Location: St.Catharines, ON CANADA | got a 318 poly, looking for date of manufacture? Inside passenger valve cover #'s 07064 and 2264095. Stamp at head on drivers side 408824. Casting #2532630. # on block pass. side under the header 07744. I'm just looking for date?? |
Location: Sydney, Australia | When you say stamp on drivers side head, is that at the front of the head? Are there definitely no more characters to the left of 408824? EXAMPLE: 4M318 408824... |
Actually on the block, below the head. |
Location: St.Catharines, ON CANADA | Sorry, the # is 40824 and no #'s or letters next to it. Drivers side front below valve cover |
Location: St.Catharines, ON CANADA | where below the head?? Down by oil pan?? |
See if you can find a number stamped here:
(SB Serial Location.jpg)
Attachments ---------------- SB Serial Location.jpg (37KB - 266 downloads)
Location: Sydney, Australia | If you have no luck from below the head depending on if it's a later 318 you might find a casting date and time on the passenger side of the block, above the oil pan.. So you will have to go in from underneath.. |
Location: St.Catharines, ON CANADA | OK guys, just found some #'s. Passenger side on head just below valve cover 8D1-48910C |
In this video at the 2:40 mark.
https://www.youtube.com/watch?v=t7IPrBInZ-8 |
Location: Vancouver, BC | Six Pistons - 2016-05-20 5:26 AM
Should be a letter before the "8D1".
In any case, the "C" at the end means it was built at Chrysler of Canada's Windsor engine plant.
It was the 38,910th engine built that model year.
The "8" means V8 (naturally).
The "D1" is for Dodge or Fargo Truck, D-100 series.
Now, if you can read the letter(s) before the "8D1" I will be able to determine the model year.
