1957 desoto adventurer spark plugs 345 Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
57swept |
Regular Posts: 66 | My dad just picked up a 57 adventurer. We did some research on plugs and read that the auto lite 65 would be equivalent to the original ar-32 that the manual recommends . These plugs have the 3/4" reach as opposed to the 3/8" reach . I put a few plugs in and there seems to be play with the tube and the plug , almost as if the 3/8" reach would have been correct . Can anyone chime in here on this . Did I get wrong info for the plugs? It's a 345 hemi | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | Autolite 85 Copper Resistor Spark Plug 345cid;OE Style; Replaces 75 .035 Gap 75 Copper Non-Resistor Spark Plug 345cid; .035 Gap Champion RJ10Y RJ11Y RJ12y | ||
57swept |
Regular Posts: 66 | Thanks | ||
57swept |
Regular Posts: 66 | Anyone know where we can get factory style wires? I see a place called mopar mall sells the plug wires new and they look like the originals . Anyone have experience with them? Edited by 57swept 2017-01-22 6:25 PM | ||
mstrug |
Expert 5K+ Posts: 6504 Location: Newark, Texas (Fort Worth) | http://www.ebay.com/itm/NOS-MoPar-1955-56-57-58-Chrysler-HEMI-Spark... | ||
57swept |
Regular Posts: 66 | Thanks but that's a little more than I want to spend . | ||
Chrispy |
Extreme Veteran Posts: 520 Location: Colorado Springs, Colorado | You can get close if you roll your own with 7mm black wire, it will let you run the ceramic factory insulators, you just have to crimp it all together. I did this long ago fro my 392, got the kit from napa. | ||
57swept |
Regular Posts: 66 | Thanks for the info Chrispy | ||
57desoto |
Expert Posts: 1488 Location: New Castle PA | Atlas Obsolete sells them, BUT I'd only buy there if it were the absolute last place on earth. I echo what Chrispy said -- make your own with 7 mm black wires. If you're trying to be correct, the only issue you might have is that the straight cup for #1 cylinder at the distributor should be red. | ||
ttotired |
Expert 5K+ Posts: 8445 Location: Perth Australia | I have found that the crossover listings for plugs are garbage and are written by stupids Same problem as you had. Looked up plugs for my 318 poly and ordered them, they were 3/4 reach, not 3/8 as original. If I didn't have the original plugs (or I hadn't removed them) and had fitted the ones that came, then wound her over, it would have been a very sad day for me, with no recourse as I gave the number and how do you find the fool that made the cross over charts Be careful when changing plugs that you know what your getting | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | If you want to make your wire sets be sure to buy a proper crimping tool so that you have secure bonding at the ends. I have been using an MSD #3500 for the last 20-30 years now and it gives a perfect crimp every time. Not sure what the comparable current plier would be..... The copper bits are available from Beldon. I'll also suggest that you check the resistance of the wire before buying (you'll need 25') so that you aren't stuck with some crap. Try for less that 5000 ohms/lf (wire used in NASCAR is down around 300-500) (some oem has been measured above 20,000.....). As to spark plugs interchange: http://www.autolite.com/productfinder?b=A http://www.sparkplug-crossreference.com/ | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | There are some kits available here including the Red plug boot for no1 plug lead, here are the crimping pliers needed? http://www.northernautoparts.com/ProductDetail.cfm?ProductId=1288 | ||
NM Desoto |
Veteran Posts: 145 | I've run Champion RJ14YC plugs in mine for several years with good results. Also with the .035 gap. | ||
1957sotos |
Regular Posts: 65 | The wire sets on both my 341 hemi's are standard big block type with straight boots. Just use needle nose pliers to push the boots on the plugs or to wiggle them off. I feel they fit more snug than the original ceramic tubes. Once the wire covers are on, no one notices. Perry | ||
