disconnect the door jamb switch - idea?
di_ch_NY56
Posted 2016-05-29 10:33 AM (#512722)
Subject: disconnect the door jamb switch - idea?
100050025
Hi all
I have to remove the door jamb switches and the emergency brake switch which is basically a door jamb switch as well. I would like not to  cut the wires. Eventhough it's possible to resolder them and cover it with a shrinking tube.
Any other idea? At the picture is the emergency brake switch (striker plate folded down). But the hex nut at the door jamb switches are at the back.
Thank you very much.
Happy Restoring!
Dieter
Edited by di_ch_NY56 2016-05-29 10:38 AM
(IMG_2833_resized.JPG)
Attachments IMG_2833_resized.JPG (176KB - 176 downloads)
LD3 Greg
Posted 2016-05-29 10:50 AM (#512727 - in reply to #512722)
Subject: RE: disconnect the door jamb switch - idea?
The wires end in bullet connectors. They should just pull out.
Greg
