Rear brakes lock & change adjustment
Posted 2015-04-22 10:22 PM (#476392)
Subject: Rear brakes lock & change adjustment
500020002000500100100
My 57 Chrysler rear brakes are giving me trouble. I replaced the wheel cylinders & lines and adjusted the rear brakes according the FSM (everything but the shoes were bad initially). I also put disc brakes on the front. When I back out of the driveway, my rear brakes lock up. I pull forward and it unlocks. I go backward again and now I have no pedal because the rear adjuster is fully out. What would cause the rear brakes to lock up and change the adjustment like that?
ronbo97
Posted 2015-04-22 11:34 PM (#476399 - in reply to #476392)
Subject: RE: Rear brakes lock & change adjustment
200020002525
Weak return springs, bad brake hose, incorrect or incorrectly adjusted proportioning valve.
Ron
Shep
Posted 2015-04-23 8:06 AM (#476415 - in reply to #476399)
Subject: Re: Rear brakes lock & change adjustment
20001000100100100100
Fluid soaked linings, also.
Posted 2015-04-23 3:39 PM (#476440 - in reply to #476415)
5000200010010010010025
Shep - 2015-04-23 8:06 AM
x2
Posted 2015-04-24 2:29 PM (#476517 - in reply to #476440)
I'll check out the linings & return springs, but this problem has nothing to do with the hydraulics. The hydraulics work perfectly. That one wheel seems to catch (so far only in reverse) and then screws up the adjustment.
Posted 2015-04-24 2:55 PM (#476518 - in reply to #476392)
50005000200010002525
A leak from the rear axle will give the same problems as brake fluid soaked into the brake shoes - check the outer seals and see if there's any leaks
