1958 Desoto steering wheel horn ring removal/advice: Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
DieselJeep |
Regular Posts: 86 | Hey all, I am trying to remove my horn ring, and the insides of the "wings" around the spokes are hitting the spokes before I can feel any "release" of the ring. The parts inside the column seem to be a little scrambled, I can't even tell if the original turn switch is in there still. A PO installed a hideous black plastic "signal stat" semi tractor style turn switch. Probably because they couldn't get the ring off, either. | ||
mstrug |
Expert 5K+ Posts: 6513 Location: Newark, Texas (Fort Worth) | Your FSM Should show the break down of the steering wheel assembly. | ||
mstrug |
Expert 5K+ Posts: 6513 Location: Newark, Texas (Fort Worth) | did you unscrew the top piece? http://www.ebay.com/itm/Chrysler-New-Yorker-Newport-Windsor-Chrome-... http://www.ebay.com/itm/1957-DESOTO-HORN-RING-WITH-CENTER-EMBLEM-/2... Edited by mstrug 2016-11-02 12:36 PM | ||
Lancer Mike |
Location: The Mile High City | Hi, Chris: Our steering wheels may be slightly different. On my car, I remove the center emblem by rotating it counterclockwise (this can be difficult if the spring steel clips on the bottom of the cap are crusty). Once the center emblem cap is off, I think it is just a matter of removing the three phillips head screws which hold the ring and horn button together. Once those are off, you just lift the ring right off the wheel. I will double check tonight. | ||
Lancer Mike |
Location: The Mile High City | Yes, Marc has it! In taking off the center cap, it doesn't matter if you depress the horn ring because those spring steel clips attach to the ring itself. I would not use tools to rotate that center cap - too easy to damage. If it is a total bear, you might try spraying WD-40 up under the cap with the little red straw (just a little!) | ||
fin junkie |
Regular Posts: 53 | This is off of a Chrysler with the emblem removed but the Desoto is the same. If you were able to gently lift the edge of the center cap and break the seal of 50+ years of chrome polish, the you should be able use a rubber pad, (such as is used for tool box drawers or even a rubber glove), put it on top of the center cap, and rotate it counter-clockwise. It will move about 1 1/2" to 2" to release. Hopefully the picture will post! (Horn ring 3.jpg) Attachments ---------------- Horn ring 3.jpg (162KB - 164 downloads) | ||
fin junkie |
Regular Posts: 53 | Another pix of the center. (Horn ring 2.jpg) Attachments ---------------- Horn ring 2.jpg (91KB - 170 downloads) | ||
DieselJeep |
Regular Posts: 86 | DING DING DING! The manual says, under "Steering Wheel Removal" and I quote, "Press down on horn ring ornament and turn counter clockwise". Sounded to me like the entire horn ring, and the line is so fine it's a bit hard to see a seam, so thought cast as one piece. It's a pretty vague book, at best, isn't it? And approaching delicate, expensive jewelry in such good shape... Wasn't trying to be an oaf with it, and most of the times google seaches come up nada. Along with that *^&$@# manual. Edited by DieselJeep 2016-11-02 8:59 PM (wheel hub.jpg) Attachments ---------------- wheel hub.jpg (215KB - 180 downloads) | ||
Doctor DeSoto |
Location: Parts Unknown | You will laugh about this later. I have my own set of "Mr. Obvious" funny stories from when I was green about these. I think everybody does. | ||
