PF Torque Converter
t2dfyre
Posted 2015-11-17 9:46 PM (#495495)
Subject: PF Torque Converter
10010010025
Hi all,
Are there any replacement TC that can be used in place of the original for the powerflight transmission. My car is going into the shop tomorrow but i just thought id ask to see if there were any other options available other than to upgrade the whole transmission. I really like my PF. Thanks
Beltran
Posted 2015-11-18 8:29 PM (#495584 - in reply to #495495)
Subject: Re: PF Torque Converter
100050010010025
You can have it rebuilt and you can use a Cast Iron TF TC, as far as I know. I have both transmissions with air cooled and a water cooled TC. The mount / fitment is the same. At least for the two I have.
The question I have to ask though is why do you want to know? The PF TC has a very specific response range to support the fact that the trans is only a two speed. Messing with that spec TC requires some serious thought.
Shep
Posted 2015-11-18 9:17 PM (#495587 - in reply to #495584)
20001000100100100100
Beltran - 2015-11-18 8:29 PM
Good advice referring to the stall speed differences.
DepsilonD
Posted 2015-11-19 2:26 PM (#495641 - in reply to #495495)
500100100252525
Ty, I picked up an extra Powerflite from Nathan (Powerflite happens to be his member name here) and torque converter a couple of weeks ago that was fully functioning when removed last year from his '56 Plymouth. Hit me up if you need the torque converter.
Dave
t2dfyre
Posted 2015-11-19 2:58 PM (#495644 - in reply to #495495)
10010010025
Hi Dave,
Well i took it in to the tranny shop yesterday and they said its the pump..is the pump inside the TC?? Im not really sure what that means but im bringing it back on the 30th for them to repair it. He said he was going to order the pump however thanks for the offer i may still buy the TC off you.
Ty
Edited by t2dfyre 2015-11-19 2:59 PM
Posted 2015-11-19 4:28 PM (#495648 - in reply to #495495)
50005000200010002525
The pump is mounted in the front end of the transmission. A damage drive sleeve might press on the pump, but I guess that it's the converter.
IRLTED1965
Posted 2016-04-01 11:52 AM (#508532 - in reply to #495495)
Subject: RE: PF Torque Converter
New User
DOES ANYONE KNOW WERE I CAN FIND A POWERFLIGHT TORQUE CONVERTER FOR A 1957 DESOTO FIREFLIGHT W/POWERFLIGHT TRANS ????????
bbrasse1
Posted 2016-04-01 7:06 PM (#508550 - in reply to #495495)
50025
Could you buy a fireflite with a PF?
