Dome Lamp Assembly
ToMopar
Posted 2016-10-04 5:47 AM (#522602)
Subject: Dome Lamp Assembly
10001002525
I have here a dome lamp w/ switch and wonder how to wire the switch.
The problem is the switch itself, because I think it should have two connections, but the aren't.
Is there somebody with a picture of a connected assembly
(Dome Wireing.jpg)
(3137e.jpg)
(3137d.jpg)
Attachments Dome Wireing.jpg (2KB - 183 downloads)
Attachments 3137e.jpg (52KB - 166 downloads)
Attachments 3137d.jpg (62KB - 187 downloads)
Posted 2016-10-04 3:39 PM (#522640 - in reply to #522602)
Subject: RE: Dome Lamp Assembly
20001000500100100252525
The dome lamp bulb normally has two contacts; power flows into one contact, through the bulb, and to the door jamb switch which provides the ground. If the dome light has a built-in switch, that switch also provides a ground.
