Engine id help required... Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
poly |
Veteran Posts: 161 Location: Melbourne, Australia | I need a little help from those in the know ...... I have an engine in the garage that I would like to positively identify. I was told it is a 350 but there is some doubt. The casting number on the block is 1944929 - 4 and has the letters L.S. underneath the numbers. From what I can find out on the net this makes it a 350, BUT on the machined pad under the distributor it has been stamped L 361... Is it a genuine 350 block that was overbored to 361 ? Don't really want to rip the heads off so I can't measure the bore. I am inclined to follow the casting numbers over those that can be stamped / altered . I don't know anything about these motors so any info or links to info would be great. Cheers, Frank | ||
Expert Posts: 3780 Location: NorCal | L is the year code for 1958; 361 is the displacement. | ||
VAN HELSING |
Elite Veteran Posts: 982 Location: Upper Hunter NSW Australia | ........ Frank, If this is any help........... I've got a 361 here from an Australian 59 Desoto which I was told it was the original 361 from this car. The engine numbers on it are:- ML 36I ( the letter "I" is after the 36 , not the number "1"as you'd expect to see to make up 361 ) Other numbers are 3008I ( again, the letter "I ". not the number 1 ) and then the letters " LC " So mine's ML 36I 3008I LC What that all decodes to I have no idea but just putting it up in case it helps you at all. Cheers .............. | ||
VAN HELSING |
Elite Veteran Posts: 982 Location: Upper Hunter NSW Australia | ........ Forgot to add...... My 361 has the casting number on the passenger side of the engine 1944929-8 and underneath that the letters LS ........ | ||
lozrox58 |
Extreme Veteran Posts: 310 Location: Newcastle Australia | My 1959 block has the same numbers: (Xtal_0039s.jpg) (Xtal_0041s.jpg) Attachments ---------------- Xtal_0039s.jpg (60KB - 171 downloads) Xtal_0041s.jpg (59KB - 120 downloads) | ||
poly |
Veteran Posts: 161 Location: Melbourne, Australia | Thanks for the replies. So going by your casting numbers, it seems I have a 1958 361. Strange how that number points to a 350 when searching for a decoding list. Anybody else have any input or thoughts on this? I would really like to have a definite answer one way or the other....... | ||
57plybel |
Extreme Veteran Posts: 594 Location: Melbourne, Australia | I'm guessing the LC stands for Low Compression.... the 3 engines I have pulled apart (local Oz delivery) have ALL had dished pistons. Are yours from Australia, Frank?
Colin | ||
Expert 5K+ Posts: 8948 Location: WHEELING,WV.>>>HOME OF WWVA | 1944929 is a shared casting number of the 350 & 361 from 58 - 64 , mostly 361 . your's is stamped 361 , so it's a 361 , logical , right !-------------------------------------------------later | ||
poly |
Veteran Posts: 161 Location: Melbourne, Australia | 57plybel - 2014-11-10 4:24 PM I'm guessing the LC stands for Low Compression.... the 3 engines I have pulled apart (local Oz delivery) have ALL had dished pistons. Are yours from Australia, Frank?
Colin No, Colin, this engine is from the states. It came with the car. | ||
poly |
Veteran Posts: 161 Location: Melbourne, Australia | 60 dart - 2014-11-10 5:36 PM 1944929 is a shared casting number of the 350 & 361 from 58 - 64 , mostly 361 . your's is stamped 361 , so it's a 361 , logical , right !-------------------------------------------------later Thanks Chuck, I didn't know that two engines could share a casting number. I suppose that clears it up...... it's a 361.. | ||
