1957 New Yorker 4dr Sedan
Moderators: ronbo97
   Forward Look Swap Meet -> For Sale - EBAY, CRAIGSLIST & OTHER FINDSMessage format
Posted 2016-11-12 9:57 PM (#526083)
Subject: 1957 New Yorker 4dr Sedan
500020002000500100100
This car seems familiar....Is this owned by a member here?
http://www.ebay.com/itm/332027760949?ul_noapp=true
A true classic. A time capsule from 1957 that turns heads wherever you go. Take the whole family with you to the car show or drive-in. It has that classy look and that unmistakable rumble from a real, 392 hemi engine and dual exhaust. Don't miss a rare opportunity to own this one of a kind, rust-free New Yorker.
51k original miles. 392 Hemi. Push button transmission. Fender tag. Clean title.
This car is solid as a rock, top to bottom, no rust. It starts, idles, runs and moves very well but needs some brake work to drive reliably. Some extra parts come with it.
Email or call. Call only between noon and 9pm please.
Professional delivery available at a reasonable cost. Call or email to discuss.
(57 NY Sedan.jpg)
Attachments 57 NY Sedan.jpg (20KB - 115 downloads)
Posted 2016-11-12 11:00 PM (#526093 - in reply to #526083)
Subject: RE: 1957 New Yorker 4dr Sedan
500020002000500100100100100
Any idea where I could find these wire clips (or could I just use zip ties?)
Posted 2016-11-13 11:20 AM (#526134 - in reply to #526093)
They are reproduced. The company that makes the new valve covers makes them.
http://www.ebay.com/itm/Chrysler-Hemi-Spark-Plug-Wire-Covers-Chrome...
If you just wanted those, you could contact them and see if they would be willing to just sell them to you.
(Hemi Clips.jpg)
Attachments Hemi Clips.jpg (41KB - 117 downloads)
Posted 2016-11-13 11:46 AM (#526137 - in reply to #526134)
Powerflite - 2016-11-13 11:20 AM
They are reproduced. The company that makes the new valve covers makes them. If you just wanted those, you could contact them and see if they would be willing to just sell them to you.
Thanks. Great idea (why didn't I think of that ). Contacted the seller to see if he or his supplier would sell me just the clips.
Dave F.
Edited by 56D500boy 2016-11-13 11:47 AM
Posted 2016-11-13 12:43 PM (#526139 - in reply to #526137)
56D500boy - 2016-11-13 11:46 AM
Dave F.
Got a reply already:
"New message from: loffs Top Rated Seller(13,949YellowShooting Star)
No sorry I don't have any extras not able to get any more."
ToMopar
Posted 2016-11-13 12:59 PM (#526142 - in reply to #526083)
Subject: Re: 1957 New Yorker 4dr Sedan
10001002525
Nathan,
the clips in your ebay link are not the same as 56D500boy is searching for.
By the way, I am searching for such clips too......
(20161101_7966.jpg)
(20161101_7967.jpg)
Attachments 20161101_7966.jpg (110KB - 109 downloads)
Attachments 20161101_7967.jpg (128KB - 112 downloads)
Posted 2016-11-13 7:56 PM (#526168 - in reply to #526142)
Oh, you're right. Sorry about that.
Imp58Alpes
Posted 2016-11-15 7:36 AM (#526289 - in reply to #526083)
5002525
Powerflite - 2016-11-13 3:57 AM
Yes. It was in that thread:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=63325&...
Posted 2016-11-15 9:56 AM (#526297 - in reply to #526142)
ToMopar - 2016-11-13 12:59 PM the clips in your ebay link are not the same as 56D500boy is searching for.
Thanks for the photo. If the clips are this simple, it should be possible to make something that functions very much the same. Trick will be finding thin spring steel.
Posted 2016-11-15 10:02 AM (#526300 - in reply to #526297)
You could probably just use pallet bands - you know the metal straps that they use to tie pallets down. That stuff is quite springy, but not so much that you can't bend it. The hard part is going to be putting in the little bends that prevent it from galling the plug wires. But if you can do those first, you should be able to get it to work.
Posted 2016-11-17 3:19 PM (#526500 - in reply to #526300)
Really, you guys are looking for those clips? I believe I have a full set off a '57 392 that I would sell.
GregCon
Posted 2016-11-17 6:30 PM (#526518 - in reply to #526083)
Those clips, and the metal covers that go over the wires, just freak me out. Especially when used with the crummy old style spark plug wire insulation.
The whole goal is to keep plug wires AWAY from metal, not purposely encase it in metal. It's just begging for an arcing to take place.
Posted 2016-11-22 9:39 AM (#526826 - in reply to #526518)
Powerflite - 2016-11-15 10:02 AM You could probably just use pallet bands - you know the metal straps that they use to tie pallets down. That stuff is quite springy, but not so much that you can't bend it. The hard part is going to be putting in the little bends that prevent it from galling the plug wires. But if you can do those first, you should be able to get it to work.
GregCon - 2016-11-17 6:30 PM
The pallet band metal would work. (I think). There is a product called PlastiDip that could be used to make the metal less likely to abraid through the spark plug wire insulation and cause arcing.
Another alternative is to fashion the clips from plastic somehow. Would be a good 3D printing exercise. Hint Hint. (Somebody?)
Posted 2024-01-13 1:27 PM (#633379 - in reply to #526826)
Seven years later, I am still looking for those clips, PN 1483 579. Six per set.
Edited by 56D500boy 2024-01-13 1:29 PM
(SparkPlugWireControlClip_PN1483579.jpg)
Attachments SparkPlugWireControlClip_PN1483579.jpg (149KB - 30 downloads)
Posted 2024-01-15 3:15 AM (#633397 - in reply to #526083)
In practice, you only need 2 per side. The front 2 aren't necessary. I had 2 engines with them still on there and I have distributed them out to use on 4 engines.
