aftermarket rear disc and power brake setup Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | i ordered and received the rear disc and power brake setup . don't know when i'll get to the install , got a ton of house things to do but maybe fall or early winter . the power brake unit i'm not 100% sure of out of the box fit because of the actuator length but i think if it needs one made , it won't be a big deal --------------------------------------later http://www.ebay.com/itm/1962-74-Mopar-B-Body-Chrome-8-Power-Brake-B... http://www.ebay.com/itm/Mopar-8-3-4-Rear-Disc-Brake-Conversion-Kit-... Edited by 60 dart 2016-08-05 3:55 PM | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Looks like it should be fun. Let us know how it goes. | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | aint startin real good . they shipped everything cept the disc/disc prop. valve/bracket/lines --------------------------------------------------later | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | after contacting the seller , they were supposed to be shipped today . i was given a tracking number but the package hasn't made the system yet . so now to wait and see if it gets here ------------------------------------------later | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | the missing prop valve came but was wrong . got all that straightened out . seemed like real nice people to deal with and i would go with them again . so now i have so many things to do and procrastination galore . maybe i should do the house stuff first! ---------------------------------------------------later | ||
DieselJeep |
Regular Posts: 86 | Don't suppose these kits would work in my '58 Desoto, would they? Tapered axles not worth fooling with? | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | take those tapered axles and cut em up for junk . thats how much i hate em . the last ones i took out , i actually pulled a stud THROUGH the hub . get yourself a good 8 3/4 even if ya gotta move the perches , which aint no big deal . you'll be glad you did -------------------------------------------------later | ||
DieselJeep |
Regular Posts: 86 | hahahaha And here I thought I was the only one at this whole site. Edited by DieselJeep 2016-11-01 7:14 AM | ||
Expert 5K+ Posts: 7401 Location: northern germany | DieselJeep - 2016-10-31 9:05 PM Don't suppose these kits would work in my '58 Desoto, would they? Tapered axles not worth fooling with? by all means keep it, or be one in the long, long list of people wondering why they can't make a fl car run in straight line. if you change to disks anyway, there is no need to pull the hubs anymore, unless you have to service the gears (or bearings). with other words, probably never again. Edited by 1960fury 2016-11-01 2:23 PM | ||
DieselJeep |
Regular Posts: 86 | 1960fury - 2016-11-01 9:56 AM DieselJeep - 2016-10-31 9:05 PM by all means keep it, or be one in the long, long list of people wondering why they can't make a fl car run in straight line. if you change to disks anyway, there is no need to pull the hubs anymore, unless you have to service the gears (or bearings). in other words, probably never again.Don't suppose these kits would work in my '58 Desoto, would they? Tapered axles not worth fooling with? I don't 100% understand your first sentence, Sir. If I DO understand you, if a car won't track straight after an axle conversion, the axle isn't square to the frame. That is kinda important to check before snugging down the u bolt nuts. Or possibly, a spring is sagging horribly, or the frame is bent or twisted. | ||
Expert 5K+ Posts: 7401 Location: northern germany | you just gotta weld the perches very precisely in place, 1/16" (or less) can make a difference, not just the center hole to center hole distance also the bore must be precisely on the shaft centerline, somewhat difficult to measure, also the angle of the perches is important. to me it wouldn't be worth it, i also like cars that still have the oe drivetrain. as i said, if you convert to disks anyway there is really no need to change axles and yes, i dislike the tapered shafts too. these can be like welded to the hubs. | ||
