Space Cramming
   Forward Look Announcements -> Help With Using This BoardMessage format
cbrayinga
Posted 2015-11-13 1:34 AM (#495029)
Subject: Space Cramming
When I type a post, I try to space correctly and use two, maybethree paragraphs. Then I click "preview", the message looks fine,but when I "submit" it, it looks like this (I'll try to imitate it):Thispost hasthespacing crammedalltogether with the periodsand paragraphs runningcontinuous.Even when I try to copy/pastealink,it will cramitwith the other text, making itimpossible to click onlike this:http://www.forwardlook.net/forums/forums/thread-view.asp?tid=31693&posts=26&start=1Any ideas?
cbrayinga
Posted 2015-11-13 1:36 AM (#495030 - in reply to #495029)
Subject: Re: Space Cramming
There! It did it again! That post above was supposed to be two
small paragraphs.....urgggghh...
ronbo97
Posted 2015-11-13 8:35 AM (#495048 - in reply to #495030)
200020001002525
Do you use the Reply button, or type in the space below the thread ? I noticed that spacing between lines is different between one and the other. Also are you using a tablet or phone to reply, or are you using a laptop or desktop ?
Try hitting the enter key twice between paragraphs and see what happens.
Ron
Edited by ronbo97 2015-11-13 8:37 AM
jimntempe
Posted 2015-11-13 7:42 PM (#495097 - in reply to #495029)
2000100100100
To avoid problems with formatting, go to CONTROL PANEL (up in the top right corner of the page) and set your options to
Use rich edit box when composing messages? NO
You might also want to set the - How should the reply box in thread view be displayed? to FULL so that you have the option to add attachments without having to submit and then edit it again.
I have found those setting fix the problem of the lines getting all squished together after an edit.
Edited by jimntempe 2015-11-13 7:43 PM
cbrayinga
Posted 2015-11-15 6:15 AM (#495215 - in reply to #495097)
I've been using the space below to type a post, but on "this" one,I clicked the reply button, so we'll see how it turns out.Paragraph two... I'll try those control panel settings as well andsee if that helps too.Thanks guys!!
cbrayinga
Posted 2015-11-15 6:16 AM (#495216 - in reply to #495029)
Dang... I guess the reply button thing didn't work... just look at that above message! Looks like a 1st grader wrote it.
cbrayinga
Posted 2015-11-15 6:21 AM (#495217 - in reply to #495029)
Okay... testing... testing... paragraph one.
Paragraph two...
Three.... etc...
cbrayinga
Posted 2015-11-15 6:22 AM (#495218 - in reply to #495029)
Hey! It worked! I just changed the forum and thread view settings from "default" to "flat".
cbrayinga
Posted 2015-11-18 6:47 AM (#495519 - in reply to #495029)
And, yep, using the "basic" editing box on a reply instead of the"rich text" box helped when I replied to a post using a quote.Thanks guys!!
