1959 Imperial
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
Sahnu
Posted 2016-09-10 3:08 PM (#520948)
Subject: 1959 Imperial
Hi
Could you guys translate this tag codes, please.
(20160910_185549_resized.jpg)
Attachments 20160910_185549_resized.jpg (178KB - 143 downloads)
KcImperial
Posted 2016-09-10 3:21 PM (#520951 - in reply to #520948)
Subject: Re: 1959 Imperial
2000100100100100252525
From what I understand, 1959 is an oddball year for codes and not much interchanges with other years so there isn't much info out there for them.
Fortunately the popularity of '59 Imperials has increased in recent years so some of you '59 owners should be able to pool info and get better info posted online.
You can also order the IBM punch card (if available) from Chrysler Historical.
This will decode the VIN
http://www.imperialclub.com/registry/vin_decode.htm#1959
This will help with exterior colors and upholstery
http://www.imperialclub.com/Yr/1959/59Databook/Cover.htm
The only 2 threads I could find on here that show any option codes
http://forwardlook.net/forums/forums/thread-view.asp?tid=52076
http://forwardlook.net/forums/forums/thread-view.asp?tid=56162
Imp58Alpes
Posted 2016-09-11 10:59 AM (#520995 - in reply to #520948)
5002525
Some info:
- 1218 = 18th of december, 1959.
- M637 = 1959 Imperial Crown built in Detroit (Warren Avenue).
- 635 = Crown convertible.
- 613 = upholstery (cloth and leather) here: http://www.imperialclub.com/Yr/1959/59Databook/11.jpg
- ZZZ = paint code, Copper Spice Poly.
As for the rest, it's all mystery, as I've never seen any built record sheet, so difficult to reverse-engineer the codes.
Sahnu
Posted 2016-09-11 1:58 PM (#521002 - in reply to #520948)
Subject: RE: 1959 Imperial
Hi guys
Thanks a lot of your help. Im starting to repair the seats this winter.
