A former owner replaced my original horn relay with a modern aftermarket type dangling near the battery. Recently I found the original horn relays in my parts box and it seems to work fine. I have however no idea where it was installed? So if somebody could provide a foto that would be great!
The car is a 61 Dodge by the way.
Thanks in advance! |
Location: Bräcke,Sweden | Not the best of pictures, you see the relay on the drivers side of the radiator.
(Hornrelay.jpg)
Attachments ---------------- Hornrelay.jpg (85KB - 210 downloads)
Location: Ottawa, ON | Thanks, that's exactly what I needed! Never thought it would be mounted there. |
Location: ZH, Switzerland | At my Letter the horn relais was mounted inside of the radiator yoke between the battery tray and the radiator, but much closer to the radiator. I don't know if it's related to a 1961 Dodge, but I could imagine. This way it is protected from spindrift and dust. Happy Restoring! Dieter |
Location: WHEELING,WV.>>>HOME OF WWVA | my 60 dodge is like ny56's --------------------------------------------later |
