New User
| Hello guys! I'm new to this forum and this is my first post. If I'm in the wrong place, I apologize. I have a 1955 Windsor Deluxe and the battery cable shorted to the exhaust manifold which fried my starter relay. It's still on the 6 volt system and I'm having trouble finding one. Any help would be greatly appreciated! |
| You're in the right place --and welcome aboard. Going to be a rough search in the N.O.S. world -- I have some 1956 - 1960s, both A/T and M/T -- but, of course, those are 12 volt....
Hopefully, someone in here will be able to help you --- I have mountains of 1955 Chrysler parts -- brakes, brake shoes, wheel cylinders, brake hoses, front end, ignition, electrical, and
a whole lot more --all BRAND NEW !!!!!!!!
Maybe, someone can help you -- even a used one off somebody's parts car is better than nothing..... |
Location: Connecticut | jbritt72 - 2016-04-09 11:35 PM Hello guys! I'm new to this forum and this is my first post. If I'm in the wrong place, I apologize. I have a 1955 Windsor Deluxe and the battery cable shorted to the exhaust manifold which fried my starter relay. It's still on the 6 volt system and I'm having trouble finding one. Any help would be greatly appreciated! Tough break. Those guys are hard to find. Same part as 55 Desoto. You may be able to find one on ebay as I did. Also there are places that can rebuild your relay. Or pull one out of a parts car. BTW, be sure you are using correct 0/1 battery cables. You can buy them at NAPA. Corroded or thinner 12V cables are a cause of hard starting problems. Ron |
You'll probably have to settle for a universal unit and adjust the wiring as necessary.
http://www.dbelectrical.com/p-12580-6-volt-universal-solenoid-relay... |
New User
| Thanks for the help guys. I took mine apart and fixed it. Wasn't that bad of a job. Thanks for the input. |
New User
| You wouldn't happen to have a good steering wheel would you? Thanks. |
