Interest in reproduction of plastic connectors for PW switches Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Hello, As you might have seen in another thread, I have the possibility to reproduce the plastic connectors for Power Window switches through 3D printing. The parts are made of polyamide (PA 2200) and are very accurate, identical to the original ones. If there is enough interest, I will produce them for you. The price will depend on the quantity of course, and here is what I can propose, based on the cost of production (price without shipping) : Master switch (4 switches / driver's side) - 5 to 19 units : $33 - 20 units or more : $17 Single switch (1 switch / passengers) - 5 to 19 units : $17 - 20 units or more : $9 If you are interested, please let me know in this thread. Thank you. (DSC02189.JPG) (DSC02193.JPG) (DSC02191.JPG) Attachments ---------------- DSC02189.JPG (123KB - 199 downloads) DSC02193.JPG (177KB - 186 downloads) DSC02191.JPG (158KB - 188 downloads) | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Hi, I got a few questions so here are some additional information : - The parts are 3D printed through a method known as Selective Laser Sintering (SLS) : https://en.wikipedia.org/wiki/Selective_laser_sintering - The material is a polyamide (PA 2200), very well suited for this application - The prices above are the final price you will pay depending on the total quantity I will produce. In other words : the more we are, the less expensive it will be. Thanks. | ||
Expert 5K+ Posts: 5012 | I'm interested. I have to check my car in storage to see how bad my mechanism is. | ||
57plybel |
Extreme Veteran Posts: 594 Location: Melbourne, Australia | I am interested in a full set Vincent
Great idea !
Colin | ||
miquelonbrad |
Expert Posts: 1737 Location: Hay Lakes, Alberta, Canada | I am interested! | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Good work Vincent. There is a definite need for these. I hope the word gets out to ALL forward look owners that you have these available. The single switch ones will also interchange with 60-64, as well as for some 59 etc. electric door lock switches. I will certainly tell my customers that you have them! Greg | ||
fin junkie |
Regular Posts: 53 | I'd be interested in at least one full set, probably two. | ||
soiouz |
Expert Posts: 3480 Location: Montreal, Canada | I would be in for two full sets. Thanks! | ||
My57Saratoga |
Elite Veteran Posts: 612 Location: Kingston Springs , TN | I'd be in for a full set. Mike | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | What years will these work on? If they fit newer stuff, you might be able to expand the market in other forums? | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | LD3 Greg - 2016-09-03 4:32 AM Good work Vincent. There is a definite need for these. I hope the word gets out to ALL forward look owners that you have these available. The single switch ones will also interchange with 60-64, as well as for some 59 etc. electric door lock switches. I will certainly tell my customers that you have them! Thanks Greg, your input is important to me. I also sent you an email about those connectors a few days ago. NicksGarage - 2016-09-05 6:27 AM What years will these work on? If they fit newer stuff, you might be able to expand the market in other forums? AFAIK, those work for '57 - '59 Power Windows setups. But as Greg pointed out, there might be other applications as well. | ||
57desoto |
Expert Posts: 1488 Location: New Castle PA | Put me down for a full set as well. Thank you! | ||
FINS! |
Elite Veteran Posts: 943 | I would be interested in several sets. Garrett | ||
finsruskw |
Expert Posts: 2290 Location: Eastern Iowa | So, it looks like a C note would cover a full set of 4 pieces, correct? Shipping should not be all that much as there would not be much weight. Keep us posted, OK? | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | OK, here is what I have so far : To be able to start the production, I will need a commitment from you, as well as a first payment. I'll send an email to each of you.
Edited by Chrome58 2016-09-06 8:24 AM | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | Are they only for 1957-59 models? | ||
Board Moderator & Exner Expert 10K+ Posts: 13055 Location: Southern Sweden - Sturkö island | It looks the same, but then someone should measure the distances between the connectors on a '60-'62 master switch | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | There is a slightly different pattern to the switch pin locations. Same holds true 64 as well. Greg | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Master switch that is. | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Update : due to the global interest, we are now in the second price range for the single switch connectors. So, the price for a full set has now dropped to $60.00 | ||
finsruskw |
Expert Posts: 2290 Location: Eastern Iowa | Works fer me!! These along w/a repro harness should cure a lot of PW issues I would think! | ||
philcojohn |
Member Posts: 16 | I'm in for two sets. Any chance some can reproduce of find a source for the electrical connector you use with this, that grips the pin? That is often in big trouble too . the harness will fix it for sure, but sometimes just a pin is wrecked | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Hi John, Thanks for the interest, you'll receive a PM shortly. As for the electrical connector, I have no source for it, but you might try with Greg Leggat ("LD3 Greg" on this forum). He does have a source, as he reproduces the complete harnesses. Edited by Chrome58 2016-09-08 2:20 PM | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Update Allright, I have launched the production of the first batch of parts. They will be ready by September 15th. Also, I'm in the process of looking for the right material to reproduce the covers of those connectors. I'll let you know if I succed in that. I hope, in the end, to be able to offer a complete set : connectors, covers and screws. Edited by Chrome58 2016-09-08 2:22 PM | ||
chrysler300c |
Expert ,, George Passed away July 28th 2021, He will be Missed Posts: 1295 Location: Twin Falls, Idaho | I will definitely take two sets. Thanks George | ||
fin junkie |
Regular Posts: 53 | Two years ago I purchased some of the terminal ends from Narragansett Reproductions, their website is http://www.narragansettreproductions.com. They don't list any terminal ends on their website and asked you to contact them. They were called power window pin terminals. | ||
55DeSotoOwner |
New User Posts: 1 Location: Beautiful North Idaho | Please put us down for one master and 3 singles. | ||
CustomRoyal |
Extreme Veteran Posts: 322 | I will take 2 sets. Thanks for doing these. Jim | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Update The first batch of production is almost pre-sold out. Some of you, whom have declared interest, have not yet answered my private messages. Please let me know as soon as possible if you confirm your interest and want to buy those sets. | ||
57Desotodome |
Member Posts: 33 Location: Norway | Put me down for a full set. Thank you! | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Hi Ole, At this stage, the orders for the first batch are closed. I will keep this thread open to prepare for a second batch, but I have yet to see if there is enough interest beyond the first batch. I have added your name to the second batch list. Thank you. Edited by Chrome58 2016-09-12 9:14 AM | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Update The production of the first batch is under way. They should be done by the beginning of next week. I have calculated the shipping costs (with tracking) : it'll be $8.00 per shipping - up to 2 full sets - to the US. I will contact you separately for the shipping, once I have the parts done. Edited by Chrome58 2016-09-14 8:44 AM | ||
finsruskw |
Expert Posts: 2290 Location: Eastern Iowa | Vincent, $$ is on the way today! | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Update The first batch of production is done I will now check each part individually for conformity, and start shipping the sets next week. (First batch.jpg) Attachments ---------------- First batch.jpg (142KB - 177 downloads) | ||
Expert 5K+ Posts: 5012 | 2nd batch two sets. | ||
1960 des |
Regular Posts: 83 | I will definitely take two sets. Thanks Michael | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Thank you for your interest. I've added both of you on the second batch list. | ||
mr426427 |
Member Posts: 11 | Please mark me down for a full set. Any chance you would make the 60-64 model? If you would not want to do that project yourself, would you share your contacts for someone else to do them? Thanks! Joe | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Hello Joe, I've added your name for the second batch. Thanks. As for the 60-64 model, I'd do it gladly if I had a model to work from. But I don't, at least for the moment being. My contacts are not special, I just drew the connectors on a 3D modeling software and used 3D printers that I can rent at my former engineering school for prototyping. Then I turned to a local 3D printing shop for batch production. Edited by Chrome58 2016-09-21 8:23 AM | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Update The first batch is being shipped out this week. I'll probably get the second batch into production before mid-october. Interchangeability I have made some research concerning the interchangeability of those parts, using the '55-'58, '59, '60 and '61 parts catalogs. Those parts are known under references 1779276 (master) and 1779268 (single), but only for the '57-'58 cars. Most probably, they were only serviced (and therefore referenced) during those years and they were included with the wiring or the switches after that. Based on the references of the switches and the wiring, I was able to cross-reference some of their use. I may be missing some applications, but here's what I've been able to gather so far: Master switch connector Electric Window Lift 1957 All - 1 per car - Plymouth, Dodge, DeSoto, Chrysler, Imperial 1958 All - 1 per car - Plymouth, Dodge, DeSoto, Chrysler, Imperial 1959 All - 1 per car - Plymouth, Dodge, DeSoto, Chrysler, Imperial Single switch connector Electric Window Lift 1957 All - 3 per car - Plymouth, Dodge, DeSoto, Chrysler, Imperial 1958 All - 3 per car - Plymouth, Dodge, DeSoto, Chrysler, Imperial 1959 All - 3 per car - Plymouth, Dodge, DeSoto, Chrysler, Imperial Electric Door Lock 1958 All - 2 per car - Imperial 1959 All - 2 per car - Imperial Electric Seat Adjuster 1957 All - 1 per car - Plymouth 1958 All - 1 per car - Plymouth 1959 All - 1 per car - Plymouth Tailgate Electric Window Lift 1957 Sub. - 1 per car - Plymouth, Dodge, DeSoto, Chrysler 1958 Sub. - 1 per car - Plymouth, Dodge, DeSoto, Chrysler 1959 Sub. - 1 per car - Plymouth, Dodge, DeSoto, Chrysler Edited by Chrome58 2016-09-29 8:54 AM | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | Allright, I'm closing the thread here, and moving it to the "For Sale - PARTS" section of the forum. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=63383 | ||
Jhack68 |
Member Posts: 40 | Looking for these. Any one know of a source | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | Jhack68 - 2021-05-09 7:28 PM Looking for these. Any one know of a source Did you check the contact information at the top of this thread ? Otherwise Contact contact info is powerwindows@orange.fr | ||
