decode 1956 plymouth data trim plate
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
jerrybev
Posted 2017-03-07 7:55 PM (#535392)
Subject: decode 1956 plymouth data trim plate
500100252525
hi
much of the data trim plate is rusted and not readable. However, I found this much info I hope you can decode for me:
1st letter on left side of data plate under 6G is a 1
2nd letter on left side of data trim plate under M6 is a 1
M7 I cant read
4th letter under M8 is a 3
5th letter under heading of M9 is an 8.
Concerning paint colors, my car is seafoam green and white. Under the seafoam is white. Does anyone know if Plymouth Division painted all the cars the base color and then sent the cars to another paint line to have the two tone (2nd color) added?
thank you for your time,
jerry Whitfield
Winston Salem,NC
GaryS
Posted 2017-03-07 8:18 PM (#535400 - in reply to #535392)
Subject: Re: decode 1956 plymouth data trim plate
1000100100
I can't help you with the decoding, but the '56 yellow and white Belvedere my dad bought new had yellow over white, so at least some came that way from the factory.
jerrybev
Posted 2017-03-07 9:03 PM (#535405 - in reply to #535400)
500100252525
thank you
Posted 2017-03-07 9:39 PM (#535410 - in reply to #535392)
Subject: RE: decode 1956 plymouth data trim plate
500020002000500100100100100
jerrybev - 2017-03-07 7:55 PM hi
jerry Whitfield Winston Salem,NC
Try doing a rubbing of the plate with white paper and a soft pencil turned on its side. Then post a photo of the rubbing so we can see what's what. Eg. Paint code.
Photo of the car would help.
Here is a post that I did with hints on how to post photos:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64340&...
Edited by 56D500boy 2017-03-07 9:42 PM
