89 Fifth Ave rear end in '59 Plymouth Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
59finnedwarrior |
Extreme Veteran Posts: 301 Location: Alberta Canada | I have an '89 Fifth Ave donor car-how tough would it be to swap its rear end into a '59 Plymouth? | ||
Handygun |
Elite Veteran Posts: 1118 Location: STL, MO | Cut the perches off, put 8 1/4 up to springs to set pinion angle, weld new perches on where your existing spring c/c is, pretty simple. But it is a junk rear end for anything more than a flathead and will be geared for Bonneville. I'd look for a 8 3/4 or 9 1/4 myself. | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | What engine/tranny you running? | ||
59finnedwarrior |
Extreme Veteran Posts: 301 Location: Alberta Canada | Magnum V-6 with a 5 speed out of a 2001 Dodge truck | ||
Rodger |
Expert Posts: 1506 Location: Colo Spgs | Hola Jerry If you look at the Rear Axle used in 1959 and The Max Torque/ Weight that was used --- then do the same with The 1989 5th Ave --- The 5th Ave Unit is very OK. I agree the "as is" Ratio is fine for Bonneville. There are other Ratio's that you can use which will have The Vehicle Speed - The High Way Speed and The Engines Torque at the wanted RPM's. I like the V6 Engine being used because it is lighter and what weight it has is not as far towards the front of The Plymouth. It was used in Dodge Trucks up to their 1 Ton Units. The same information is true for Their 5 Speed Manual. The "cut & paste" from Steve is very good to know and use. Rodger & Gabby Colo Spgs | ||
Board Moderator & Exner Expert 10K+ Posts: 13050 Location: Southern Sweden - Sturkö island | Aaah - I thought you meant the "rear end" as in rear body - I saw a terrible sight before my Eyes Edited by wizard 2015-03-07 12:04 PM | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | 59finnedwarrior - 2015-03-06 7:44 PM Back in the 80s I was looking at a row of Aspen/Volares in a junkyard & noticed that the /6 stick cars had 8 1/4 & the 318/904s had 7 1/4. I think that was because of the shock/jolt that can be inflicted dropping a clutch on a stick vs an A/T. You might look for an 8 1/4 unless the 2001 had a 7 1/4 or equivalent.Magnum V-6 with a 5 speed out of a 2001 Dodge truck | ||
Expert Posts: 3778 Location: NorCal | '89 Fifth Avenue could have either the 7 1/4" or 8 1/4" depending on the motor, it would be wise to determine which one you have before making plans to swap it in. The 8 1/4" would be OK for your engine/trans combo especially considering the rear end will have a low numeric axle ratio...well suited for the NV3500 with its 4.02 first gear. | ||
59finnedwarrior |
Extreme Veteran Posts: 301 Location: Alberta Canada | thanks for all the feedback-I'm thinking the most logical solution is to keep the stock rear end because the car was a 318 poly manual trans car so the rear end could clearly handle the V-6 Magnum torque. | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | 59finnedwarrior - 2015-03-08 4:38 PM Many want to go modern for ease of brake work....thanks for all the feedback-I'm thinking the most logical solution is to keep the stock rear end because the car was a 318 poly manual trans car so the rear end could clearly handle the V-6 Magnum torque. | ||
Expert Posts: 3778 Location: NorCal | Yeah, the issue with the '59 rear end isn't strength, it's brakes....when you swap out the original transmission you're left with no parking brake. | ||
Resurrector |
In your case I'd say stick with the stock rear axle, as much as a pain in the arse as they are- because a lot of the 5th ave's came with 2.26 gears! Way, way too high speeded with OD. However, I've found the 2.26 to be perfect for a non-overdrive trans and a torquey V8. 1900 rpm with stock sized tires at 60 mph! I've had good luck with those newer rear ends as long as you don't beat it up racing and such. | |||
