another 1960 Chrysler appeared Jump to page : < 1 2 3 4 5 6 7 8 9 10 11 ... > Now viewing page 6 [50 messages per page] | View previous thread :: View next thread |
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | These are both windshield wiper pivots. I arranged it like it were mounted on the firewall of my Letter. The RH pivot has the parts number, but the LH one looks really peculiar. Anybody knows where it's from? The length of the crank is (almost) identical as the mounting flange is from the length and width of the mounting plate. Dieter (IMG_3457_resized.JPG) Attachments ---------------- IMG_3457_resized.JPG (410KB - 521 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | To let the engine (413 HP?) restore at a professional restorer's (next year) I plan to purchase a low rise dual plane intake manifold plus a 600 to 750 cfm carb on it. It's because I would like to get a broken in engine (my wish). What do you think I could expect at the dyno /w the 300F camshaft and eventually matched intake and exhaust runners at the cylinder heads and eventually a stock 440 distributor? Happy Restoring! Dieter BTW: with this procedure I assume it's guaranteed that the engine would run /w the cross ram and the stock 2903s carbs mounted. Even though I have to retard the camshaft if not mounted like it was prior to the restoration. Edited by di_ch_NY56 2016-12-18 2:41 AM | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Today I removed the center link - not complete, but enough to move it away. Then I removed the oil pan. I'm sorry for the bad quality of the pictures. It was cold. Happy Restoring! Dieter (IMG_3480_resized.JPG) (IMG_3481_resized.JPG) (IMG_3496_resized.JPG) (IMG_3497_resized.JPG) Attachments ---------------- IMG_3480_resized.JPG (277KB - 519 downloads) IMG_3481_resized.JPG (300KB - 504 downloads) IMG_3496_resized.JPG (402KB - 513 downloads) IMG_3497_resized.JPG (487KB - 520 downloads) | ||
oldwood |
Expert Posts: 2905 Location: little rock, AR | This is what my '50 Buick oil pan looked like when I removed it. People don't realize what oil does after sitting for 30 years. (100_0393-med.jpg) Attachments ---------------- 100_0393-med.jpg (123KB - 497 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Happy New Year to all my friends First work in this year was to remove the #2 main cap at the engine. It was not looking promising. Then, after cleaning it, I mounted it again, but not with full torque at the bolts. Because of what I saw I decided to remove the cap # as well. The result in the babbit bearing cap was even worse. The broken out chips were stored at about 60 degree CW. I cleaned the parts and mounted that cap too. Time to remove the engine now. From what I saw, the hex nuts of the cap #5 are not accessible with a hex socket... Happy Restoring! Dieter BTW: I just noticed for the cap #5 that first I have to remove the holder of the rear crankshaft seal... Edited by di_ch_NY56 2017-01-03 1:23 PM (IMG_3541_resized.JPG) (IMG_3542_resized.JPG) Attachments ---------------- IMG_3541_resized.JPG (138KB - 504 downloads) IMG_3542_resized.JPG (240KB - 509 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | It could be that the bearings at the crankshaft were overheated most probabely due to the lack of lubrification. But now the engine is almost ready to remove. I'm organising two assistant people locally to remove the hood first. Happy Restoring! Dieter (IMG_3543_resized.JPG) Attachments ---------------- IMG_3543_resized.JPG (435KB - 505 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Today I removed the hood and finally the engine. The removal of the hood was not state of the art (truck driver should know what's wrong), but I was all alone. All bolts of the torque converter housing are removed, but the housing sticks. Happy Restoring! Dieter (IMG_3550_resized.JPG) (IMG_3552_resized.JPG) (IMG_3553_resized.JPG) (IMG_3556_resized.JPG) Attachments ---------------- IMG_3550_resized.JPG (381KB - 504 downloads) IMG_3552_resized.JPG (444KB - 527 downloads) IMG_3553_resized.JPG (400KB - 507 downloads) IMG_3556_resized.JPG (426KB - 522 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | A little bit work over the last few days.... (IMG_3582_resized.JPG) (IMG_3580_resized.JPG) (IMG_3597_resized.JPG) Attachments ---------------- IMG_3582_resized.JPG (73KB - 508 downloads) IMG_3580_resized.JPG (387KB - 493 downloads) IMG_3597_resized.JPG (330KB - 502 downloads) | ||
58coupe |
Expert Posts: 1740 Location: Alaska | It is amazing how much better the detergents are in the newer oils, ( I assume). I have pulled newer engines apart with over 200,000 miles on them and they are so much cleaner. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Rolland you're right, but for modern oils a flat bottom tappet engine needs ZDDP additive for sure. Today again I did a little bit of work. My project is moving slow, but steay like a slug
Dieter (IMG_3601_resized.JPG) (IMG_3602_resized.JPG) (IMG_3603_resized.JPG) Attachments ---------------- IMG_3601_resized.JPG (452KB - 504 downloads) IMG_3602_resized.JPG (429KB - 517 downloads) IMG_3603_resized.JPG (421KB - 502 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | The crankshaft out of the engine of my Letter Dieter (IMG_3608_resized.JPG) Attachments ---------------- IMG_3608_resized.JPG (498KB - 486 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | This afternoon two employees of an engine restoration company are coming to pick up my engine to restore. I'm happy! Happy Restoring Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Since late afternoon 01/22/2017 the engine of my Letter is at the engine restorer's. On 01/25/2017 I visited the company and had a sight of a very good company. My engine is again in a mounting stand and the drivers side cylinder bank is upright. There is special fluid on top of the piston #1. I told the boss that when the piston is out, I'll visit them again. Happy Restoring! Dieter | ||
Expert 5K+ Posts: 5006 | that was quick! | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | This afternoon I wanted to buy a spray can of Cummins Apex red to paint the cross rams. But I got a notification that the company cannot ship the can overseas. So I have to chase for another solution. Is there a color close to Cummens Apex red in the RAL chart? Happy Restoring Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | mikes2nd - 2017-01-26 4:22 PM that was quick! Thanks Because this company is very good in modifying and calibrating engines I do not get angry when my engine comes back with more torque and horse power than addressed by the technical sheet of Chrysler. The boss showed and told me about Aston Martin engines, stroked and bored (4.3 to 5.0, and the old Aston Martin, 5.3 V8 (https://en.wikipedia.org/wiki/Aston_Martin_V8) with a block at least as big as the RB engine), a modified V12 Aston Martin engine (all aluminum with surface in the cylinder bores of Sulzer Metco), a 361 under restoration (pistons and camshaft already installed) and a finished 340 LA engine where they could organize a new 340 block (very rare block he said). Happy Restoring! Dieter BTW: the boss told me that the contemporary fuel has a faster burning velocity than the old leaded gas. So the engines need a modified ignition calibration. He recommended Swiss 98 Octane for my Beast as well. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Yesterday afternoon, evening and this morning I was cleaning the complete throttle linkage from the throttle pedal to the carburetors. Now all screws and hex nuts are moving free like new ??. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | I just wonder... I want to remove the fresh air cut off plate of the allweather heater system in my Letter. Of course I do not want to destroy the plate. Anybody an idea how to remove it without destroying either the rubber (still in good, soft condition), the shaft or the body. Any suggestions are welcome. Thank you very much. Happy Restoring! Dieter (IMG_3093_resized.JPG) (fresh air cut off plate.jpg) Attachments ---------------- IMG_3093_resized.JPG (217KB - 494 downloads) fresh air cut off plate.jpg (121KB - 485 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | I noticed after a further investigation, that the pivot point is not a going through shaft from one holder (welded at the firewall) to the other one. But a pin, about the length of an inch. Happy Restoring! Dieter (IMG_3640_resized.JPG) (IMG_3641_resized.JPG) Attachments ---------------- IMG_3640_resized.JPG (308KB - 504 downloads) IMG_3641_resized.JPG (322KB - 491 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Look my friends, A big stone (rock size) will fall down from my heart when the body is straight and all rust issues have gone. All other subjects are - compared to the body - just peanuts for me. Happy Restoring! Dieter | ||
Adventurer 60 |
Elite Veteran Posts: 827 Location: tailFinland | If I remember right, he other pin goes in to cut of plate wehwn you bush it. You have to lubricae it first with WD40 or such aerosol oil. Perhaps you have already noticed it by now | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Hi Jari Thanks a lot. The air shut off plate is already out of my Letter. I used a blade screw driver and drove the passenger side pin back. I noticed that on each side there's a felt washer to inhibit noises. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | At the moment the brake booster, canister type, is in my barn and I'm working on. I cleaned the canister outside and inside, all the rubber parts between the piston perimeter and the bottom of the canister are good. But after assembling (I didn't separate the piston rod and cover plate) I noticed that there is a slight leakage at the piston rod gasket around the piston rod...
Happy Restoring! Dieter BTW: second trail: when I apply vacuum and the trigger Nylon button is pressed in, the vacuum is steady. At that time when I release the button, the fork moves out quite quick, but not for a long time - it moves back slowly. I assume this is normal, isn't it? When I apply the Nylon button again when the fork is out (brake assisting mode) the fork moves back quite fast. My careful consideration was, that when I release the brake pedal the Nylon button will be applied again. Edited by di_ch_NY56 2017-04-17 1:08 PM (IMG_3857_resized.JPG) (IMG_3858_resized.JPG) Attachments ---------------- IMG_3857_resized.JPG (308KB - 466 downloads) IMG_3858_resized.JPG (432KB - 474 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Yesterday night I performed a really small work. All alone I pressed out the windshield and the rear window. For that I layed with my back on the floor and used my feet to press at the top (alternating left side, right side) until the glass was out of the weatherstrip or the weatherstrip away from the surrounding body lip. Now resting is about one labor day of work: the fragments of the old exhaust system, the fuel line and the brake lines. Happy Restoring! Dieter (IMG_3980_resized.JPG) Attachments ---------------- IMG_3980_resized.JPG (300KB - 460 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | A really big rock will fall down from my heart, when the body is fully restored, painted and ready for the assembling process. I catched the most important areas (beside the rear wall of the trunk and partially the trunk floor) with pictures to show it to you and eventually getting a quote or an offer where to bring the body to. Happy Restoring! Dieter BTW: in my eyes it makes ways more sense first to restore the body and following the engine to mount it into the fully restored body at any time. (IMG_3983_c-pillar_LH_rear.JPG) (IMG_3984_c-pillar_LH_from_outside_top.JPG) (IMG_3985-c-pillar_LH_from_LH_side.JPG) (IMG_3991_c-pillar_LH_inside_quite_ok.JPG) (IMG_3992_c-pillar_LH_inside_ok_from_quarter_window_sight.JPG) (IMG_3989_rear_window_frame_box_still_here_1_LH.JPG) (IMG_3990_rear_window_frame_box_still_here_2_LH.JPG) (IMG_3986_rear_window_frame_box_gone_1_RH.JPG) (IMG_3987_rear_window_frame_box_gone_2_RH.JPG) (IMG_3988_rear_window_frame_box_gone_3_RH.JPG) (IMG_3995_RH_door_rust_through_front_lower_corner.JPG) (IMG_3996_RH__door_front_structure_frame_rusting_through_from_rear.JPG) (IMG_3997_RH_door_front_structure_frame_rusting_through_front.JPG) (IMG_3993_RH_front_accident_fender_bent_cowl_bent.JPG) (IMG_3994_RH_front_accident_fender_bent_headlight_low_pointing_weird.JPG) Attachments ---------------- IMG_3983_c-pillar_LH_rear.JPG (314KB - 461 downloads) IMG_3984_c-pillar_LH_from_outside_top.JPG (335KB - 473 downloads) IMG_3985-c-pillar_LH_from_LH_side.JPG (391KB - 454 downloads) IMG_3991_c-pillar_LH_inside_quite_ok.JPG (258KB - 453 downloads) IMG_3992_c-pillar_LH_inside_ok_from_quarter_window_sight.JPG (253KB - 471 downloads) IMG_3989_rear_window_frame_box_still_here_1_LH.JPG (388KB - 450 downloads) IMG_3990_rear_window_frame_box_still_here_2_LH.JPG (209KB - 497 downloads) IMG_3986_rear_window_frame_box_gone_1_RH.JPG (282KB - 457 downloads) IMG_3987_rear_window_frame_box_gone_2_RH.JPG (305KB - 449 downloads) IMG_3988_rear_window_frame_box_gone_3_RH.JPG (282KB - 459 downloads) IMG_3995_RH_door_rust_through_front_lower_corner.JPG (167KB - 452 downloads) IMG_3996_RH__door_front_structure_frame_rusting_through_from_rear.JPG (111KB - 457 downloads) IMG_3997_RH_door_front_structure_frame_rusting_through_front.JPG (265KB - 458 downloads) IMG_3993_RH_front_accident_fender_bent_cowl_bent.JPG (135KB - 442 downloads) IMG_3994_RH_front_accident_fender_bent_headlight_low_pointing_weird.JPG (247KB - 458 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Great going Dieter! I don't think that Jan Fridberg reads all posts here on the forum, try to send him a link - now he can see better the state and the worst damages. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2017-05-27 4:21 PM Great going Dieter! I don't think that Jan Fridberg reads all posts here on the forum, try to send him a link - now he can see better the state and the worst damages. Thanks dear friend, I assume it's sunny clear that I'm not keen to pay hourly wages of almost sFr. 100.- or more like here in the ridiculous expensiv Switzerland. Take care and Happy Restoring Dieter BTW: I'm earnestly thinking about leaving my home country for ever | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Today I removed the brake lines at the front sub frame, the junction block and the brake line to the rear axle. Happy Restoring! Dieter BTW: resting are - the brake line on the rear axle - the fragments of the exhaust system - the fuel line | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Congratulations Dieter. The rust looks relatively minor. You may want to purchase a mig welder and start practicing so you can fix most of that yourself. It is a great skill to have and doesn't require a lot of effort to become reasonably good at it. The large flat panels are the hardest to prevent from warping, so leave the outer door to a pro. But the small holes on the inner sheet metal are great places to get started on yourself. Unfortunately, California isn't much better than $100/hr. You are lucky to find a place that will work for $70/hr. and the quality isn't a guarantee. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Look, I made two promisements to a) my mum not to run into depts because of the project and b) to the landlords to get the place in the barn, not to weld in the barn, mostly made out of wood.. So I have to leave ok for another option for the body. I beg your pardon. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | On Saturday I was able to catch the radio at the local post office. It works perfect with a cristal clear sound in he DAB mode. Big thank you to Hemidenis for his astonishing effort to bring my radio back to live. I know we both went through a nightmare many times during the long time we worked together. Finally the radio project went very successful. Big thank you again for Hemidenis. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | This afternoon I mounted the hood all alone (a very dangerous action all alone ). After mounting I cleaned the perimeter (roof, A pillars and bottom) of the windshield opening. Neither the rear window opening nor the windshield opening (seam to mount the corresponding weatherstrip) are rusty. All around the color is nice at the seam... So I just need to remove the gas line and the isolation mat inside (passenger compartment) at the firewall. Happy Restoring! Dieter (IMG_4103_overwiew actual.JPG) Attachments ---------------- IMG_4103_overwiew actual.JPG (442KB - 434 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | You've done a lot now Dieter, soon time for to fix the rust issues. I would suggest a final check-up of all the documentation you've done so that all is ready for the mounting when that time comes. I always think that I have enough photos and documentation, but then Murphy prooves me wrong | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Thank you very much Wizard for your encouraging words. In the mean time (to be precise, today ) I got a new contact at FB from Morgan Johansson, William Svensson living in Malung SWE as well as Jan Fridberg. William restored his 300G and Morgan proposed him to me as a master. So we discussed many things and I provided William some actual pictures. Actually we are discussing the transportation and who'll do the paint job. Except of the damage of the passenger rear wheel well and the windshield (I have to organise a new windshield myself, tinted (original color) with a smoke band at the top preferred) William got all these pictures plus some older ones as well. Happy Restoring! Dieter Edited by di_ch_NY56 2017-07-09 10:31 AM (IMG_4124_crack in the windshield got bigger.JPG) (IMG_4125_drivers side rear corner rear view.JPG) (IMG_4126_drivers side rear corner side view.JPG) (IMG_4128_c pillar drivers side.JPG) (IMG_4129_holes in the rear section of the trunk floor passenger side.JPG) (IMG_4130_front view with damage at passenger side.JPG) (IMG_4131_top view with glass removed.JPG) Attachments ---------------- IMG_4124_crack in the windshield got bigger.JPG (245KB - 435 downloads) IMG_4125_drivers side rear corner rear view.JPG (283KB - 433 downloads) IMG_4126_drivers side rear corner side view.JPG (313KB - 442 downloads) IMG_4128_c pillar drivers side.JPG (311KB - 430 downloads) IMG_4129_holes in the rear section of the trunk floor passenger side.JPG (144KB - 438 downloads) IMG_4130_front view with damage at passenger side.JPG (257KB - 433 downloads) IMG_4131_top view with glass removed.JPG (278KB - 426 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | I got the message from Magnus Stade, that my steering wheel of my Letter is restored. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | I got a wonderful message from my friend in Sweden. The steering wheel has arriven. As an evidence I got pictures. Big thank you to Magnus Stade who restored the steering wheel from my Letter. It looks so wonderful and an evidence of a superb craftmanship. I assume when my Letter is ready to do the first test ride, from then on I'll carry a terry towel in the footroom behind the drivers seat to cover the steering wheel and the dash pad (to purchase, on my wish list) when my Letter will be on a car meeting or a parking lot under free sky. Happy Restoring! Dieter BTW: very slow but steadily progress at my project. (IMG_2142_restored steering wheel.JPG) Attachments ---------------- IMG_2142_restored steering wheel.JPG (447KB - 420 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | This afternoon I removed the ornaments of the flite sweep decklid I got from Charlie (but not without a damage cause by a employee of Fedex). I used the vacuum cleaner to remove the baken dust and a thin welding wire (rust free) to free the drain tube. It was very humid between the deck lid recession and the hub cap like ornament. I think this area needs a special treatment of color type to resist the humid. Happy Restoring! Dieter (IMG_4271_decklid from tailfin - ornaments removed.JPG) Attachments ---------------- IMG_4271_decklid from tailfin - ornaments removed.JPG (375KB - 424 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | The bowl of the ornament has one (!) pin hole. That's not much. I discussed with a well known MoPar guy in Switzerland the restoration of the body of my Letter. We agreed a price (/wo transports, sand blasting, painting). But he knows a good sand blaster and a perfect painter team (two brothers) who treats a customers car like it would be their own. At the facility there are two cars that have to leave, so I got the prospective that within about one month my Letter will go to the facility of this guy. A big stone is falling down from my heart. The piston of the first cylinder is still in the block. I payed the first down payment to allow the work of a cylinder grinding shop. We'll see what the result will be. Happy Restoring! Dieter BTW: the roof rail weatherstrip I'll need for my 1960 Chrysler Hardtop is either W13 or W15 weatherstrip profile in conjunction of a set of #69 front ends of the Gary Goers catalog, page 38 (document cat10B)? Edited by di_ch_NY56 2017-09-17 10:46 AM | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | back on the wheels again, ready to transport my Letter to a restorer for the body work. Happy Restoring! Dieter
BTW: the stuff in front of my Letter is from another family. I more than complete house hold... Edited by di_ch_NY56 2017-10-14 7:10 AM (IMG_4366_back on the wheels again.JPG) Attachments ---------------- IMG_4366_back on the wheels again.JPG (320KB - 416 downloads) | ||
Expert 5K+ Posts: 5006 | going to be an amazing car when done. honestly it doesn't look that bad. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Great going Dieter! I bet you're very pleased that the car is ready for the rust repair works now! Think forward to the next stage of the works when you will start to mount all the Clean and renovated parts and units back in the car. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Now finally my Letter is at the restorer shop for the body restoring. There is a load of work to perform to bring my Letter back to the original condition (body wise). Because the body restorer is quite close to me (about 40 min driving with a car) I'll visit him frequently to look at the progress and discuss issues (not detected until now). Happy Restoring! Dieter
(IMG_4412_I'm waiting.JPG) (IMG_4415_going_to_the_body_restorer.JPG) Attachments ---------------- IMG_4412_I'm waiting.JPG (278KB - 402 downloads) IMG_4415_going_to_the_body_restorer.JPG (391KB - 417 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | A big step Dieter, I can imagine that this is a huge relief for you. Now it will be a long wait until you get your car back again, but then the fun part begins. Keep us posted! | ||
Adventurer 60 |
Elite Veteran Posts: 827 Location: tailFinland | I remember that stage nearly 5 years ago I did the bodywork in my own Garage at left "dirty work side" Edited by Adventurer 60 2017-10-29 5:15 PM (300g.jpg) Attachments ---------------- 300g.jpg (134KB - 434 downloads) | ||
Adventurer 60 |
Elite Veteran Posts: 827 Location: tailFinland | Is it going to be blasted and rotisserie? In my case it was all worth of it. I first started, lying on a floor and desperately trying to weld, cut and grind hoping good results... Then I drove 700 km and picked up the rotisserie that was made for F by the firend of mine , it was the best decission ever, doing body work has never been so fun (grillisssss.jpg) Attachments ---------------- grillisssss.jpg (139KB - 432 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Hi Jari: thanks a lot for your input. For sure I can imagine that it's ways easier to work at the body. But I do not perform the body work myself, but Emil and his body worker (a turkian guy working like a wizard). My Letter is on a two pillar automotive lift. At least they could walk upright under the body,. But they have to work above their heads, what could be tortouring after a long time with no break. Some pictures of the progress... the name of the file is speaking for itself.... I was just surprised of how much dirt accumulated on several places. As far as I got out, none of the 1960 cars was painted at the area above the mounting structure to the subframe... Happy Restoring! Dieter (IMG_4421_suframe RH side straight again.JPG) (IMG_4424_inside view RH front fender - reconstructed.JPG) (IMG_4430_cowl area with on fender - look how much dirt accumulated here.JPG) Attachments ---------------- IMG_4421_suframe RH side straight again.JPG (285KB - 405 downloads) IMG_4424_inside view RH front fender - reconstructed.JPG (271KB - 424 downloads) IMG_4430_cowl area with on fender - look how much dirt accumulated here.JPG (274KB - 400 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | The progress seems to go on in a steady way and the result looks good Dieter! Thanks' for posting all Pictures - a good help for the Chrysler '60 owners. Keep us posted. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Happy for you Dieter, my "old" friend Emil is doing this job for you at resonable costs and good SWISS quality (similar as Swedish!). Edited by sermey 2017-11-10 9:24 PM (2000-05-21 Emils Baby.jpg) Attachments ---------------- 2000-05-21 Emils Baby.jpg (120KB - 399 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | sermey - 2017-11-10 3:16 AM Happy for you Dieter, my "old" friend Emil is doing this job for you at resonable costs and good SWISS quality (similar as Swedish!). Thanks a lot Serge. Is the baby the sister or brother of Cheyenne (apparently the older daugher)? Take care, Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | This afternoon I met Emil again. Two guys were working at my Letter, but I didn't talk to them, just with Emil. A steady progress . I just showed Emil the rust damage at the front structure of the passenger door as a reminder not to forget. Emil explainded all work they performed this week. He didn't know what the recession (rain drainage) is for. I told him from my mind, that early 60 Chryslers had this recession instead of a tube drainage like e.g. Jari installed in his G. The rear reinforcement bar is bent back and all surrounding sheet metals replaced. The inner rocker and trunk floor section has been replaced because all these parts were crushed by an accident. At this pictures you'll notice the rear end of the 300 H Cheyenne is restoring (I asked Emil for the name of his daughter). Next Saturday I'm going to remove the tar proctection in the passenger room and at the underside of the passenger floor.... I promised it. I think the names of the pictures are explaining enough now. If not just PM me. Happy Restoring! Dieter (IMG_4446_passenger rear quarter view.JPG) (IMG_4447_rear view with the H of Cheyenne.JPG) (IMG_4448_driver side rear undercarriage, accident damage repaired.JPG) (IMG_4449_drivers side front, quarter lower section, repaired.JPG) (IMG_4450_drvier side rear, accident repaired.JPG) (IMG_4451_passenger side rear detail, rain drainage.JPG) (IMG_4452_the thrash can is filling quite quick, part 1.JPG) (IMG_4453_the trash can if filling quite fast, part 2.JPG) Attachments ---------------- IMG_4446_passenger rear quarter view.JPG (326KB - 407 downloads) IMG_4447_rear view with the H of Cheyenne.JPG (426KB - 407 downloads) IMG_4448_driver side rear undercarriage, accident damage repaired.JPG (424KB - 404 downloads) IMG_4449_drivers side front, quarter lower section, repaired.JPG (359KB - 421 downloads) IMG_4450_drvier side rear, accident repaired.JPG (381KB - 414 downloads) IMG_4451_passenger side rear detail, rain drainage.JPG (374KB - 425 downloads) IMG_4452_the thrash can is filling quite quick, part 1.JPG (358KB - 406 downloads) IMG_4453_the trash can if filling quite fast, part 2.JPG (288KB - 432 downloads) | ||
