Location: Houston | Another member and I have been discussing the full size 126" WB frames.
Are they all the same (convertibles not included)?
Would a frame from a 4 door sedan be the same as a 2 dr HT? Would a New Yorker 4 door be a good donor frame for a 300?
I've read in the past where others here say they are the same but thought I'd ask again. |
Location: Under the X in Texas | On Chrysler /DeSoto, the rear leaf spring length was changed from '57-58 so the rear hangars are repositioned at least.
Location: So. Cal | I believe your question is more in reference to Sedan vs. Hardtop. I don't know the answer, but I suspect that the differences, if any, are very minor. I have a 57 sedan frame sitting in my yard that I could take a look at and see how different it is from my 57 hardtops. I will probably get to it over the weekend. |
Location: Under the X in Texas | There is some difference between sedan and hardtop transmission crossmembers. Been too long to recall what that difference is.
Checked the 1957 and 1958 parts books and in both years all sedans and hardtops shared the same frames, with the exception of Imperials. Convertible frames were different as were wagon.
For 1957 American built (except convertibles and wagons) -
P30, D64 - 1734 571
P31, D65 - 1734 572
D72 - 1734 573
D66, D67 - 1734 574
S27 - 1734 575
S25, S26, C75, C76 - 1675 804
For 1958 American built (except convertibles and wagons) -
P1, E1, F1 - 1829 963
P2, E2, F2 - 1829 948
D1 - 1829 571
D2, D3, S2 - 1829 750
S2, S3 - 1829 953
C1 - 1820 311
C2, C3 - 1829 311
For 1957 Canadian built (except wagons) -
P30, D64 - 1820 290
P31, D65 - 1734 572
D67-2 - 1734 574
C75-2 - 1675 804
For 1958 Canadian built - (except wagons) -
P1, E1, F1 - 1820 290
D3 - 1820 953
S2, C2 - 1829 952 (except the serial numbers below)
S2, C2 - 1675 804 (used on serial numbers below)
LS2W-1001 to LS2W-1002; LC2W-1001 to LC2W-1002; LC2W-1732 to LC2W-2058
No convertibles were built in Canada.
Location: Alaska | Are you wanting to know if they are the same or if they will interchange? 57 and 58 are not the same as you can see by the above part #s but will interchange according to my Hollander by changing the #3 body hold down brackets and rear spring rear hangers. |
Location: Houston | I have a 4dr 58 Frame that another member here might want for a 57 2DR HT. Just trying to understand if it would work. Thanks! |
