1956 plymouth-what color should door jambs be on a 2 tone car?
jerrybev
Posted 2017-03-07 8:00 PM (#535395)
Subject: 1956 plymouth-what color should door jambs be on a 2 tone car?
500100252525
hi
I have a 56 plymouth that is white and seafoam green. What color should the door jambs be panted to be correct color? This car started as a white car, and then seafoam was added either at the factory or later.
tthankyou for your time,
Jerry Whitfield
Winston salem NC
Posted 2017-03-07 9:35 PM (#535409 - in reply to #535395)
Subject: RE: 1956 plymouth-what color should door jambs be on a 2 tone car?
500020002000500100100100100
jerrybev - 2017-03-07 8:00 PM
hi I have a 56 plymouth that is white and seafoam green. What color should the door jambs be panted to be correct color? This car started as a white car, and then seafoam was added either at the factory or later.
tthankyou for your time, Jerry Whitfield Winston salem NC
Not sure about the order of painting but according to these photos the door jambs might be two tone too, at least on a Belvedere (I stand to be corrected).
REFERENCE: http://www.allpar.com/model/belvedere.html
Edited by 56D500boy 2017-03-07 10:35 PM
Posted 2017-03-07 11:07 PM (#535416 - in reply to #535409)
Made me go check what was up with my 56 Dodge door jambs.
Three tone car:
The firewall is the darker metallic (Royal poly) blue.
(Those ratty D500 hemi valve covers are one of the next projects).
And the door jambs are mostly the dark blue too (just a bit at the bottom by the rocker panels is the light (Wedgewood) blue) (at least on the rear door)
Ends of the doors are the darker blue
Probably didn't help you but it is more info.
Posted 2017-03-07 11:14 PM (#535417 - in reply to #535416)
To quote the Dude, "More information has come to light"
Posted 2017-03-08 1:38 AM (#535426 - in reply to #535417)
56D500boy - 2017-03-07 11:14 PM
Even more (found these in my stash of photos). 55 Custom Royal 2dr (hardtop)
(55CustomRoyalLancerDoorJambPaintChange.jpg)
(55CustomRoyalLancerDoorJambPaintChange_2.jpg)
Attachments 55CustomRoyalLancerDoorJambPaintChange.jpg (53KB - 103 downloads)
Attachments 55CustomRoyalLancerDoorJambPaintChange_2.jpg (50KB - 105 downloads)
