White 1958 Coronet Lancer Jump to page : 1 2 3 4 5 Now viewing page 3 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9672 Location: So. Cal | Go for it Mike! You really have nothing to lose. If you mess it up, you can still pay big bucks to get it re-molded. I cut out a ring for my horn contact today. Then I brazed a layer of brass on the bottom side to help prevent corrosion and put a spot of brass on the top side too in order to solder the electrical wire to it. I ended up grinding through the brass in 2 spots, but it should be alright anyway because I will cover it with dielectric grease. After it was done, I layed it into the wheel and welded it to the center hub. I dowsed the plate after each weld to cool it and prevent the soldered wire from melting and coming loose. I don't normally recommend welding on a piece of rug, but I thought it was worth the risk to catch it on fire in order to save the paint. Hopefully there won't be any interference issues with the turn signal, but if so, I will just grind the welds down until all is good. But I don't think it will end up being that close. I would have put it on today, but I had my limit of heat exposure for the day so I will save it for later. (Home Made Horn Contact.jpg) (Horn Fixed.jpg) Attachments ---------------- Home Made Horn Contact.jpg (228KB - 408 downloads) Horn Fixed.jpg (340KB - 424 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | For future reference, this is the wiring on the back of the fuel & ammeter gauges, as well as the light switch wiring on my '58 Dodge. (58 Dodge Fuel Gauge Wiring.jpg) (58 Dodge Light Switch Wiring.jpg) Attachments ---------------- 58 Dodge Fuel Gauge Wiring.jpg (174KB - 425 downloads) 58 Dodge Light Switch Wiring.jpg (193KB - 413 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I went to install the wheel and realized I really goofed. The way I have it setup, the horn is always connected to ground through the welds to the hub. So the original copper plate that is held by the hub must be electrically isolated somehow. I have no idea how I would do it here. Maybe I can cut the center hole extra large and epoxy it to the hub? Not sure how well that would hold it in place though. I am tempted to just put a button on the dash for the horn at this point. Edited by Powerflite 2017-09-03 10:06 AM | ||
soiouz |
Expert Posts: 3480 Location: Montreal, Canada | Why not just install the correct part instead? They are not so hard to find, I might even have one here in a parts drawer. | ||
big m |
Expert 5K+ Posts: 7807 Location: Williams California | Yes, David is correct. The horn contact rings are removable, there is no such thing as a 'power steering' steering wheel, as many proclaim, they are all the same with the exception of the removable horn contact ring. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | On my original wheel it is definitely not removeable. But I can't figure out how it isn't shorting out on the hub either?? If you have one of these I could install, I would be very thankful. | ||
soiouz |
Expert Posts: 3480 Location: Montreal, Canada | Powerflite - 2017-09-03 1:16 PM On my original wheel it is definitely not removeable. But I can't figure out how it isn't shorting out on the hub either?? O If you have one of these I could install, I would be very thankful. That brass ring is made to be removeable. It is cramped tight against the hub, but it comes out, that's for sure, unless your wheel was modified and not original. The original brass ring has a smaller rubber ring inside the hole for the hub, so it does not short on the hub. I will go in my garage right and try to find it.. I just hope I still have it. If I do find it, I will send it to you for the price of shipping only. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Thanks David! | ||
soiouz |
Expert Posts: 3480 Location: Montreal, Canada | Powerflite - 2017-09-03 6:20 PM Thanks David! Searched all over my garage, and I cannot find it!... I might have given it to a guy last year who wanted to do a conversion to power steering in his 1958 Dodge. Sorry! But Big M or someone else on this board should have one, they are not that rare. | ||
Expert 5K+ Posts: 7401 Location: northern germany | that steering wheel looks perfect, great work! nice color combo too! love 58 dodges. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Thanks for looking David. I probably need to find one because I don't see how to make it work well doing a home-made approach. Thanks Sid, I'll like it too once I can start to use it. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | The 2bbl carb was giving me all sorts of trouble with the float sticking open or something like that, so that it was constantly dribbling fuel down the throat of the motor. That made it very difficult to start after driving it because it was always flooded. When I checked the oil last week, I noticed that it was overfull - by about 3 quarts with a strong gasoline smell to it. Not good. The motor has also always had multiple lifters that were making a lot of noise and never quieted down. So I removed the intake & valve covers and replaced the lifters with new ones. All the lobes on the cam looked good so I felt confident that it would solve the problem. The gasoline in the oil had dried out the gunk in the motor so I vacuumed and cleaned it out of the heads & lifter valley the best I could. I drained the oil and then flushed the valley with new oil to hopefully flush out any extra debri that was still in the motor. I installed a new 30 degree style oil filter with an adapter from Hot Heads to hopefully catch the gunk a little better than the original style filter. After that, I primed the oil pump with the new oil so that I would have good oil on the crank bearings before I start turning the motor again. I then installed the 4bbl intake I purchased from BigM and a matching WCFB carburetor. I bought this new/old re-manufactured carb for my '56 Plymouth back in 2004 and never ended up using it. I also removed the downdraft tube and installed a 426 hemi style PCV setup on the right valve cover. I tied it into a Tee on the intake with the vacuum switch. Unfortunately, it started raining on me just as I was finishing it up. But I managed to snap a photo right before I installed a fuel line & new pump in the rain. During startup, the carb initially started dribbling fuel down it's throat, but after a whack with a dead blow, it stopped. Hopefully it doesn't do that again. I'll keep an eye on it for a while to make sure. I don't want a repeat of this lovely experience. After that, it ran well and had good oil pressure throughout the run around the block, in the rain, with really old wipers, and...... no lifter noise! Yay, mission accomplished. I have an air cleaner for the 4bbl, but it needs a little body work done on it before it's ready for paint. (Dry Lifters.jpg) (58Coronet 4bbl.jpg) Attachments ---------------- Dry Lifters.jpg (240KB - 380 downloads) 58Coronet 4bbl.jpg (211KB - 369 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I purchased an NOS knight emblem from Ebay, but I can't decide if I like it on the grille or not. Without it, the Coronet looks more bare-bones and muscular, but it does look quite nice on there too. What do you think? (CoronetNoBadge.jpg) (Coronet-w-Badge.jpg) Attachments ---------------- CoronetNoBadge.jpg (289KB - 393 downloads) Coronet-w-Badge.jpg (263KB - 361 downloads) | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Powerflite - 2018-03-24 2:14 PM I purchased an NOS knight emblem from Ebay, but I can't decide if I like it on the grille or not. Without it, the Coronet looks more bare-bones and muscular, but it does look quite nice on there too. What do you think? Gotta have it! It adds charm to the muscle! Greg | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I think you are right Greg. I am liking it more and more. Yesterday, I finally fixed the dash lights on this car. First I attempted to install a good '56 Dodge light switch in place of the original '58 Dodge version. I used some lug adapters to convert to the existing terminal on the wires so I didn't have to change the wiring. The switch worked, but I couldn't get it installed into the dash because it collided with the structure on the backside of the dash. So I decided to take the original switch apart and fix it. It wasn't very difficult to fix. It just required cleaning all the contacts and applying electrical grease to protect it afterward. The contact from the rheostat wire to the internal contact was the hardest part to do, but I managed to make it work by using a very small file all around where the wire enters into it. Re-crimping the housing is never as tight as when the factory did it, but it is close. I should have taken pictures of it apart for future reference, but I neglected to do it. Sorry. Edited by Powerflite 2018-04-01 12:41 PM (58Dodge Light Switch.jpg) Attachments ---------------- 58Dodge Light Switch.jpg (84KB - 368 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Took the family to Oro Grande Days in the Coronet and entered it in the small car show there. The Stagecoach Olds creation was unexpected and neat to see. It was pretty fun for being a small place. We trolled the numerous antique shops there and was surprised to find an original propane tank for my Kit teardrop trailer! It was really cheap too, compared to getting it from someone who knew what it was originally from. I also picked up an old fuel can to replace the utter garbage versions that they sell today. Oro Grande is just North of Victorville and lies right on Route 66 so there are a couple of neat things to see around there, including an old metal truss bridge from the 30's, a couple of old motels & gas stations. We also went to the route 66 museum in Victorville too. Afterward we headed to just South of Lancaster to take a hike in the Devil's Punchbowl. That was really neat and I recommend anyone to check it out if you are in the area! The only issue we had with the Coronet was that we hit a couple of regularly spaced bumps or dips in the fast lane at a high speed turn and the inside rear tire seemed to hit resonance and immediately bottomed out 3 times to the point that it was a little scary. My car sits pretty well in the rear, even with all my family in there, but nevertheless, the rear springs just aren't as stiff as they should be to handle very well. My '58 DeSoto with its new (stiffer) rear springs & front sway bar handles soooo much better than this car. Oh there was another issue. The starter switch on the neutral button just decided to stop working....of course. It's worked great the whole time I've had the car, but today it decided to stop. I kept a piece of wire handy in the car for emergencies so it wasn't a big deal except that I had to hot wire it every time I needed to start it again. (Coronet at Show.jpg) (StageCoach Front.jpg) (StageCoach Back.jpg) (T-FireTruck.jpg) (Antique Goodies.jpg) (EmmaJeans 2.jpg) (Devil's Punchbowl Kids.jpg) (Devil's Punchbowl Ravine.jpg) (Coronet Devil's Punchbowl.jpg) Attachments ---------------- Coronet at Show.jpg (227KB - 362 downloads) StageCoach Front.jpg (164KB - 388 downloads) StageCoach Back.jpg (133KB - 352 downloads) T-FireTruck.jpg (240KB - 367 downloads) Antique Goodies.jpg (240KB - 369 downloads) EmmaJeans 2.jpg (141KB - 354 downloads) Devil's Punchbowl Kids.jpg (207KB - 358 downloads) Devil's Punchbowl Ravine.jpg (216KB - 368 downloads) Coronet Devil's Punchbowl.jpg (229KB - 366 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I like the design of the tee shirt that came with show registration. (OroGrande Days TeeShirt.jpg) Attachments ---------------- OroGrande Days TeeShirt.jpg (142KB - 362 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Looks like a great trip with the family! Awesome pics, I'm sure you all made lasting memories in that ol' Dodge. | ||
Lancer Mike |
Location: The Mile High City | Cool beans, Nathan! Looks like a great trip! | ||
Expert 5K+ Posts: 9672 Location: So. Cal | It really was fun. It's funny because I can enjoy it with or without new paint just as well. I like to enjoy them long before they are done.... | ||
Lancer Mike |
Location: The Mile High City | Yep, that's the perfect time to drive 'em. BTW, I like the lancer grille emblem. I bet you got a lot of compliments on the road trip! | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I did get some nice comments Mike, mostly from people who had never seen one before and were surprised by the sleek roofline and cool fins. These gauges showed up yesterday from Bogota, Columbia. Nice set of gauges with near perfect chrome. This is going to make my dash look.....dashing! (Dodge Gauges.jpg) Attachments ---------------- Dodge Gauges.jpg (303KB - 346 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I drove the car to work today, and while cruising at 75mph on the freeway, the car suddenly started making a huge racket. When I pulled over, I found that the rubber boot for the ball & trunion had ripped & loosened and was whacking itself on the floor. Of course, there is an ample amount of grease on the floor now too. So I just turned up the tunes and tried to ignore it, but it doesn't seem to want to come off on its own. I'll have to live with the noise until I can get it back home to deal with it. I didn't really want to convert it to a slip-yoke setup yet, but it looks like it has become a priority now. | ||
Expert 5K+ Posts: 7401 Location: northern germany | Powerflite - 2018-05-04 2:41 PM I didn't really want to convert it to a slip-yoke setup yet, but it looks like it has become a priority now. Why for heavens sake would anyone convert to a heavy and inferior external slip yoke? The OE B&T is superior in every way and one of the outstanding (properly serviced) indestructible FL features. Mine, that has a very hard life behind a 383 and a 2.93 axle, is still like new with over 330k on it. If yours spewed grease after the boot failed, it wasn't properly serviced. There is no grease supposed to be behind the boot. Its a DUST-boot not a grease seal. Its not designed to carry grease only its own weight. Do not exceed the amount of grease given in the fsm, which is only 2 ounces. Keep it MoPar. Edited by 1960fury 2018-05-07 6:19 PM | ||
Expert 5K+ Posts: 9672 Location: So. Cal | If it was a slip yoke with a standard U-joint, we wouldn't be having this conversation. B&T are a pain in the neck, and bound to failure eventually. not to mention unobtainable parts and difficulty to balance. No thanks. I wish Chrysler had used a slip yoke much earlier than '65. | ||
Expert 5K+ Posts: 7401 Location: northern germany | Powerflite - 2018-05-07 6:43 PM If it was a slip yoke with a standard U-joint, we wouldn't be having this conversation. B&T are a pain in the neck, and bound to failure eventually. not to mention unobtainable parts and difficulty to balance. No thanks. I wish Chrysler had used a slip yoke much earlier than '65. Not at all and it works for me for 30 years without any problems, as i said, 330k miles just in one car, still like new. rebuid kits are readily available for much less than the cost of a slip-yoke conversion. try to rebuild a slip-yoke. not possible. welding required. ask the 50s GM guys about their external slip-yokes and how reliable they are, these are bound for failure and vibration. I never had any problems with the B&T in my cars. The B&T is the superior design, for several reasons, as every mechanic/engineer knows, but over the years (I drive FL almost daily for decades) replaced several cross/rollers. yes, if you carry grease in the boot it can cause vibration and will cause boot failure, but as i said, theres no grease supposed to be there. don't blame an excellent design because of poor service. the best parts break if you do not treat them properly. just service it as per fsm and it will last forever. Edited by 1960fury 2018-05-07 7:19 PM | ||
Expert 5K+ Posts: 9672 Location: So. Cal | The brake pedal started to increase it's travel bit by bit until it suddenly came pretty close to the floor. So I took the rear brakes apart and eventually found that the adjuster tab on the rear brake shoe had bent over so that the adjuster didn't make contact with it anymore. Also, the round spring clip that holds the adjuster to the main structure had broken off. Great. After a lot of effort, I managed to get the spring clip back into place and I clamped down on it to get it as close to the original position as possible, then I welded it to the adjuster pin in multiple places to make sure it wouldn't move again. I tried bending the tab on the brake shoe back into position, but it was really soft and immediately broke off. So I pulled a brake shoe from the front of my '58 New Yorker, that had good ones on it, and replaced the bad one on the Coronet. After that, I put it back together and I was able to adjust the shoes like normal again. Drove the car, and the brakes feel like new. Nice, ready for use again. Edited by Powerflite 2018-06-03 2:00 AM | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I welded sway bar brackets and mounted a bar from a Dodge based '58 Windsor yesterday. It was difficult to weld with everything in the way, but it came out fine. The links seem a little long because the bar will rub on the strut bars under a hard turn while braking. But the brackets are at the top of the frame, so I don't know why there would be an issue. I will just shorten them up a little to move them out of the way. Having shorter links is better anyway. But the car handles much better now. Even with a 3/4" bar, the sway is dramatically reduced. Edited by Powerflite 2018-07-15 2:32 PM (Dodge Sway Bar.jpg) Attachments ---------------- Dodge Sway Bar.jpg (100KB - 358 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | A little camping at the beach fun. High speed turns are much more enjoyable now with the sway bar in there. (Dodge at Beach Camp.jpg) Attachments ---------------- Dodge at Beach Camp.jpg (162KB - 327 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I had planned to hitch up the teardrop trailer to our '56 Savoy and take that to the Sierra mountains this weekend, but once it was loaded down, it started losing power and backfiring quite a bit. No amount of timing adjustment could fix it. I figure it may be too much slack in the timing chain that is causing it. Anyway, we re-packed our stuff into the Coronet instead and took that without the trailer since it doesn't have a hitch on it. Was a little crowded with 6 people and all their stuff, but that trunk is huge and we got it to fit! Had a great time and the car worked perfectly except that I found out that the raised lettering on the inside of the right front tire will rub the upper control arm when the car is loaded down and you hit a bump - or corner a hard left. The right side only. Weird, but it wasn't a big deal, just occasionally annoying. I will look to see what I can do about it when I get under it again. The high gears in this car make it very enjoyable to drive on the freeway. We went 75-80 mph most of the way there. Edited by Powerflite 2018-08-13 1:38 AM (KingsCamp Coronet.jpg) Attachments ---------------- KingsCamp Coronet.jpg (331KB - 340 downloads) | ||
Lancer Mike |
Location: The Mile High City | Great pics, Nathan! Thanks for sharing. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Thanks Mike. I figured I would start to show a couple of the more fun ways I use the car since I am not working on it as much as I used to. But improving the sunvisors is next on the work list for it. | ||
60 Imp |
Location: North Australia | You had the coolest camping vehicle in the park I recon! Nice pics. Which park is that? Steve. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | We really did! It was funny when a Filipino couple saw it and took their picture in front of our car. There tends to be a lot of foreign visitors in these camps, but I also had a good chat with a Chevy guy who camped next to us. This was in King's Canyon near the end of the road. I was hoping to buy some gas from the old gas station that I used in the '70 Satellite 4 years earlier, but it had burned down from a fire that went through there in 2015. Glad we had the chance to use it while it was still around, only 1 year before it was gone. (King'sCanyonGas2.jpg) Attachments ---------------- King'sCanyonGas2.jpg (190KB - 352 downloads) | ||
Burnemup |
Veteran Posts: 141 Location: Simi Valley, CA | Nathan, Hello, I enjoyed our conversation last night at the cruise-in at Bobs in Northridge. I have the Black 55 Dodge! See you Soon! At some Car Show or Cruise Night! Ernie Baily | ||
Expert 5K+ Posts: 9672 Location: So. Cal | It was great to meet you Ernie. Thanks for the A/C tips too! | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I finally got the sunvisors installed. Only took me about a year! The new visors were made to work with the later style rod that is one uniform size, 5/16" diameter. My original rods are more like .35" instead. Not a big difference, but enough that it won't work because they make them to fit very tight. I could have cut the originals down on a lathe, and then cut them shorter, but I don't have access to a machine shop right now, so I just welded rods from newer sunvisors onto the old ones. Not as clean as I would like it, but it works and isn't bad. (Coronet SunVisors.jpg) Attachments ---------------- Coronet SunVisors.jpg (66KB - 320 downloads) | ||
flattie45 |
Veteran Posts: 194 Location: Dorset, England | Powerflite - 2018-08-13 6:30 AM I Had a great time and the car worked perfectly except that I found out that the raised lettering on the inside of the right front tire will rub the upper control arm when the car is loaded down and you hit a bump - or corner a hard left. The right side only. Weird, but it wasn't a big deal, just occasionally annoying. I will look to see what I can do about it when I get under it again. The high gears in this car make it very enjoyable to drive on the freeway. We went 75-80 mph most of the way there. Surely your tyres are rubbing because you've fat radials on there?? Stick some useless old BBs on & the trouble will disappear. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Change tires? Never would have thought of that. I made this bracket to attach the knight's crest to the grill. It looks similar to the original bracket. How should I secure it to the emblem? The pins on the emblem are tapered so it looks like it is meant to just use a friction force to hold it in place. I am not real fond of that approach because taking it back off can be dangerous to the pins. I would rather widen the holes and use some nuts to secure it, but I am not sure how well the nuts will work with those tapered pins. Any advice for this from those people with experience? (58 Dodge Grill emblem.jpg) Attachments ---------------- 58 Dodge Grill emblem.jpg (133KB - 336 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Are these barrel nuts the right approach? Connect them to the bracket and slide the emblem in them? I assume that you grip on those little tangs and that will release the pressure to be able to remove it. How well do they work? Might be tough to do that simultaneously to both pins. Edited by Powerflite 2018-08-28 7:28 PM (Barrel Nut Assortment.jpg) Attachments ---------------- Barrel Nut Assortment.jpg (176KB - 324 downloads) | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | They have nuts that hold them on, the kind that cut their threads. Have a photo, but too large. Attachments ---------------- 7045CA5E-192E-453F-8276-26EDD0DF6624.jpeg (150KB - 343 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Cool. So they just used regular emblem nuts on them. Strange that they would make the pins so long and tapered for that. But I like that method the best if it works well. Your picture wasn't too big, it had the wrong file extension as .jpeg instead of .jpg. (7045CA5E-192E-453F-8276-26EDD0DF6624.jpg) Attachments ---------------- 7045CA5E-192E-453F-8276-26EDD0DF6624.jpg (106KB - 329 downloads) | ||
christine-lover |
Expert Posts: 2996 Location: Sept. 1958 | Yeah, I modified it, unfortunately with my iPhone all photos are jpeg. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | My oldest daughter took a video of us riding home in our Coronet near Fresno, California as we came up to a '57 Chevy cruising along. The audio was boring so I dubbed something more interesting over it. Edited by Powerflite 2018-09-03 2:21 PM | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I bought this lower trim to mount the dash pad to my car. I was originally thinking I would just modify the painted steel trim from the Chrysler to do the job, but I was surprised to find out that the Dodge version is made from pot metal and chromed. It is also more complicated, running along the right side of the dash in two directions, whereas the Chrysler version is just a slightly contoured, straight piece of steel. Were they all like this, or is this a Custom Royal version only? (58Dodge DashPad Trim.jpg) (58Dodge DashPad Trim Close.jpg) Attachments ---------------- 58Dodge DashPad Trim.jpg (67KB - 313 downloads) 58Dodge DashPad Trim Close.jpg (83KB - 325 downloads) | ||
Lancer Mike |
Location: The Mile High City | Hi, Nathan: I think any 1958 Dodge, regardless of model or body style, that had the padded dash option (or safety option group - as it was one of the components) came equipped with the chrome pot metal piece. It is kinda cool!
BTW: I used plastic nuts on some of my emblem pins and they work really well without chewing up the pins. Something to check out. Edited by Lancer Mike 2018-09-29 6:05 PM | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Plastic nuts, sounds interesting. They don't make thread cutting versions, I assume; so what thread size did you use? 10-24 maybe? I like that idea because it wouldn't affect the integrity of your pot metal from corrosion of the nut. This car has very nice floors for the most part. Not a bit of rust on it anywhere except for under this rear seat brace. That thing is rusted quite heavily with a couple of rust holes in the floor underneath it. So I extracted the brace from the really rusty 300D that I parted out. Weird that that car was so rusty you couldn't possibly save it, but it nevertheless had a good seat brace on it. I can even see clean, bare metal on the underside of it. After I get this replaced, I will install new carpeting in the car. (Hardtop Seat Brace.jpg) Attachments ---------------- Hardtop Seat Brace.jpg (138KB - 317 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Powerflite - 2018-09-03 1:44 PM My oldest daughter took a video of us riding home in our Coronet near Fresno, California as we came up to a '57 Chevy cruising along. The audio was boring so I dubbed something more interesting over it. This (the embedding protocol was wrong so I removed it): https://www.youtube.com/embed/JJBjEriATwY Edited by 56D500boy 2018-10-01 11:37 AM | ||
60 Imp |
Location: North Australia | Nice video, why has that Kid got green stuff coming out of her ears?? Nice to see your Kids cruising. A crusty 58 Dodge 2drht beats a 57 Chev sedan any day of the week in my book. Steve. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Especially a sloooow Chevy My noisy old window gaskets aren't going to get replaced until a new source for them comes up. Hopefully someone will be able to take over Gary's operation. But it isn't bad for short runs; it's just that on a 3.5 hour drive, your hearing can suffer with a constant noise like that so I make my kids wear ear plugs. The real question is why isn't my son wearing them! The trunk lid I bought from John had this license plate panel rusted, probably from storing the lid with this area up, catching a lot of water and dirt in there. So I cut that section from my original and kept it for future use. Today, I separated it from the remainder of the trunk lid that it was welded to. Sandblasting it now will make it so I don't have to sandblast the whole lid later. Hopefully, I can find time to get it welded into the lid in the near future, but I need to figure out how to remove that die cast panel from around it first. On this one it was easy because I had access to the tabs holding it once I cut the section out, but on the new one, I am afraid of breaking it trying to get it out. (Original Trunk Lid License Panel.jpg) Attachments ---------------- Original Trunk Lid License Panel.jpg (159KB - 325 downloads) | ||
