Looking for a seal
plymouth
Posted 2017-01-03 5:21 PM (#530334)
Subject: Looking for a seal
20001001002525
I'm sealing up my torqueflite and I need a part number or size for the O ring on the pushbutton cable. Can anyone help me out?? Thanks
grunau
Posted 2017-01-04 9:11 AM (#530375 - in reply to #530334)
Subject: Re: Looking for a seal
10010010010025
Hi
The "O" ring seal at the trans cable is Chrysler part number 1316813 for 1960 to '65 not sure of the actual dimension as I've never measured it.
plymouth
Posted 2017-01-04 10:03 AM (#530382 - in reply to #530375)
20001001002525
Thank you
Posted 2017-01-05 12:54 PM (#530503 - in reply to #530382)
20001000500100100252525
The dimensions are .700" OD X .100" thick.
Posted 2017-01-05 2:32 PM (#530513 - in reply to #530503)
50002000100100100100
57chizler - 2017-01-05 12:54 PM
i was about to measure it. Thanks!
Posted 2017-01-06 2:56 PM (#530632 - in reply to #530513)
Here's some of the transmission O ring dimensions I have measured from overhaul kits:
O RING SIZES (OD X thickness)
Dipstick tube '62-on .750" X .100"
Speedometer Adapter '66-on 1.750" X .100
Speedometer cable trans end '60-'65 .950" X .100"
Shift cable '60-'65 .700 X .100"
Park cable '62-'65 .437" X .070"
Early NSS ?-'65 .970" X .100"
Rear band lever pivot shaft '66-on .625" X .062"
plymouth
Posted 2017-01-06 7:58 PM (#530667 - in reply to #530632)
20001001002525
Thanks guys. This helps a lot
