57 Chrysler Windsor Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
J97_Imperial |
Veteran Posts: 161 Location: Pearland, Texas, McPherson, Kansas | I Know its hard to see, previous owner got very paint happy... (cc546c1ba0154439aa568a0a2180955a.jpg) Attachments ---------------- cc546c1ba0154439aa568a0a2180955a.jpg (38KB - 231 downloads) | ||
J97_Imperial |
Veteran Posts: 161 Location: Pearland, Texas, McPherson, Kansas | MDL----PNT----SCH----ITEM 145----BCB---1015----0059 2 lines of random numbers 16 2 15 4 19 23 Body--SO/FO---2--ABCDE and then more numbers 02237------------5 9-------13235 Edited by J97_Imperial 2016-01-07 11:40 PM | ||
Expert 5K+ Posts: 9670 Location: So. Cal | You already figured out your paint code. The trim code 53, which you omitted here is this blue fabric combo shown in this pic. MDL 145 is the 4dr Windsor. (57windsorsamples1.JPG) Attachments ---------------- 57windsorsamples1.JPG (70KB - 243 downloads) | ||
J97_Imperial |
Veteran Posts: 161 Location: Pearland, Texas, McPherson, Kansas | Powerflite - 2016-01-09 11:30 PM You already figured out your paint code. The trim code 53, which you omitted here is this blue fabric combo shown in this pic. MDL 145 is the 4dr Windsor. If only I could find some of that fabric, I'm taking interiors this semester in college and could redo them correctly! | ||
Expert 5K+ Posts: 9670 Location: So. Cal | You can get it at SMS auto interiors. They are likely the only ones that have it. | ||
KcImperial |
Expert Posts: 2490 Location: Kansas City, KS | J97_Imperial - 2016-01-07 10:29 PM MDL----PNT----SCH----ITEM 145----BCB---1015----0059 2 lines of random numbers 16 2 15 4 19 23 Body--SO/FO---2--ABCDE and then more numbers 02237------------5 9-------13235 The 2 lines of random numbers are actually read as vertical columns. Any 3 digit number would be an option code. Your options would be: 361, 336, 342, 331, 335, 334, 311, 319, 322, 323 I can not read the lower right section, there are more options there. The red circles shows an example of how to see the codes. (cc546c1ba0154439aa568a0a2180955a.jpg) Attachments ---------------- cc546c1ba0154439aa568a0a2180955a.jpg (48KB - 257 downloads) | ||
J97_Imperial |
Veteran Posts: 161 Location: Pearland, Texas, McPherson, Kansas | KcImperial - 2016-01-11 12:40 AM J97_Imperial - 2016-01-07 10:29 PM MDL----PNT----SCH----ITEM 145----BCB---1015----0059 2 lines of random numbers 16 2 15 4 19 23 Body--SO/FO---2--ABCDE and then more numbers 02237------------5 9-------13235 The 2 lines of random numbers are actually read as vertical columns. Any 3 digit number would be an option code. Your options would be: 361, 336, 342, 331, 335, 334, 311, 319, 322, 323 I can not read the lower right section, there are more options there. The red circles shows an example of how to see the codes. I'll try to get a better picture of the tag today. One of the previous owners painted the entire engine bay that weird green you see in the picture. Do you know what any of those options are off the top of your head? Jacob | ||
StillOutThere |
Location: Under the X in Texas | Take a picture of the BACK SIDE of the data plate and then invert it in your photo software. Go over the back with some fine steel wool first and it will be even better. | ||
J97_Imperial |
Veteran Posts: 161 Location: Pearland, Texas, McPherson, Kansas | StillOutThere - 2016-01-11 8:52 AM Take a picture of the BACK SIDE of the data plate and then invert it in your photo software. Go over the back with some fine steel wool first and it will be even better. That's exactly what I'm doing right now, picture will be up in a few minutes. | ||
J97_Imperial |
Veteran Posts: 161 Location: Pearland, Texas, McPherson, Kansas | Here is a much better picture. Unfortunately one of the screws is sized and stripped so this is the most it will come off without me cutting it. On the second and third lines, farthest to the left, the 2 numbers are 3 on the second from the top, and 5 on the third from the top. Edited by J97_Imperial 2016-01-11 3:34 PM (0112016142455~4~2~2-800x611.jpg) Attachments ---------------- 0112016142455~4~2~2-800x611.jpg (130KB - 234 downloads) | ||
StillOutThere |
Location: Under the X in Texas | The three you had circled: 342 = Hood ornaments (the double fin things in the middle) 331 = Vanity mirror 311 = Light package (Windsors only) | ||
StillOutThere |
Location: Under the X in Texas | 337 = Torqueflite 341 = Undercoat 333 = Cushioned Dash 332 = Solex Glass 329 = Electric Clock 325 = Power Brakes | ||
J97_Imperial |
Veteran Posts: 161 Location: Pearland, Texas, McPherson, Kansas | StillOutThere - 2016-01-11 2:40 PM The three you had circled: 342 = Hood ornaments (the double fin things in the middle) 331 = Vanity mirror 311 = Light package (Windsors only) What was the light package? | ||
StillOutThere |
Location: Under the X in Texas | J97_Imperial - 2016-01-11 4:05 PM StillOutThere - 2016-01-11 2:40 PM The three you had circled: 342 = Hood ornaments (the double fin things in the middle) 331 = Vanity mirror 311 = Light package (Windsors only) What was the light package?
I would expect that was a glove box light, trunk light and underhood light. Maybe the dash map light too if that wasn't standard in a Windsor.
J97_Imperial |
Veteran Posts: 161 Location: Pearland, Texas, McPherson, Kansas | StillOutThere - 2016-01-11 4:11 PM J97_Imperial - 2016-01-11 4:05 PM StillOutThere - 2016-01-11 2:40 PM The three you had circled: 342 = Hood ornaments (the double fin things in the middle) 331 = Vanity mirror 311 = Light package (Windsors only) What was the light package?
Yeah, I have all of those extra lights. Unfortunately, a previous owner took a can of blue spraypaint and covered the whole dash, including the lights, in paint. | ||
J97_Imperial |
Veteran Posts: 161 Location: Pearland, Texas, McPherson, Kansas | Alright, So after a year of messing with this car, I have a breakthrough and now we have enough options to match with factory stamped codes. However, i still do not know which codes go with which options. We already know that 342 = Hood ornaments (the double fin things in the middle) 331 = Vanity mirror 311 = Light package (Windsors only) 337 = Torqueflite 341 = Undercoat 333 = Cushioned Dash 332 = Solex Glass 329 = Electric Clock 325 = Power Brakes and from a different post we also know that 361 - Power antenna (My Car does not have power antenna so this code does not line up for my windsor) 328 - Power windows 326 - 6-way power seat 343 - Fender ornament 349 - Dual headlamps 335 - Mirror - left outside rear view 334 - Mirror - Interior day/night 322 - Rear speaker 319 - Music master radio 323 - Heater / defroster 265 - Delivery route (factory to desler) 332 - Solex gass 325 - Power brakes This leaves codes 361 336 The other Options My car has are Power Steering Jiffy Jet Jacob Edited by J97_Imperial 2017-03-09 12:44 PM | ||
J97_Imperial |
Veteran Posts: 161 Location: Pearland, Texas, McPherson, Kansas | Other than the two that i havent been able to deduce yet, this is how this tag should read 361 = (Power steering) 336 = (Jiffy Jet) 342 = Hood Ornaments 331 = Vanity Mirror 335 = Outside Mirror 334 = Day/Night Mirror 311 = Light Package 319 = Radio 322 = Rear Speaker 323 = Heater Defroster 337 = Torqueflite 341 = Undercoat 333 = Cushioned Dash 332 = Solex Glass 329 = Electric Clock 325 = Power Brakes And Regarding the 265, that showed the shipping Route was Factory to Dealer from what I have been able to find. Not Sure about A9 Now this is just a shot in the dark on those two options Jacob Edited by J97_Imperial 2017-03-09 12:47 PM (0112016142455-4-2-2-800x611.jpg) Attachments ---------------- 0112016142455-4-2-2-800x611.jpg (130KB - 180 downloads) | ||
RDP |
Elite Veteran Posts: 1049 Location: PL / EU | 336 windshield washer 361 manual antenna 327 power steering 319 radio music master | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Any idea what code 346, 269, and A9 stand for on a Detroit built '57 Windsor? | ||
RDP |
Elite Veteran Posts: 1049 Location: PL / EU | sorry, none | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I am thinking that maybe 346 is a gas powered heater because the number is close to the A/C number. Do you know what the number is for the gas powered heater? | ||
kenbiello |
Veteran Posts: 121 | 347 is for the Southwind gas heater on my '58 Saratoga | ||
RDP |
Elite Veteran Posts: 1049 Location: PL / EU | I met only once this option code - '59 Dodge = 347 | ||
Expert 5K+ Posts: 9670 Location: So. Cal | The light blue '57 New Yorker 4dr hardtop that John bought out of Montana has this gas heater option too. Most of the parts are still there, but the fiberglass housing is broken. | ||
