Location: D-70199 Heslach | When motor/transmission is cold, every time I start the car, it leaks a mass of ATF in case I push the "D" pushbutton.
I found out, the ATF comes out of the trans dipstick tube. The transmission is a 3 spd TorqueFlite from a 57 Fireflite.
Any ideas... |
Location: Southern Sweden - Sturkö island | This could be many causes Tom, after checking that the vent isn't clogged, I'd start with confirming that the dipstick is the correct one by emptying all transmission fluid (also the converter), measure up the volume and refill the fluid to the correct capacity. |
Location: D-70199 Heslach | Sven, even at the risk to blame me, where is the vent of trans ? |
Location: Southern Sweden - Sturkö island | No problems Tom, look on top of the rear extension (alu), there is a metal cup that is supposed the vent out air. The metal cup should be rattling somewhat - if not you must clean it up. |
Location: Belgium, 40 miles south of Brussels | It might come from the fact that the engine has not been started for a long time.
When that's the case, the torque converter slowly empties its ATF into the transmission, causing overfill and spillage.
The cure is to start the engine, and let it idle for less than a minute, every week. |
Location: Southern Sweden - Sturkö island | If a transmission pukes out oil - there's always a reason. Even with the drainback from the converter, the transmission will handle this in a blink of an eye. As soon as the engine starts the transmission front pump will fill up the converter very fast.
Even if I leave my car a month without starting the Engine, there will be no transmission fluid puke out. Some transfluid might leak out from the throttle lever seal, but that's "normal". |
Here's a pic of the breather that was posted before.
(breather.jpg)
Attachments ---------------- breather.jpg (67KB - 239 downloads)
thanks for the picture, this is very helpful |
