another 1960 Chrysler appeared Jump to page : < ... 7 8 9 10 11 12 13 14 15 16 > Now viewing page 13 [50 messages per page] | View previous thread :: View next thread |
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | My Letter (body wise) has holiday season for few weeks. Happy Restoring! Dieter | ||
Expert 5K+ Posts: 5006 | theres no holidays in car restoration... get on the internet and order parts! | ||
Expert 5K+ Posts: 9905 Location: Lower Mainland BC | mikes2nd - 2021-08-01 6:30 AM theres no holidays in car restoration... get on the internet and order parts! Except Dieter is in Europe and most of Europe goes on holiday for the month of August. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Today I was in the shop... The illumination of the shop is improving actually. I did refill the rh rear tire (completely flat). In the paint booth is an AMG GTS (with all body parts removed) to get a new paint shop. In front of the booth bumpers, hood, doors, front fenders and hatch lid with a fresh coat of primer and marker coat . The AMG GTS.... from a guy with a very thick wallet (originally with a foiling applied - another shop removed the foiling (the only question mark from my side is why didn't they remove the windshield as well?), the owner got rid of the like of the foiling surface, now.... a completely new layer of paint - apparently a very lucrative job...). This is the reason, my project stalls. Happy Restoring! Dieter BTW: I don't buy anymore parts in advance... no space anymore in my house | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | This morning I was at the body and paint shop. The detailing work on the trunk lid has started. The very skilled body worker from Turkey did remove some minor dents from the sand blasting. With the owner of the body and paint shop I discussed the further work on the trunk lid (especially the bowl under the ornament). Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | di_ch_NY56 - 2021-05-16 5:19 PM The first trial with the 2001 Dodge Neon CV boot 614-001 at the temporary wrong propeller shaft mounted for break in and power test of the engine. The brows in the case I shaved with a small, round rasp. I used silicone oil instead of grease. But I was able to work the boot through the case with loads of patience and no #@*&^%. I still hope I'll get a 1658 931 or 1658 933 propeller shaft from Williams CA, 95987 Happy Restoring Dieter BTW: other members here will discover immediatly what fault I did.... (;) Big thanks to Big M. I got the the emergency brake drum and the propeller shaft. this early morning I unpacked both parcels and discovered.... both propeller shafts are identical. The diameter of the flange of the B/T-housing is identical. Later on.... I'll cleaning the b/t-housing and will look how the state of the inside of the housing is. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | B/T-state: the case inside looks very promission, one roller is stuck, both gliding shoes show almost no wear. This morning is was at the painter and body shop. Both front fenders are in work again. The passenger side front fender needs a bit adjustment due to the more than discutable body work in the first shop (the paint&body-shop owner said, his employee was working for hours on the outside line of the passenger side front fender). Happy Restoring! Dieter BTW: note the very careful installation of the front fenders Edited by di_ch_NY56 2021-09-18 9:51 AM (IMG_9122 front fender pair in work view from right hand side.JPG) (IMG_9123 front fender pair in work view from left hand side.JPG) Attachments ---------------- IMG_9122 front fender pair in work view from right hand side.JPG (380KB - 217 downloads) IMG_9123 front fender pair in work view from left hand side.JPG (356KB - 210 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | I managed to work away the roller and needle bearing on the propeller shaft from Big M (only one side was difficult). I noticed that the inside washer on one side was partially eaten up (the side the roller and needle bearing went away with no problem, one needle was missinig). Visible from eye and took the vernier caliper (metric) to measure the offset of the pin... almost 1/8". Of course, not visible from the outside (assembled). So I guess I'm going to remove the center pin on both propeller shafts and use the b/t case from the "new" propeller shaft and the parts from the restoring kit (even though the cover doesn't have the "Detroit" embossing) and the existing original propeller shaft w/o the pin and b/t case. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | This morning once again I visited the body and paint shop. The picture was taken at the beginning of my stay there. But almost at the end of my visit, the trunk lid has been finished to the state to get a fresh coat of primer. The work on the hood just started (few spots are very coarse due to the heavy sand blasting and will need some filler - but really all rust has been removed). The body is almost finished as most other parts as well. Happy Restoring! Dieter (IMG_9196 trunk lid on work.JPG) Attachments ---------------- IMG_9196 trunk lid on work.JPG (419KB - 196 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Yesterday I went to the body and paint shop to replace the cv axles on my very high milage V50 and installed new Taiwanese fog lamps (the glass on both fog lamps were beyond polishing). The owner showed me the trunk lid (even the border of the inner bowl and the skin is open again - just the absolute minimum of filler used). The hood is in the paint booth and looks georgous with primer coat. The outer skin of both front doors are on the last step of preparing. The owner and his employee (very skilled and very efficient - former Stadler Rail locomotive and carriage painter - he does a very good job). The owner of the paint and body shop asked for a 50% pre payment - for sure he'll get it. Next saturday a first sample (quite big piece of sheet metal he announced) will be painted with the top coat to show it to me. As noted ways earlier here, he got the original formula of the color to mix it with a contemporary paint brand (most probalbly PPG). I got a quite accurate estimation of the delivery date: spring 2022 (end of March). At the engine restoreres (I did a phone call recently) he announced to do a phone call just prior Christmas Season. At that time the engine block still was at the engine block machining company. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Pictures to the last entry. In the meantime the door outer skin on both front doors is almost finished as well. Happy Restoring! Dieter (IMG_9249 hood.JPG) (IMG_9250 trunk lid almost finished.JPG) (IMG_9251 both doors.JPG) Attachments ---------------- IMG_9249 hood.JPG (409KB - 192 downloads) IMG_9250 trunk lid almost finished.JPG (332KB - 199 downloads) IMG_9251 both doors.JPG (333KB - 195 downloads) | ||
Expert 5K+ Posts: 5006 | looking good, its all downhill now... | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | mikes2nd - 2021-10-30 3:49 PM looking good, its all downhill now... Thank you Mike In the meantime the trunk lid and one door got the fine primer layer. When the owner has time he'll do a further progress on the body (grinding the primer layer to the half thickness), first inside the fin on the passenger side from the door opening to the tail, than the quarter panels. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | This morning I was at the body and paint shop once again. One door will get fine filler and a grinding job again. The hood is under a grinding job again. The work on the body did resume on a very small amount until the tire change season (Summer to Winter) has passed. The owner of the body and paint shop showed the first sample painted in the formula he got from a door handle polisher from PPG (WW1 Alsakan White, Polar White, Sable White, Oyster White, White White White (Golss)) with contemporary indigrients (already at least one car has been painted with this color formula somewhere on the Earth). We did look at the sample under foggy sky. The color is a warm cream white, a little bit more than the Mercedes Classic White (a car ahead of me, when I drove home). I guess my Letter will look gorgeous with that color (two layers and a glaze layer (as he used on a Pearl Yellow metallic AMG GTS coupe)). Happy Restoring! Dieter Edited by di_ch_NY56 2021-11-13 1:51 PM | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | The first three parts got the first layer of the final color. These are the inside of the doors and the hood inside. Next week the inner side of the trunk lid, the front fenders and the complete inner structure of the front clip will be painted in the same color (Alaskian White - original formula as I did mention earlier). The color in nature looks gorgeous. Happy Restoring! Dieter Edited by di_ch_NY56 2021-12-11 7:03 AM (IMG_9381_doors and hood.JPG) (IMG_9382_close up view.JPG) Attachments ---------------- IMG_9381_doors and hood.JPG (339KB - 177 downloads) IMG_9382_close up view.JPG (444KB - 183 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Very nice Dieter! | ||
22mafeja |
Elite Veteran Posts: 655 Location: Finland | I am happy for you Dieter...it seems to be top quality. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Few parts got the final paint, not in picture are radiator yoke, hood latch beam, lower end profile, vertical reinforcement, inner front fenders. At the body, the passenger side fin got a fine grinding (ready now). The rear wall of the trunk got the final touch up. Under discussion is the very, very low recession around the trunk lock opening. The boss of the body and paint shop would like to egalize the small imperfection (in his eyes). Resting are both side walls (quarter panels) to get the fine touch. Next week over the boss will spend his (highly deserved) Season Holidays until New Year with his family. So further progress next year. Happy Restoring! Dieter (IMG_9406 hood.JPG) (IMG_9405 drivers side door.JPG) (IMG_9404 trunk lid.JPG) (IMG_9407 body rear end on work again.JPG) Attachments ---------------- IMG_9406 hood.JPG (358KB - 169 downloads) IMG_9405 drivers side door.JPG (341KB - 163 downloads) IMG_9404 trunk lid.JPG (292KB - 176 downloads) IMG_9407 body rear end on work again.JPG (498KB - 161 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | This is going to be a very beautiful car with a high professional paint work. The "down-side" is that all chrome should be in very nice condition as well. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2021-12-17 4:30 PM This is going to be a very beautiful car with a high professional paint work. The "down-side" is that all chrome should be in very nice condition as well. Thank you Sven Spot on The weak point on my Letter is all the chrome and stainless steel parts. I know a guy who could (as he would) do that in his free time as he did it for his own car. I guess everybody here knows that the weak point on cars of that area is the pot metal (internal corroding). That is the reason, why my project takes sooooooooo long... (in time). Happy Restoring! Dieter Edited by di_ch_NY56 2021-12-18 11:15 AM | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Yes Dieter, all the stainless can be straightened and polished to a spendid result. The pot metal is a real drag and very expensive work. Mount the best you have and work on the spare ones | ||
Expert 5K+ Posts: 5006 | yeah restoring these cars take forever... but amazing work. | ||
34 Airflow |
Veteran Posts: 217 Location: Echuca | Progress is progress, the car is looking great and I'm sure the end result will be worth it! | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Big thanks for all comments. Yesterday, late evening I got a set of pictures from the boss of the paint and body shop. I didn't mention it to him, but for me he's like a friend. The boss now is gonna enjoy his well deserved Christmas Holiday until January 1st 2022. He's working as a bee (underestimated). Big thank you to the boss of the paint and body shop. Happy Restoring! Dieter (IHNN2590 passenger side fender front top view.JPG) (OJAT5867 overwiew paint booth with drivers side fender.JPG) (WBCR7826 hood inside trunk lid inside both doors inside (top view).JPG) (ETVV0767 hood inside.JPG) (IMWY2327 drivers door inside and some more parts.JPG) Attachments ---------------- IHNN2590 passenger side fender front top view.JPG (303KB - 173 downloads) OJAT5867 overwiew paint booth with drivers side fender.JPG (478KB - 181 downloads) WBCR7826 hood inside trunk lid inside both doors inside (top view).JPG (269KB - 172 downloads) ETVV0767 hood inside.JPG (281KB - 165 downloads) IMWY2327 drivers door inside and some more parts.JPG (354KB - 176 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | That's like Christmas gifts, all hard boxes just like we like. Well, Merry Christmas Dieter | ||
22mafeja |
Elite Veteran Posts: 655 Location: Finland | Looks incredible...but you need a lot of "safe" space to store these goodies in before they sit on the car. | ||
60Mopars |
Member Posts: 43 Location: Småland Sweden | Great work, better than when new. Merry Christmas! | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Merry Christmas to all of you. Big thank you for your wishes. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Happy New Year to everybody! I went to the barn to seek for the arm rests ontop of the center console. Finally I got em. The screws at the pivot of the rear arm rest are frozen. The vent windows will have some work as well. Main point is the broken adjuster screw holder at the drivers side. It was already broker prior to remove it from the door. Happy Restoring! Dieter (IMG_9477 center console front piece.JPG) (IMG_9478 center console rear piece.JPG) (IMG_9479 vent window door window channel both vent windows.JPG) (IMG_9481 vent window lower adjuster base broken.JPG) Attachments ---------------- IMG_9477 center console front piece.JPG (361KB - 156 downloads) IMG_9478 center console rear piece.JPG (375KB - 159 downloads) IMG_9479 vent window door window channel both vent windows.JPG (293KB - 168 downloads) IMG_9481 vent window lower adjuster base broken.JPG (192KB - 164 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | The best tool for loosen frozen bolts/nuts is an induction heater. I bought one for roundabout $400 and it works like a dream, no open flame, only induction heat instantly. Here's some examples https://www.amazon.com/induction-heater/s?k=induction+heater Here's my heater https://www.biltema.se/en-se/tools/electric-tools/screwdriver/induct... | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2021-12-31 11:09 AM The best tool for loosen frozen bolts/nuts is an induction heater. I bought one for roundabout $400 and it works like a dream, no open flame, only induction heat instantly. Here's some examples https://www.amazon.com/induction-heater/s?k=induction+heater Here's my heater https://www.biltema.se/en-se/tools/electric-tools/screwdriver/induct... I got the two UNF 10-32 x 7/32" screws of rear hinge band out with WD40 and loads of pressure to the PH2-screwdriver. The structure is made out of a 3D fibreglass structure. Fortunately I still have a very nice catch up stainless steel rope with the white isolation like cover around it on the front arm rest as Bob in a video (YouTube) described. Happy Restoring! Dieter Picture: inside the front arm rest... with a part of the underside of the cover (quite thick faux leather, light tan colored)
(IMG_9489 inside the front arm rest.JPG) Attachments ---------------- IMG_9489 inside the front arm rest.JPG (294KB - 159 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | https://www.youtube.com/watch?v=2rZEyXhVshs https://www.amazon.se/Svart-Flock-fibrer-sqm-instrumentbr%C3%A4dor/d... A good alternative perhaps? First glue, then the flock fibre | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Thanks Sven I'm going to ask the painter if he knows a shop in Switzerland who does that procedure glue and flocking. For me myself it's ways beyond my possibilities at home. I guess the same procedure was applied duriing the production time. The only way I can do myself is model railway powder (black) and a glue out of a rattle can. Anybody here with an alternative way? Happy Restoring! Dieter | ||
Expert 5K+ Posts: 5006 | Liquid wrench work 100 times better than WD40... only way to go, beats em all, even kroil and PB | ||
Expert 5K+ Posts: 9905 Location: Lower Mainland BC | di_ch_NY56 - 2022-01-02 8:15 AM I'm going to ask the painter if he knows a shop in Switzerland who does that procedure glue and flocking. For me myself it's ways beyond my possibilities at home. I guess the same procedure was applied duriing the production time. The only way I can do myself is model railway powder (black) and a glue out of a rattle can. Anybody here with an alternative way? Dieter: In North America, there is (or was) a contact paper (sticky glue on one side with a peel-off cover paper) that was black flocked on the upper side. You might check hobby shops for that. Fabric stores here in North America will typically carry a low "nap" (fibre height) black velvet or "velvetine". I have used that for a few house projects (back side of display cabinet). I think I used spray glue. Just some ideas. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | 56D500boy - 2022-01-02 4:22 PM di_ch_NY56 - 2022-01-02 8:15 AM I'm going to ask the painter if he knows a shop in Switzerland who does that procedure glue and flocking. For me myself it's ways beyond my possibilities at home. I guess the same procedure was applied duriing the production time. The only way I can do myself is model railway powder (black) and a glue out of a rattle can. Anybody here with an alternative way? Dieter: In North America, there is (or was) a contact paper (sticky glue on one side with a peel-off cover paper) that was black flocked on the upper side. You might check hobby shops for that. Fabric stores here in North America will typically carry a low "nap" (fibre height) black velvet or "velvetine". I have used that for a few house projects (back side of display cabinet). I think I used spray glue. Just some ideas. :)Dave: big thank you for your hint. At epain I got "Self-Adhesive Velvet Flock Contact Paper Liner for Jewelry". I assume that's exactly what it was rolling off the assembly line (my F). During the journey this morning with my V50 under the cover (middle arm rest like) is a bin with exactly the same finish. Very kind to touch it. I guess prior, clean the bin with thinner and smoothen it. Happy Restoring! Dieter Edited by di_ch_NY56 2022-01-03 2:43 PM | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | What do you think about that "Tan Light Parchment Vinyl Upholstery Fabric Durable Grade Vinyl Fabric by Yard"for door panels (base) and arm rest (two sewing lines at the outer edges). I was looking at epain.us I was seeking for "light tan vinyl fabric". Happy Restoring! Dieter Edited by di_ch_NY56 2022-01-03 10:49 AM | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | Hi Dieter, Not picking , but something looks odd on the body line here, it may just be the light? (20210528_092131 marker layer all over as I met my Letter~2.jpg) Attachments ---------------- 20210528_092131 marker layer all over as I met my Letter~2.jpg (196KB - 168 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | springsweptwing - 2022-01-02 5:15 PM Hi Dieter, Not picking , but something looks odd on the body line here, it may just be the light? Sad, you couldn't visit my Letter in natura. From looking again at the picture, the odd looking body line (your words) are exactly where the sun ray beam is on the floor. Saturday before Christmas Season I saw my Letter wet (silicone remover) and we inspected the lines both, the Boss of the Body and Paint shop and me. Nothing odd at all. Kind regards Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | I wrote down three orders (with an order date) for that year for Quirey Quality Design. Plus the order date for the ordering of the windshield, a NAGS W590, green, with smoke band. Preferred is the windshield direct from Finnland (or North European Country), instead of a detour over California. Corresponding to the expectable progress at my Letter. Happy Restoring! Dieter BTW: the red circle is not with no reason. At that area the surface is more coarse than the rest. But it will become as smooth as the rest of the Letter. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Today I sorted some parts and put a label with the content to the card box of parts of my Letter. The bags with the rubber ends of the B post and door end fell into my sight. One carrier was rusted away. So I made a card paper template. I assume the carriers were made out of spring steel. For the lower end of the front glass run channel (was broken off prior the removing from the door) I'm asking the guys I know from earlier for help to repair the adjuster beam. Happy Restoring! Dieter BTW: I know the vacuum canister still is not ready to install (some work with a steel rasp, further removing of loose rust (lower end of the mounting frame is welded on) and smoe more). Edited by di_ch_NY56 2022-01-09 9:00 AM (IMG_9496 vacuum canister brushed.JPG) (IMG_9509 vacuum canister repaired.JPG) (IMG_9511 rear door end and b pillar rubbers.JPG) (IMG_9481 lower adjuster of the glass run channel and vent window frame at the drivers side.JPG) Attachments ---------------- IMG_9496 vacuum canister brushed.JPG (392KB - 165 downloads) IMG_9509 vacuum canister repaired.JPG (273KB - 153 downloads) IMG_9511 rear door end and b pillar rubbers.JPG (323KB - 155 downloads) IMG_9481 lower adjuster of the glass run channel and vent window frame at the drivers side.JPG (192KB - 167 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | I did use 400 grit wet sanding paper to clean the vacuum canister. It got the first layer of epoxy rust inhibitor. From the engine restorer I got good news... the cylinder grinder did start working on the engine. Everything okay so far was his comment (the engine restorer visited the cylinder grinder shop). More within two weeks about the engine. Just a quite small final paying will follow (two prepayments confirmed on paper). Happy Restoring! Dieter | ||
22mafeja |
Elite Veteran Posts: 655 Location: Finland | Are you going to open up the can? It seems to be full of rust.. maybe I am wrong.. There is the possibility to shorten the can 1/2" or so and tig weld on a new bottom if the rust is on the bottom . | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | 22mafeja - 2022-01-10 6:24 AM Are you going to open up the can? It seems to be full of rust.. maybe I am wrong.. There is the possibility to shorten the can 1/2" or so and tig weld on a new bottom if the rust is on the bottom . I did shake the can. Just a minor amout of rust in the can. I assume I could let it, as it is. Now I'm going to apply stone chip resistant color to the can. Afterwards a layer, or two of satin black. Happy Restoring! Dieter Edited by di_ch_NY56 2022-01-11 3:41 AM | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | Hi Dieter, Those vacuum canisters are used on a few makes of vehicles, you may be better buying a new one and putting you're valve in it? You don't know how bad it is inside and will only develop more holes later. https://www.google.com/search?q=headlight+vacuum+canister&cl... Paul. Edited by springsweptwing 2022-01-11 8:37 AM | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | springsweptwing - 2022-01-10 2:33 PM Hi Dieter, Those vacuum canisters are used on a few makes of vehicles, you may be better buying a new one and putting you're valve in it? You don't know how bad it is inside and will only develop more holes later. https://www.google.com/search?q=headlight+vacuum+canister&client... Paul. Hi you're probably right. As described I did apply some stuff onto the vacuum bottle (canister)... Happy Restoring! Dieter (IMG_9518 vacuum bottle actual state.JPG) Attachments ---------------- IMG_9518 vacuum bottle actual state.JPG (271KB - 151 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Just install a plastic fuel filter in a hidden position. On the tube that goes to the engine. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2022-01-10 6:16 PM Just install a plastic fuel filter in a hidden position. On the tube that goes to the engine. I'll do it | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | Looks like there is a hole in the vacuum canister. You will have to do something with that or you'll have a vacuum leak causing a rough engine idle. (IMG_9518 vacuum bottle actual state.JPG) Attachments ---------------- IMG_9518 vacuum bottle actual state.JPG (64KB - 143 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | imopar380 - 2022-01-10 10:02 PM Looks like there is a hole in the vacuum canister. You will have to do something with that or you'll have a vacuum leak causing a rough engine idle. Hi Ian I did use a vacuum pump (manually driven) to check. This area is repaired with electronic thin and an electronic welding station. I pumped down to 15 in Hg Vac. It was keeping the vacuum and releasing it very, very slow prior to proceed the further restoration. Dieter | ||
