1959 Dodge Fin Piece Removal
texas383
Posted 2017-01-23 11:11 AM (#532111)
Subject: 1959 Dodge Fin Piece Removal
I'm trying to remove the rear fin piece. I've removed the 3 screws that hold it in place but can't get the piece to come off. I don't want to pry and mess something else. Should it come off easily after the 3 screws are removed or is there something else?
(Untitled-1.jpg)
Attachments Untitled-1.jpg (87KB - 115 downloads)
Rebels-59
Posted 2017-01-23 1:07 PM (#532121 - in reply to #532111)
Subject: Re: 1959 Dodge Fin Piece Removal
500050002000500
You have to remove the Fin Tip, As there is a Nut below it that also hold that Under Fin Trim panel on.. Unfortunately you have to remove the longer chrome trim that meets the Fin Tip first, as there is a screw under the trim each side that holds the Fin Tip on...
That Under Fin Trim is the first part of chrome to be fitted, so last to be removed, (If that makes sense to you)
Clive
texas383
Posted 2017-01-23 2:32 PM (#532133 - in reply to #532111)
Subject: RE: 1959 Dodge Fin Piece Removal
It makes perfect sense! Thanks!!
