Model 715 Heater restore questions.
ABloch
Posted 2016-05-25 7:10 PM (#512411)
Subject: Model 715 Heater restore questions.
1000100100100100252525
Greetings,
After my little incident on the road back from Arizona I decided it was time to just redo the entire cooling system. I've got the radiator and heater core out to the shop for a hot tank and pressure test. I just installed an NOS Everhot temperature control valve that was on the shelf over at Old Car Parts NW. (gratuitous plug) Once I get the engine flushed out and everything cleaned up under the hood it will be time to reinstall.
Question. What should I use to seal the housing to the firewall? I could use some mastic or dum dum tape or even some foam type weatherstripping I have lying around the shop. What have you done?
Secondly, Is the housing supposed to be black black or just a natural greyish black. Was it painted black or is it just a black tinted fiberglass assembly? I could take the time to prep and paint it I guess, but it doesn't look half bad considering the age of it. Opinions? Thanks, Andrew
Posted 2016-05-25 10:51 PM (#512433 - in reply to #512411)
Subject: RE: Model 715 Heater restore questions.
500020002000500100252525
Most people just lightly sand and paint the housing clear. It looks really good that way and I think the original finish was just natural - no paint.
60 dart
Posted 2016-05-25 11:56 PM (#512445 - in reply to #512411)
Subject: Re: Model 715 Heater restore questions.
50002000100050010010010010025
if you go over lightly with fine scotch brite and soapy water , let dry , then 2 light coats of spray can satin clear , it'll look as near to new as possible ---------------------------------------------------later
