Location: ST. Stephen NB Canada | I'm looking for input regarding valve seal options. I have a 55 Dodge Royal, with the original 270 Hemi . I want to install valve seals, & really don't want to remove the heads . Regular umbrella seals are out because of double valve springs. So, my questions: 1.I have 3/8 oring seals, they are not square cut, but smooth round, will these work? 2. Is there a small umbrella type that will fit my inner spring clearance,(0.690 -0.710) ? 3. Are there positive stop seals that do not need machine work on the valve guides ? I don't have smoke when I back off coming down a hill,so I'm thinking the guides are Ok . Any advise is appreciated. Thanks. Loo |
Location: Lower Mainland BC | I do NOT know the answers to your questions BUT I might be in the same boat. The PN for the valve seals in my 56 CR V8 seem to be 1630241. A quick search on that number found a few things including these:
"Replaces Original (OE) Part #:1630 241, 2205 958, 3208 125, 388833, 388834, 401824, 406945, 575142, 580367, 581692, 612107C1, B6Q 6571-A, B6Q 6571-B, C1TE more details on -
https://www.carid.com/victor-reinz/valve-stem-oil-seal-mpn-b45298.ht... "
Also:
Brand: CHRYSLER
Part Number(s): 1630241
ProductName: Valve Stem Seal
Cross Interchange Parts:
Factory Number
CLEVITE 216-1014
NAVISTAR 445370C1
NAVISTAR 612107C1
CHRYSLER 2205958
FORD B6Q6571B
FORD C1TE-6571B
But then again, I know nothing and could have this all wrong.
HTH
Edited by 56D500boy 2016-12-17 4:59 PM
Location: NorCal | The 270 has 3/8" valve stems. You need to measure the actual O.D. of your valve guides to know what will fit, this looks promising:
http://enginetech.com/products/product-categories/valve-stem-seals/
Edited by 57chizler 2016-12-18 5:07 PM
