WHAT YEAR TORQUEFLITE TRANSMISSION CAN I USE
Ron
Posted 2016-11-17 3:47 AM (#526461)
Subject: WHAT YEAR TORQUEFLITE TRANSMISSION CAN I USE
WHAT IS THE LATEST YEAR TORQUEFLITE TRANSMISSION CAN I USE FOR A 58 CHRYSLER 300 D, WITH FACTORY MECHANICAL LIFTERS AND FACTORY CAM OPTION. CAN I USE MY POWERFLITE BUTTONS AND JUST NOT HAVE CONTROL OVER LOW GEAR AT STARTING OUT. WHO SELLS TORQUEFLITE REBUILT TRANSMISSIONS.
RON SWARTLEY
E MAIL ARCHANGEL1390@AOL.COM
PHONE 717-939-3429
Mopar1
Posted 2016-11-17 11:38 AM (#526479 - in reply to #526461)
Subject: Re: WHAT YEAR TORQUEFLITE TRANSMISSION CAN I USE
2000100025
Up to '61 has the same bell bolt pattern & crank length, '62 & up have the modern bell pattern/cranks. Or use an adaptor like what "Wayfarer" (QEC) here on the Board sells to use the 62 or so ones that have the push buttons
grunau
Posted 2016-11-17 12:20 PM (#526484 - in reply to #526479)
10010010010025
Hi
Remember that the shift cable changed on these cast iron Torque flites in 1960 to the style used up to 1965 with the adjustment "wheel" . With regard to the Buttons you will need to obtain a Torque flite button box as I think the only position that is close on the Powerflite box is "Drive" ' cause we tried that once when we were just starting out with this FL stuff that's how I know ...I'm pretty sure that the R,N, D buttons from the Powerflite set position correctly on a pre '60 Torqueflite button box or at least they do on '57-'58-'59 except for '59 Plymouth which has a unique button position setup.
I know of no one that sells rebuilt Torque flites you'd have to obtain a "core" and get it rebuilt. What car are you doing this on??
ram300
Posted 2016-11-17 7:33 PM (#526520 - in reply to #526461)
Subject: RE: WHAT YEAR TORQUEFLITE TRANSMISSION CAN I USE
1001001002525
I've got a '61 Torqueflite in my 300D the only difference I recall was the lenth of the shift cable, I think it's a lttle shorter on the '60-61.....and of course the cable has the wheel adjustment on the trans end.
Owen
Posted 2016-11-18 1:07 PM (#526566 - in reply to #526461)
20001000500100100252525
I'm confused, you say it's a 300D which came only with a Torqueflite but you want to use your Powerflite buttons?
Beltran
Posted 2016-11-20 1:54 PM (#526702 - in reply to #526461)
100050010010025
Hey Ron, I did this with my 55. I create a 5 button box so I could properly work the 57 Torgueflight I put in it. Only the really knowledgeable guys can tell there is something different about my car. Look at my signature below. Is this what your trying to accomplish?
wayfarer
Posted 2016-11-23 11:26 AM (#526943 - in reply to #526461)
500100100100252525
X2 on the 300D PowerFlite question...something is not-quite-right.....
Ron
Posted 2016-12-16 2:36 AM (#528845 - in reply to #526566)
NO NO NO I DO NOT WANT TO USE THE POWERFLITE BUTTONS, SOME ONE SAID I COULD THATS ALL.
I HAVE A CADILLAC LA SALLE STICK TRANSMISSION AND I WANT TO GO TO TORQUEFLITE TRANS------MY QUESTION IS WHAT YEARS CAN I USE?
RON
60 dart
Posted 2016-12-16 5:20 AM (#528848 - in reply to #526461)
50002000100050010010010010025
http://forwardlook.net/forums/forums/thread-view.asp?tid=4108&posts...
Posted 2016-12-16 6:35 PM (#528912 - in reply to #528845)
Ron - 2016-12-15 11:36 PM
RON
It really depends on whether you want to use an original iron replacement or want to adapt a later 727 using the adapter mentioned. If you want original, Chuck's link lists them.
