bought. https://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_id=114&ipn=i... | ||
Expert 5K+ Posts: 5006 | firewall "flapper" 58 "no engine bay fumes" fumes version.... its on a piece of stainless steel with two holes drilled. Vans sells the flappers... (firewalldrain.jpg) Attachments ---------------- firewalldrain.jpg (233KB - 363 downloads) | ||
Expert 5K+ Posts: 5006 | working on sound proofing... and still figuring out how the whole dash goes together. Starting looking at how to map the wiring to my wiring harness. (firewallinsulate.jpg) Attachments ---------------- firewallinsulate.jpg (248KB - 375 downloads) | ||
Expert 5K+ Posts: 5006 | put the plugs in the hemi, chagned the oil filter adapter, started roughing in the quarter panels for final.. this was the first sanding pass. wet checked. (wetcheck.jpg) Attachments ---------------- wetcheck.jpg (247KB - 346 downloads) | ||
Expert 5K+ Posts: 5006 | getting quarter panels finalized (quarterpanelG2.jpg) Attachments ---------------- quarterpanelG2.jpg (308KB - 359 downloads) | ||
Expert 5K+ Posts: 5006 | painted fins... getting real close... (finspainted.jpg) Attachments ---------------- finspainted.jpg (349KB - 353 downloads) | ||
Expert 5K+ Posts: 9679 Location: So. Cal | Really nice. Is the bottom going to be white? | ||
Expert 5K+ Posts: 5006 | no all one color, its gonna be a 57 regal lancer and a 59 :) only the roof will be white this year... if i dont like it ill paint the roof green next year i will be wrapping the fins and the regal trim in black. carbon fiber? copper? iridescent black/green? i am ordering samples now. i ordered this. You can change the fin/trim color. I can also wrap the roof if i want. Edited by mikes2nd 2019-08-30 7:02 PM (irridescentgreen.jpg) Attachments ---------------- irridescentgreen.jpg (125KB - 350 downloads) | ||
Expert 5K+ Posts: 5006 | painting in the driveway for Dummies... https://www.youtube.com/watch?v=kJuMyAS7tZA | ||
Expert 5K+ Posts: 5006 | The eastwood paint sucks compared to the TCP. Left the gun with the same settings. This stuff shoots like glue but it will buff out to perfection im sure. Dries fast but ididnt flow. 4 coats of white on the roof. It will probably get wrapped though. The black and green flip flop wrap is awesome, turns emerald green metallic in the sun, black otherwise. Ill do a video on the wrap samples.
Edited by mikes2nd 2019-09-09 9:13 AM (roof.jpg) Attachments ---------------- roof.jpg (247KB - 337 downloads) | ||
Expert 5K+ Posts: 5006 | test fitting again!!! (testfitting.jpg) Attachments ---------------- testfitting.jpg (283KB - 358 downloads) | ||
Expert 5K+ Posts: 5006 | Checking out wrap colors https://youtu.be/Yd_GSE4Bd5I | ||
Expert 5K+ Posts: 5006 | bought some temp tires sits level now (tire.jpg) Attachments ---------------- tire.jpg (239KB - 329 downloads) | ||
Expert 5K+ Posts: 5006 | one more final featherfill paint coat (primerfin1.jpg) (primerfin2.jpg) Attachments ---------------- primerfin1.jpg (324KB - 332 downloads) primerfin2.jpg (357KB - 325 downloads) | ||
Expert 5K+ Posts: 5006 | reshot the passenger fin... now its just quarters and rockers left... thursday is my last day to shoot i think.. Ill get them both done then I hope, but I can assemble the car now over fall/winter i guess. Need to have the 59 parts sandblasted and epoxy primered. https://youtu.be/GzWgNMXoOaI (finPaint.jpg) Attachments ---------------- finPaint.jpg (242KB - 314 downloads) | ||
Expert 5K+ Posts: 5006 | one final side to paint... uhg (quarterpaint.jpg) Attachments ---------------- quarterpaint.jpg (164KB - 342 downloads) | ||
Expert 5K+ Posts: 9910 Location: Lower Mainland BC | mikes2nd - 2019-07-29 6:41 PM Hood springs painted... Looks good. a) Did you stretch them to paint them? b) How? c) How did you get them back on? (I want to paint my 56 Dodge Springs (red)) | ||
Expert 5K+ Posts: 5006 | http://www.forwardlook.net/forums/forums/thread-view.asp?tid=67642&... you forgot this thread? yes, i used a floor jack, just pushed them on with a small pry bar | ||
Expert 5K+ Posts: 9910 Location: Lower Mainland BC | mikes2nd - 2019-10-10 1:34 AM you forgot this thread? yes, i used a floor jack, just pushed them on with a small pry bar Sorry, I just didn't remember that it was you that used the floor jack. Must find my spare set of springs and give it a go with my jack. Thanks. (Not sure about getting them on by prying) | ||
Expert 5K+ Posts: 9679 Location: So. Cal | I haven't noticed any difference in how it looks if you paint them sprung or unsprung, so I wouldn't put too much effort into it. | ||
Expert 5K+ Posts: 5006 | its doesn't show much... but you want them fully coated. when i pried them on, i used a rubber coated bar. You cant stop the springs from chipping off where they contact the hinge though unless you rubber coat or so something. maybe plastidip them? or put rubber slip ons over the hook end? that would be a nice mod I was able to use the cheap harbor freight jack since it had a bolt right there. today is my last day to paint it looks like 75 degrees in ohio... wish me luck. | ||
Expert 5K+ Posts: 5006 | I think i may need to reshoot the drivers side, i see a imperfection i dont like... Passenger side came out great. (quarter.jpg) Attachments ---------------- quarter.jpg (211KB - 316 downloads) | ||
Expert 5K+ Posts: 5006 | hah finally rims all the way around... (siderims.jpg) (back57.jpg) Attachments ---------------- siderims.jpg (239KB - 307 downloads) back57.jpg (443KB - 320 downloads) | ||
